F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 10 HU discussion
ARMA SPEED
      03-10-2020, 02:14 PM   #89
Alpina_Guy
Dirk
Alpina_Guy's Avatar
Germany
Drives: Alpina D5
Booting time is irrelevant for me, its just once.
More interesting is reliability, security, etc.
      03-10-2020, 02:50 PM   #90
daschacka
77
Drives: M5Competition
Bluetooth i havent checkef specifically yet but i would be surprised if they have opened it. but i will check later and post the result.
Boot time even i havent timed it, it feels pretty same compared to 9.0
Im still on an MCU from July 2018. tbh i never experienced a low audio bug i dont know if its a Mcu thing or not. I was on 3.8.x aswell and it was the same since 2.3.x
      03-10-2020, 03:15 PM   #91
Kri
Austria
1084
Drives: E87
Originally Posted by shakir View Post
Hi all. 1st time poster but love this forum for a long time as an awesome source of information!
Today I got an email from the supplier of my qualcom android head unit (octa core /64gig/4g/wifi) with a link to download android 10 (was 9 before) update.
I have updated newer versions of android 9 with no problem.
Anyway. after the update, its now stuck in a 'no signal' loop that then goes to scrambled graphics that I cant decipher enough to make out what menu its on..
It seems to be working in the background as songs were playing but the video mode seems wrong and I cant seem to fix it..
I have even uploaded and edited version of the bmw-oem xml file in case i could tweak it somehow there.
My car is CCC - perhaps they sent me a CIC Bios?
I have also tried renaming older android 9 ksw files to the 'factory reset' filename but it doesnt seem to force install of that at all..
What can I do? Obviously dont want to wait 6 months and pay return postage to china at this time of panic.
thanks so much for any help!
Shakir .
Heres the email from them - Andream
Download link:
https://mega.nz/#!2UwnRS6T!jyILVx7ka...xAEOkM3pgfcP6Q
Note:
for Android 9.0, change the file name to 'Ksw-P-Userdebug_OS_v1.2.5-ota.zip'.
for Android 10.0, don't need to change the file name.
Qualcomm upgrade instructions:
(Note: The upgrade process cannot be powered off and the files are not extracted.)
Upgrade path: U disk or SD card root directory
Step:
1. Copy the upgrade file to the root directory of the U disk/SD card (first level directory)
2. Insert the USB flash drive/SD card containing the upgrade file to the USB port.
3. Wait for the machine to recognize the SD card/U disk and the upgrade prompt box appears.
4. Click “Yes” and the system will start to upgrade until the vehicle terminal automatically restarts and the upgrade is successful.
5. The upgrade process takes 5 minutes.
I checked the update in comparison to 1.2.2, this version 1.2.5 is from 26th February 2020.
As The update is only one day younger than Android 9.0 3.8.5 probably from this build on come new features/fixes.
Code:
ro.build.display.id=Ksw-Q-Userdebug_OS_v1.2.5
ro.build.version.incremental=eng.zlx.20200226.150347
ro.system.build.date=Wed Feb 26 15:03:29 CST 2020
ro.system.build.fingerprint=qti/msm8953_64/msm8953_64:10/QKQ1.191008.001/zlx02261503:userdebug/test-keys
Update/Feature: ALS Dashboard now with different speed mph support
Update/Bugfix: KswPMedia Startactivity change (function unknown?)
Update/Bugfix: Change to TXZNET Notification behavior
Update/Change: again some LTE providers deleted
Update/Change: Change to mcu listener change unknown (new code)
As i don`t run on Android 10 yet, it would be good if users can give feedback if they find changes fitting my source code changes.
Kri
      03-10-2020, 03:16 PM   #92
Kri
Austria
1084
Drives: E87
Originally Posted by daschacka View Post
I reuploaded it to Mega since i dont have a Wetransfer account:
https://mega.nz/#!Gh9HWC4S!6GZ3RWaNv...ZUGRZLNAppWSDs
Thx, Mega.nz is also fine, btw wetransfer does not require an account
I checked the update in comparison to 1.2.5, this version 1.3.0 is from 2nd March 2020.
