05-08-2024, 10:33 AM | #23 |
BimmerPost Supporting Vendor
523
Rep 340
05-08-2024, 10:37 AM | #24 | |
523
Rep 340
In regards to the overall volume systems, they are almost identical. The real difference between the systems is in the resonance and the interaction between the material and the exhaust pulses. We find that the titanium resonates to deliver the driver and more high frequency experience. This can be construed as ultimately louder, but it is more of a tone change. We find it is a more engaging sound characteristic when compared to the stainless steel. Is it a massive noticeable difference? Not really, but the titanium you save a good chunk of weight and the system is truly a piece of artwork under the vehicle. Hopefully this helps anyone deciding between titanium and stainless. We've tested all the materials thoroughly so that we can offer the ultimate experience! |
05-08-2024, 12:07 PM | #25 | |
3073
Rep 2,735
Drives: 2024 M4 Convertible
I get that you're trying to sell a product, but OP wants something that's not going to go overboard and is very concerned about things like drone and rasp and warranty issues. I get that people like your products but I don't think it's appropriate for OP here. Haze no amount of watching these videos is going to give you an accurate experience of actually driving and owning these systems. I listened to a ton of videos, got a bunch of people's advice, and specifically was told by owners and the actual manufacturer that the setup I went for was going to have zero drone when I was looking, all of that info was wrong when all was said and done. I learned my lesson that you really need to try and find an example to listen in real life and actually sit in the car. The only thing I can recommend for sure is the midpipe-only swap. It's the only setup I've personally experienced where you're going to literally have zero drone and the ability to still keep the car completely silent when you want it. Last edited by Berzerker; 05-08-2024 at 12:13 PM.. |
05-08-2024, 04:19 PM | #26 | |
523
Rep 340
05-09-2024, 02:07 AM | #27 | |
32
Rep 30
05-09-2024, 10:10 AM | #28 |
699
Rep 471
What I don’t get is all these aftermarket axle back options essentially do is straight pipe when the valves are open, amplifying a shitty tone. Not like the s58 is a v8 or v10. The idea of valves is great but I also like having the right tone/volume no matter the mode.
05-09-2024, 12:44 PM | #29 | |
24439
Rep 191,342
https://x-ph.com/sale/ Phone number 702-494-9435 |
05-09-2024, 01:06 PM | #30 | |
3073
Rep 2,735
05-09-2024, 01:56 PM | #31 | |
2009
Rep 5,063
Piping material and metal thickness can also play a roll in the overall sound.
05-09-2024, 05:14 PM | #32 | |
699
Rep 471
It’s like you should either do a midpipe OR an axle back, but not both. I like the idea where the axle back goes through a muffler system no matter what, with an external valve controller to quiet it down a little, particularly on cold starts or other situations (my wife and kids lol). Then, you could hypothetically be more aggressive with the pre axle back. |
05-10-2024, 09:03 AM | #33 | |
2009
Rep 5,063
05-10-2024, 09:30 AM | #34 |
699
Rep 471
05-10-2024, 09:28 PM | #35 |
2009
Rep 5,063
E63M6_G42M240i699.00 |
05-13-2024, 03:20 AM | #38 |
Rep 16
Drives: 2024 m4 competition x drive
Thank you. From the videos I have watched, titanium doesn't have the sound I enjoy. Some sound raspy and have that tin can sound to it. From all the videos I've watched, the Mad Resonated midpipe sounds good and AA pipes sound good too. A couple of the valvetronic videos sound good too. I need to take some notes this week.
kgelfen3602293.00 Berzerker3072.50 |
05-13-2024, 10:58 AM | #39 | |
24439
Rep 191,342
05-13-2024, 03:58 PM | #40 |
2009
Rep 5,063
Titanium setups are definitely not for everyone but they do have a group of people that love them.
05-13-2024, 10:21 PM | #41 | |
348
Rep 284
FWIW, the AWE system maintains the secondary cats, even with the midpipe option. It’s not overly loud with valves open. Like 10-20% louder maybe than with valves closed. |
05-14-2024, 10:23 AM | #43 | |
24439
Rep 191,342
Adding catted downpipes to this system gives it a lot more sound while keeping the nice and clean tone
05-14-2024, 11:57 AM | #44 | |
2009
Rep 5,063
What he is suggesting is allowing some of the exhaust flow to travel through the muffler naturally even when the valves are fully open so that it regulates the sound and it's not just a raspy straight pipe. Bmw is doing this by closing down the valves to around 40% in (open mode) and forcing the air into the muffler causing some back pressure in the process. The result would be similar to adding a resonator inline that is always doing its job regardless of the valve angle.
