BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) EDC on UK BMW X1 (F48) THE TRUTH
      03-31-2017, 06:39 PM   #23
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
Originally Posted by mchlpeel View Post
The reason for not including it is because i'm not interested in using sport mode.
If it were to benefit comfort mode (which it doesn't) then it would be worthwhile.
Actually, it's worth test driving cars with, and without, before making that decision. Why? Because the ride/damping in a standard (non-EDC equipped) car is not the same as Comfort in a car fitted with EDC, which is slightly softer. BMW changed the springs/struts in EDC equipped X1s from Jan 2016 production, meaning EDC equipped cars are slightly more compliant in the Comfort setting than a standard car, which has spring/damping rates that compromise between Comfort and Sport.
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      04-01-2017, 12:52 AM   #24
Tjalle
183
Drives: X4 35i
That was my instinctive reaction - even if EDC is non-intelligent, there would be a chance that BMW would go for softer setting in the comfort mode than "one for all" in a non EDC car.
      04-01-2017, 02:08 AM   #25
The Beast
The Beast's Avatar
268
Drives: VW Transporter Sportline
I thought that was only on M Sport cars... hence why I asked what model line he was going for
      03-26-2018, 08:58 AM   #26
geome
13
Drives: BMW X1 X LINE XDRIVE 20i
So to my way of thinking the standard suspension my be a better bet as the sport mode will be too hard the comfort mode too soft with the standard being set just right.
      03-26-2018, 05:02 PM   #27
ttimbo
ttimbo's Avatar
282
I think not. Besides, EDC is a cheap option.
      03-13-2021, 07:40 AM   #28
ralphclark
Drives: None
That does seem to mean that you can't just have EDC retrofitted in the hope of improving the ride quality.
Unless the kit includes new struts and springs. In which case it wouldn't be a cheap upgrade.
      03-13-2021, 10:27 AM   #29
plagm
120
Drives: X3 30d 2021, 430d 2017, X1 20D
i Have to say after owning a x1 with edc for 4 years when used you could still sit in the car look at each other and ask " anyone notice any difference at all ? "
If i had to concentrate and try to notice minor changes then its not worth it.
Its cheap to buy i agree but further down the line will it be cheap to fix or replace.................
      03-15-2021, 04:21 PM   #30
ttimbo
ttimbo's Avatar
282
There are alternative adjustable damping systems that can be fitted; some owners have done so, and you can probably read their experiences here. Probably (a LOT) cheaper than buying the OEM BMW parts as an after-thought! Any aftermarket solution will be substantially more expensive than ticking this option when you first order
      03-15-2021, 04:26 PM   #31
ttimbo
ttimbo's Avatar
282
You probably won't notice much difference on a smooth, straight road. But it does sharpen things up — noticeably — on the twisties. Replacement dampers should not be too expensive — apart from the BMW tax. The system is at the simple end of variable damper technologies
      11-28-2021, 01:22 PM   #32
Salvos
Drives: BMW X1 2016 20d 2016 xdrive
EDC suspension fitted after purchase?
Hi, and good to find you all here! I have just sold my old Q3 2014 quattro for an X1 xdrive 2016 (in Greece cars are much more expensive so I prefer to buy oldies but goodies). Anyway, I searched for a good forum (and company) like this and found you guys! My car was actually, but the manufucturing date is actually 2015, so no EDC or DDC. I am stirring this old thread again as I am exactly at the point where you left this. I want to add genuine EDC, as I am a little scared after the reviews on the rather harsh drive of X1! Is it possible? Will it cost half of my car? I have asked the local BMW here, but I don't particularly trust their knowledges. Thank you and good to find you!
Tags
bmw, edc