Code:
ro.build.display.id=Ksw-Q-Userdebug_OS_v1.3.0
ro.build.version.incremental=eng.zlx.20200302.181440
ro.system.build.date=Mon Mar  2 18:14:35 CST 2020
ro.system.build.fingerprint=qti/msm8953_64/msm8953_64:10/QKQ1.191008.001/zlx03021814:userdebug/test-keys
Update/Bugfix: New Api for caching images (Lcom/bumptech/glide)
Update/Bugfix: Change to Audio Speaker behavior / Bugfix Audio Bass issue (Vendor image: /etc/acdbdata/QRD/QRD_Speaker_cal.acdb)
Update/Change: new function at KswPMedia player "isAcc", start behavior related to ignition ?
Update/Change: change to MCU listener, new code "memory music 8917 delay 02" "openSourceMode" and other
Update/Change: dual_clear_ota.sh - update to recovery procedure MHL Support ?
Update/Change: change to broadcast receiver, myreceiver.smali new code ???
New file: libbmob.so / libBmobStat.so - some kind of Android SDK ?!?!?
New file: Google chrome apk a to preinstall folder will be installed
New file: shell.apk - seems to be an app for gathering bug reports
Found the file where the Update-listener described, the system is listening to following factory file names:
Code:
Ksw-Q-Userdebug_OS_v-ota_factory.zip
Ksw-Q-Userdebug_OS_v-ota-only-reset-data_factory.zip
Ksw-Q-Userdebug_OS_v-ota-reset-data_factory.zip
Kri
Appreciate 2
      03-10-2020, 03:50 PM   #93
nurif20
Drives: BMW F20
is on Android 10 the silent audio bug stil available?
If not i would update my unit
      03-10-2020, 04:51 PM   #94
elnino72
Drives: Bmw E92 320I
Good evening group, I waited to update my 10.25, there were too many bugs, now I read that the new update seems to have solved, do you know if I can go from 1.2 directly to 1.3 or do I have to do other steps? do you recommend to format the drive or can i overwrite it without problems? do power-on animations with splash files also work on Android 10? Thanks to Kri who created this group✌
      03-10-2020, 04:54 PM   #95
elnino72
Ps: Do I have to update the MCU too?
      03-10-2020, 05:53 PM   #96
Victor8490
Drives: F21
Anyone who has updated an Android 10 use Zlink? I would like to update to android 10 but I don't know if zlink will be compatible
      03-11-2020, 05:27 AM   #97
endursa
hardware modder
26
Drives: BMW f20
zlink is usually included in the rom, so if you had it before it should be there regardless
      03-11-2020, 07:56 AM   #98
Xanderl
Drives: F30
Can I download the new carplay software somewhere externally? I updated the dongle first and now I can no longer update the software because an error constantly occurs and then the program is closed when updating. Dongle itself works
      03-11-2020, 02:10 PM   #99
DaniXD
Drives: BMW X6 E71 M Performance Pack
I had the same problem with the update, everytime i tried to upgrade an error comes out. Fortunately the update remains saved in the device. Through ES File Explorer you can found it, i don't remember where.
If you use the Autoplay Box from avinusa i have a copy of the last update of january
Using ES File Explorer check:
1) Local with home icon\Home\Downloader folder
2) Local without home icon\Home\Download
      03-11-2020, 03:00 PM   #100
Xanderl
Drives: F30
I have the Avinusa dongle 😬👍🏻
Dont find anything there ☹️
      03-11-2020, 03:03 PM   #101
akirax
31
Drives: BMW F30
This is frustrating, I've random bootloops, with the needed of factory reset and re install and re configure all.
It's a problem with Android 10, you can check out in Google "Android 10 bootloops".
I need to downgrade to Android 9, any help?
Cheers.
      03-11-2020, 03:21 PM   #102
Kuj0n
Poland
Drives: F31 LCI 320xdA B47
Cheers.
Every vendor say that you can't downgrade from 10 to 9.
