XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 Photos / Videos / Media
Register FAQ Calendar Today's Posts
      08-20-2017, 08:09 PM   #45
GTony
Australia
28
Drives: 2015 X3 F25 XDrive 28i M Sport
Originally Posted by bmwx1sq View Post
245/18/40 in the front
285/18/35 in the rear
Camber is -1 f and -3 r
Looking Good with that Stance and Wheels/Tires Set Up.
I guess yours is an Xdrive.
      08-24-2017, 08:26 PM   #46
bmwx1sq
bmwx1sq's Avatar
145
Drives: BMW X1 35i
Thanks! Yeah it's a 35
      09-10-2017, 09:27 AM   #47
kapetajr
Drives: 2015 E84 X128I
E38 M-PARS with 245/40/18 FRONTS & 275/35/18 REARS
No rubbing in the front or rear at stock ride height. I will update this once I lower it on H&Rs.
2015 E84 x128i/Alpineweiss/TunerWerks Module/E38 MPARS/
1991 Toyota Soarer - turbo6
      09-10-2017, 04:23 PM   #48
bmwx1sq
bmwx1sq's Avatar
145
Drives: BMW X1 35i
You will rub on big bumps. There is a tap that is right in the middle of the fender opening.
      09-11-2017, 11:58 AM   #49
kapetajr
Thanks for the info. Can the tap be taken care of with a dremel or cutoff wheel?
      09-11-2017, 12:42 PM   #50
kiloTHREE
76
Drives: '13 xDrive28i
What tires did you get, I can't find anything stateside in the size.
      09-14-2017, 05:37 AM   #51
bmwx1sq
bmwx1sq's Avatar
145
Drives: BMW X1 35i
I used a Dremel to cut the tap then sprayed some black paint on it
      09-14-2017, 05:38 AM   #52
bmwx1sq
bmwx1sq's Avatar
145
Drives: BMW X1 35i
What do you mean? There is plenty of 245/40/18 and 285/35/18s
      09-14-2017, 08:16 AM   #53
kiloTHREE
76
      09-14-2017, 08:22 PM   #54
Dalco450
Dalco450's Avatar
84
Drives: X1 M-Sport
Any problems with XDrive and 0.53% variance between F and R ?
      09-15-2017, 08:23 AM   #55
kiloTHREE
76
4 PSI difference will result in a larger % variance than that. How accurate do you think people are with tire pressure?
      09-15-2017, 08:55 AM   #56
kapetajr
Cool thanks, I'll make sure to do the same.
Toyo Proxe 4's
http://www.toyotires.ca/tire/pattern/proxes-4
No issues so far, I have driven about 1000km's with the tires. Doing the Tcase, Diff and Transmission pan/fluids this weekend.
      09-15-2017, 02:41 PM   #57
kiloTHREE
76
Oh please take pictures!
      09-16-2017, 08:58 PM   #58
Dalco450
Dalco450's Avatar
84
Drives: X1 M-Sport
Any links to the theory ? I'm interested because they just changed my transfer case last week under warranty. I don't want to pay the bill if it arrives again because of wrong size of tires. My warranty expires next week.
      09-17-2017, 03:38 PM   #59
kapetajr
Dunno if this helps but here is what the manual says
"The tire circumference can fluctuate up to 1% or more as a result of mixed tires or wear. The tire tolerance logic decides depending on the driver's command and driving situation whether the slip is to occur in the transfer case clutch or at the contact area between tire and road.
If the slip is permitted in the transfer case clutch, the locking pressure set by the pre-con- trol is reduced in order to keep the work loss low. In the driving dynamic control situation, the clutch is locked slightly more than normal, the four wheel drive is always guaranteed when required.
For maximum xDrive performance, tires (and wheels) of the same diameter should be installed on the vehicle."
      09-17-2017, 03:45 PM   #60
kapetajr
Will do, got a little busy this weekend. I'll try to put a DIY together once I get it done.
      09-18-2017, 10:59 AM   #61
kiloTHREE
76
Besides common sense?
In fact some vehicles these days use ABS sensors to measure when a tire is low on air instead of physical sensors in the wheels. This works because it compares the number of rotations on one wheel to another. When the tire is low, the number of rotations will be higher thus tripping the TPMS idiot light.
      09-19-2017, 03:15 AM   #62
bmwx1sq
bmwx1sq's Avatar
145
Drives: BMW X1 35i
Here is more pictures of the rear setup. I got new faces to pull in the rear about a half inch which will give me more clearance from the fender. My KW are settling and are not as soft anymore. I ll post more pictures when my new faces come back from powder coating. Also remember that is a 5" lip in the rear. Lol
      09-19-2017, 07:23 PM   #63
Dalco450
Dalco450's Avatar
84
Drives: X1 M-Sport
With my winter square setup in 225/45R18, I must put 38psi in Fronts and 45psi in Rears. So, it doesn't make sense for your theory of 4psi = X% diameter variance...
      09-19-2017, 08:40 PM   #64
kiloTHREE
76
Yep this is where I give up because it seems like there may be a lot that doesn't make sense in your world sorry, no hard feelings.
      12-24-2017, 03:08 PM   #65
KWX1
KWX1's Avatar
25
Drives: X1 Xdrive35i
New Shoes
Wheels: CSL M3 Repros 19x8.5 squared ET35
Tires: 245/40/19
Spacers : Rear, 12mm just to bring flush to top of fender
Clearance: no problem, stock height.
bmwx1sq145.00
      02-22-2018, 11:43 AM   #66
Sabander
Drives: 2012 e84 X1
Hello, New to this forum, just bought a 2012 X1 28i.
After seeing these pictures i'm excited to change out the stock 17's for some of the iconic BMW styles.
Has anyone ever put an 8" wide 17 rim on the x1?
Would this require a spacer?
I'm not sure what the offset is on the rims I'm looking at, but i'm being told either 34 or 40.
Thanks!
