BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Screen mirroring
      02-13-2018, 07:43 PM   #1
Flyingscotsman
Scotland
186
Drives: G30 520d se
Screen mirroring
Does wifi need enabling for screen mirroring on android?
I assume it's codeable seeing as car play is an option which uses wifi to connect.
*edit*
I've checked the idrive and I don't have the CarPlay option, so I guess it's not possible via wifi without additional hardware.
Is screen mirroring possible via USB?
      02-17-2018, 05:05 PM   #2
Gmoney El Nene
Gmoney El Nene's Avatar
52
Drives: 2018 540i M
*edit*
Yes you must have wi-fi enabled to use screen mirroring. Only works with android and the car must be in park. Works really well
2018 540xi MSport, Med Blue/Mocha
Exec Pack, Cove Mat, HK, Carplay, Lux Seats
19"664M, Wifi, Driving Assistant
      02-17-2018, 06:04 PM   #3
Flyingscotsman
Scotland
186
Drives: G30 520d se
Thanks, that's what I feared. I've been having a play around with it, wondered if there was a way to get it working as I don't have the enhanced Bluetooth/wifi options.
I've enabled video via USB and video in motion, wanted to get android apps showing on the idrive screen, but I guess I'm out of luck.
      02-17-2018, 09:16 PM   #4
Gmoney El Nene
52
Drives: 2018 540i M
I need to enable video in motion. Amaretto...its time..
      02-18-2018, 09:05 AM   #5
Flyingscotsman
Scotland
186
Drives: G30 520d se
TBH I don't think I'll ever use video in motion, was just trying to see if it would work.
      02-18-2018, 02:08 PM   #6
mobilejo
mobilejo's Avatar
1115
Drives: G06 X6 40i
Can he do it yet? Last time I discussed it with him, he could not activate it to work at all speeds, only below 40kmph. I used Bimmercode app in the end.
      02-22-2018, 10:57 AM   #7
zaka999
Drives: 2018 BMW 540 Xdrive Msport
2018 G30 screen mirror for iphone/ipad
Hi,
I am new to this forum and i have seen some posts regarding screen mirroring from bimmertech for iphone.
I purchased 2018 BMW 540i M sport and one of my friend tried to hack its idrive using bimmercode app but said this is not hackable.
Can anyone suggest any link to hack the idrive?
i need to mirror my phone/ipad to idrive
Also, how do you connect to wifi (bmwcarplayXXXXX)
Thanks
      02-22-2018, 11:18 AM   #8
mobilejo
mobilejo's Avatar
1115
Drives: G06 X6 40i
Originally Posted by zaka999 View Post
Hi,
Thanks
You can't code the car to allow screen mirroring with Apple devices. The hardware in this car allows screen mirroring for Android only.
Bimmertech does it by adding a hardware module to the car, but I am not sure if that kit is compatible with the G30.
      02-22-2018, 02:48 PM   #9
zaka999
Yes.. I sent a request to Bimmerfest and they replied saying the kit is not compatible with G30.
      02-23-2018, 10:18 PM   #10
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Yes, I can do it.
      03-01-2018, 04:07 AM   #11
Gmoney El Nene
52
Drives: 2018 540i M
Yes, I can do it.
He did it for me. Works great. But it does stop at 40 miles per hour Android only though!!
Fantastic work Almaretto!
Almaretto2374.00
      05-02-2018, 11:43 PM   #12
Almaretto
Almaretto's Avatar
2374
That is with coding alone.
With bin, it can be done at any speed.
      11-05-2018, 07:48 PM   #13
fayzamin
Malaysia
Drives: X5 E40
*edit*
Yes it is possible via usb. It’s within the Media cluster. Screen mirroring is possible too without WiFi, but in your android mobile you need to enable smart screen.
      11-05-2018, 10:39 PM   #14
Almaretto
Almaretto's Avatar
2374
Possible without WLAN antenna but inexpensive part (if needed) and much more reliable connection.
You would need some kind of multimedia interface between device and head-unit as it does not have traditional AV (TV-like) inputs.
      11-06-2018, 09:08 AM   #15
bpbaud
Drives: 530i
Screen mirroring is no longer supported by newer versions of Android, starting with Android 6 (Marshmallow).
https://en.wikipedia.org/wiki/Miracast#Android
      10-05-2023, 01:42 PM   #16
M550iGuy8675
Drives: 2018 bmw m550i xdrive
My 2018 g30 has apple play built in, 3 different wifi items when I try to connect with my phone (updates S23 ultra) and no matter what I do I can't screen mirror. Any ideas?
      10-05-2023, 02:55 PM   #17
mimoon
Drives: G31
you can use the AAIDrive app
      10-06-2023, 05:54 AM   #18
AD51YYY
AD51YYY's Avatar
15
Drives: BMW 530e M Sport 2018
2022 BMW 520d  [0.00]
I have a 2022 g30 lci, is there any way of screen mirroring on this? There used to be something on android auto early this year but I think android auto update stopped these apps working?
I have just installed aaidrive but looks like it's not compatible with my idrive version?
5post