I have upgraded today from android 9 to 10 ver 1.2.0 and then updated to 1.3.0. There are no audio bug anymore. Everything work great.
Kri1083.50
      03-11-2020, 03:27 PM   #103
DaniXD
Try this link
https://drive.google.com/open?id=1NO...IFehzi526rm6GB
this is the last update that i have
      03-11-2020, 04:04 PM   #104
Alpina_Guy
Dirk
Alpina_Guy's Avatar
Germany
Drives: Alpina D5
Audio bug still present für me. Same like in android 9.
not the bass but, the other one
      03-12-2020, 03:46 AM   #105
Stainy
265
Drives: 435d Xdrive
What MCU you running? Mine only started with the audio bug when I went to 3.8.3. I probably need to downgrade
      03-12-2020, 05:00 AM   #106
DaniXD
Hello can someone please share "dashboard and cronusviewer" apk apps on your android 9 or 10 unit, because after i restored my unit this 2 apps are missing and i can't found anywhere. thanks
      03-12-2020, 06:04 AM   #107
Mjam
134
Drives: E87, i3, Taycan Cross Turismo
You are referring to a different audio bug than in question here, which came with 3.8.3, where the volume level isn't correctly reflected by the volume slider. This is probably fixed in later versions. The low volume bug has been present always, where the volume is low after boot, until the music app, Bluetooth app or possibly other built in app, is launched. This bug we set up Tasker to handle.
      03-12-2020, 06:45 AM   #108
Xanderl
Drives: F30
Try this link
This is not the latest version the new version is called 2020.01.20.1300 but before this file is downloaded an error occurs and the app closes, is your Idrive in Carplay now moving around properly? (right, left) 😬
      03-12-2020, 06:49 AM   #109
DaniXD
This is not the latest version the new version is called 2020.01.20.1300 but before this file is downloaded an error occurs and the app closes, is your Idrive in Carplay now moving around properly? (right, left) ��
this afternoon i will check another time in my system what version is installed, yes my carplay work perfectly right, left
Hello, i'm so sorry, i share the wrong update: this is the new
https://drive.google.com/open?id=1l9...iR87eoEs3MNegh
      03-12-2020, 07:03 AM   #110
vigorio
12
Drives: BMW F30, 320i
Hi everyone! I´ve been a silent reader of the Android 9 and Android 10 forums for many months and now I have decided to share my experience.
I have an Andream Snapdragon 625 device with extra box (split version) 4 GB RAM and 64 GB ROM and LTE, latest 1.3.0. firmware and latest MCU firmware. No root. I have following USB devices attached to my unit: 128 GB SD-card with my music library, TPMS dongle, OTG-adapter, USB-DVR. Also, I have a non-OEM rearview camera.
I want to answer few questions:
1. Sygic and music. No, the switching between the songs when using Sygic doesn´t work. The switching works, when Sygic is not on the screen. I didn´t test the switching with other navigation apps.
2. The bass bug. I had the bug with Android 10. Now with 1.3.0. firmware it went away.
3. The sound volume bug from Android 9. It remained. BUT! When I start the stock media player WsWMediaKit and close it it doesn´t help anymore! I found a solution in creating a task in Tasker to set the media volume to 15 or max. level on start. It works for now.
Experience:
1. External DAC. I´ve used an USB-stick DAC from Sharkoon. Well, it works but the sound quality is just crap. It is hissing in the background so much that you can not hear the silent or slow music like classics or jazz without drumming bass. The conclusion: no difference or even worse than android sound card. My FiiO X5 is just the best. You kick it in the AUX and there is no better quality than that except you have more expensive hardware.
Questions:
1. My unit remembers the last apps which were opened during the last trip. How to make them close after reboot?
2. Does anyone know how to switch off the android debug mode? It is really annoying.
3. I´ve read that someone has a hissing sounds in background like me. Is that normal? It sounds like a working digital mechanism in the background and reminds me of an old gsm phone near a loudspeaker.
Appreciate 2
Kri1083.50
Mjam133.50
f30post
