04-06-2022, 10:45 PM | #45 | |
Rep 6
https://www.jegs.com/webapp/wcs/stores/servlet/SearchResultsPageCmd?q=+555-150023&storeId=10001&catalogId=10002&langId=-1 |
bad///Mechanic0.00 |
12-29-2022, 01:26 PM | #46 |
Builder of Special Cars
204
Rep 488
Drives: G12 B7,F02 750li,E70 X5M,E46M3
Location: Dallas, TX | Farmington, UT | Gainesville, FL
S63 isnt the same as this N63 setup
Folks - the E70 S63 (X5M), compared to the E70 N63 (X5 5.0i) has a connected bypass between the driver and passenger sides. I followed this entire thread, and I see where all the connections are going, but with an S63 for the same years (2010 to 2013), it's different.
Has anyone installed Sophisticated Redneck setup on an S63 and eliminated the bypass across the top between the two sides? Any issues with it? Any input would be greatly appreciated. Joe Last edited by JellyStyle; 12-29-2022 at 03:17 PM.. |
01-02-2023, 06:31 PM | #47 | |
1416
Rep 1,564
01-02-2023, 06:56 PM | #48 | |
204
Rep 488
01-03-2023, 12:33 AM | #49 |
1416
Rep 1,564
01-03-2023, 12:37 AM | #50 |
1416
Rep 1,564
Below are pics on where to cut the CCV tubes on the M. From there you can install the -8an male fittings as mentioned earlier in this thread. You can use a 3/8" npt tap to make it easier to thread in. Make sure you use a 3/8" npt tap and not just a normal 3/8" tap. There is a huge difference between the two.
0-60Motorsports792.00 Lilian2421.50 |
03-29-2023, 02:09 PM | #51 |
Rep 3
N63 warning
Just wanted everyone to be aware that the aftermarket replacement parts are defective. The original part has a breather hole next to the one way flapper. This breather hole is missing on the aftermarket parts sold everywhere. Please see image of the original part I uploaded here....
06-29-2023, 09:30 AM | #54 |
204
Rep 488
07-01-2023, 02:38 PM | #56 |
204
Rep 488
07-22-2023, 07:52 AM | #58 |
32
Rep 184
If I am reading this right we only need about 6ft of 8an and 4ft of the 6an correct the links are showing like 16ft
also is it critical to run the Vac gauge at road speed? can it just be set for idle? or to many variable? just trying to piece together everything.. Last edited by punisher12b; 07-22-2023 at 08:13 AM.. |
07-23-2023, 10:40 AM | #59 | |
204
Rep 488
07-26-2023, 12:28 PM | #60 |
Rep 5
Drives: 12’ X5 x35i
Would this work for an n55 engine ?
08-08-2023, 07:46 AM | #61 | |
32
Rep 184
08-08-2023, 08:44 AM | #62 | |
204
Rep 488
along with video of how its made: Along with the mount for the Catch Can's themselves too. Give me 2-3 weeks and he can make more, i assure you its worth the small wait. |
08-09-2023, 06:20 PM | #65 |
204
Rep 488
