07-13-2020, 03:19 PM | #23 |
65
Rep 244
Just installed the box from Andream (https://www.android-car-dvd.com/prod...32066140471432) for my 2016 F48. If you want to save $400 and get the same box Bimmertech sells, I’d recommend it
07-14-2020, 10:37 AM | #24 |
Rep 23
Hi has anyone used this for Andrioid Auto and does anyone know if you can use the steering wheel to skip tracks. Currently using Bluetooth (spotify) with an Msport wheel im not able to skip tracks. I have to use the next track from the center console
07-14-2020, 10:50 AM | #25 |
15
Rep 13
Try to enable wheel key on MMI settings menu.
03-31-2021, 09:22 AM | #26 | |
Rep 32
F48 Carplay MMI
If could provide more details on process would be great Thanks |
03-31-2021, 10:08 AM | #27 |
Rep 59
Hi, it seems like different F48 owners had different experiences.
Some couldn't move the HU at all, others pulled out the unit completely out and others (like me) could move the HU out but not completely, still with enough space so that you can place your hand behind the HU and remove the original quadlock and then again enough space to connect the new quadlock (wear gloves, trust me, otherwise you could end up with some nasty scratches). Remove the CD/AC trim and the two screws holding the HU. Then just try and see how far the HU comes out. If it doesn't move a bit then better remove the glovebox (no idea how) because I believe it's much easier than removing the whole center console (there is one video on youtube showing how to remove the center console). And yes, don't forget to check if you have black/green optical cable. If yes, then move it to the new quadlock in the same place as it was on the old quadlock. And if you want, I would highly recommend, disconnect the negative pole on the battery. Have patience with everything and take your time. Good luck! |
03-31-2021, 02:52 PM | #29 |
22
Rep 81
04-02-2021, 11:04 AM | #30 |
1799
Rep 3,062
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
04-02-2021, 12:52 PM | #32 |
15
Rep 71
Is it possible to install such a device in my car -
https://aliexpress.ru/item/100500212...00018817603175 2017, May, HU_entrynav |
04-02-2021, 02:12 PM | #33 |
Rep 32
I use Andream and installed in my 2014 535 and works flawlessly. I am also installing in a 2016 x5.
Wang was easy to work with from and Andream but realize they are communicating from China and there is a delay in responding. I ought for 250 and delivered in about 10 days. https://www.android-car-dvd.com/collections/for-bmw/products/ew-bmcp-nbt01a |
