02-17-2023, 01:34 PM | #1 |
3598
Rep 6,846
APEX Forged VS-5RS 18" 1 series fitments incoming:
Hey All,
I wanted to give you a quick heads-up before we went into the weekend: After quite a bit of development time and back and forth on these wheels, we are releasing VS-5RS forged wheels for the 1 series. The fitments are going to be 18x8.5 ET40 front, and 18x9.5 ET58 rear. This is a familiar combination to many with an offset in-between our ET45 and ET35s for the front wheel. It's slightly less ideal for completely stock cars but offers more room for anyone running aftermarket suspension that reduces inner clearance around the front suspension. The 18x8.5 ET40 can also of course be run square. Many of you have already seen this car on 17" wheels, but here's a taste of the design on this chassis in a smaller diameter: 17x9 ET42 square shown above Pledging for the 18" Group Buy is open and includes these wheels and the Fitment Guide is updated. The wheels are arriving in May. While we weren't initially going to include them in the Group Buy, we wanted to give the 1 series community the opportunity to join the Ongoing deal and lock in a discount on these wheels, especially those of you who have been waiting since our original release. I hope you enjoy these wheels and are as excited about them as I am. I'll have more news and content around these fitments in the future but let me know if you have questions about these wheels and I'll dive into them next week. -Tom
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey Last edited by Expert@ApexWheels; 01-08-2024 at 06:00 PM.. |
02-17-2023, 08:20 PM | #2 |
208
Rep 223
I want these so bad
Expert@ApexWheels3597.50 |
02-20-2023, 04:49 PM | #3 |
506
Rep 651
How does the brake clearance compare to an SM-10? I'm about to do an AP CP9668 BBK on my "135" (with M3 knuckles, etc.) and was told the 18x8.5 et35 SM-10s I have are about the only non M3/1M wheel that will fit, but that VS-5RS is super sexy and the et40 would definitely be better...
02-21-2023, 11:23 AM | #4 |
191
Rep 128
Drives: 09 135i
Those are absolutely gorgeous! I don't usually prefer a square setup looks-wise, but I LOVE how much meat is on those tires!
02-21-2023, 02:24 PM | #5 | ||
3598
Rep 6,846
-Tom
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey |
02-22-2023, 09:53 AM | #6 | |
506
Rep 651
I talked to someone at Apex a little while ago and they confirmed it should fit with my current SM-10s. My car is essentially a 1M/E9x M3 at both ends but still has the 135 body panels. The 18x8.5 et35 SM-10s juuuust fit in the front with 3.5 degrees of camber but it would definitely be nice to go to a et40. That would allow me to either eliminate rubbing with a 245/40R18 or, run a 255. |
02-22-2023, 12:05 PM | #7 | |
3598
Rep 6,846
We have the clearances of this kit done against most of the M3 fitments, but not 1 series. -Tom
amg6975506.00 |
02-22-2023, 01:23 PM | #8 | |
3598
Rep 6,846
Green C denotes clears in all directions with no spacers needed or barrel clearance issues. I found your email to our support team on 10/4/22. Geirsen didn't have the data for the M3 kit VS the 8.5" wheels on hand but he confirmed that the AP/Essex kit for the non-m e9x chassis cleared, which it does. The M3 kit on the other hand needs the spacers for the 9668 version as that caliper is thicker. While it's nice to have that massive endurance pad in the calipers, the 9660 would be easier to run if you stick with the M3 kits. Again, caveats in your case if something is slightly different from the M3 assembly. Hope that helps. -Tom
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey Last edited by Expert@ApexWheels; 02-23-2023 at 04:44 PM.. |
amg6975506.00 |
02-22-2023, 04:20 PM | #9 | |
506
Rep 651
It's also interesting that the 9668 kit needs more spacer with the VS-5RS, but with the 9660 kit it needs less(no) spacer with the VS-5RS. |
01-08-2024, 06:33 PM | #10 |
3598
Rep 6,846
Video & Photo shoot update
A better look at the 18" VS-5RS on a volunteer car:
Wheels: Brushed Clear VS-5RS with Hankook RS-4s Front: 18x8.5 ET40 with 5mm spacer & 245/40-18 Rear: 18x9.5 ET58 with 3mm spacer & 265/35-18 We'll have photos soon, but thought you all might enjoy this quick video of the new VS-5RS in action.
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey Last edited by Expert@ApexWheels; 01-09-2024 at 11:19 AM.. |
01-08-2024, 10:10 PM | #11 |
158
Rep 123
Beautiful.
ApexWheels1445.00 |
01-10-2024, 09:17 PM | #12 |
707
Rep 2,450
Thanks for another excellent option in one series offsets. Quick question, Will these clear the F8 M3/M4, 380 mm brakes?
Expert@ApexWheels3597.50 ShocknAwe3246.00 |
01-11-2024, 10:59 AM | #13 | |
1Addict
3246
Rep 7,913
Additionally what offset and width do you recommend for 1M clone bodywork and nonM rear subframe track width. I'm assuming 9.5et22 it's still the front spec.
01-11-2024, 11:01 AM | #14 | |
3598
Rep 6,846
Other kits might not share the exact same clearances if the calipers sit in a slightly different place. -Tom
01-11-2024, 11:09 AM | #15 | |
3598
Rep 6,846
This car is running that exact fitment: https://apexwheels.com/gallery/bmw/1...port-gold-1351 If you want a less aggressive front wheel, you can go to a ET28 9.5. If the car is going to be track-focused, 18x10 ET25 square is a good option provided you've got enough camber dialed in up front via camber plates. -Tom
01-11-2024, 10:42 PM | #16 | |
1Addict
3246
Rep 7,913
01-12-2024, 11:32 AM | #17 |
3598
Rep 6,846
Yeah, it's a great gold IMO. Its also available in the standard offsets for the normal 1 series fenders so you don't need a 1M conversion to get that color.
-Tom
01-13-2024, 10:48 PM | #18 | |
77
Rep 316
Drives: C63S Sedan|350Z
Rolled fenders?
C63S Sedan: Long Live The V8
350Z: The Very Poorman's 981 GT4 |
01-15-2024, 12:02 PM | #19 |
3598
Rep 6,846
Not as far as I know, but the owner has made a number of modifications to the alignment and suspension.
Full mod list: MCS 1 way coilovers with swift springs. Ground control camber plates. M3 upper and lower control arms. Solid aluminum rear subframe bushings. Adjustable rear toe arms. H&R swaybar with ground contol endlinks. Stoptech ST60 380mm big brake kit. Bayoptiks headlights. Carbon fiber front lip. Carbon fiber mirror caps. Boca style carbon fiber trunk lip. Carbon fiber rear diffuser. NRW carbon fiber interior trim. NRW carbon fiber rear seat delete. Recaro pole position seats. M3 alcanatra flat bottom steering wheel. IND alcanatara shift boot and ebrake boot.
03-18-2024, 10:59 AM | #21 |
3598
Rep 6,846
They are not, we're still producing the 18x8.5 ET45 and 18x9.5 ET58 in our ARC-8 and EC-7 design specifically for the E82 along with the 17x9 ET52.
-Tom
04-04-2024, 05:04 PM | #22 | |
313
Rep 141
Thanks!!! |
