02-13-2020, 12:21 PM | #1453 |
6551
Rep 3,039
So, would you take a brand spankers new Supra or a well kept 997.2 Carrera S with say 40,000 miles?
Food for thought. Last edited by Alfisti; 02-13-2020 at 12:35 PM.. |
02-13-2020, 01:10 PM | #1454 | |
17
Rep 249
I'd buy a Supra if they fixed the issues in the next model year. But right now the M240i and M2 are superior cars.
2011 X1
2018 M240i Estoril Blue 2007 335i Jet Black 1992 Eagle Talon TSi |
02-13-2020, 01:44 PM | #1455 |
859
Rep 407
Drives: Miss Daisy
02-13-2020, 01:50 PM | #1456 |
4465
Rep 9,160
Don't be silly. Name a $30k car that's rear wheel drive, has more than 300hp, fixed calipers, a limited slip and can put up similar track times to an M2C.
02-13-2020, 01:58 PM | #1458 |
1576
Rep 1,049
The profit margins in these cars are very very small. We are talking ~8.5% profit on an M2... They have far more than 30k into these cars. While the Supra is an innately cheaper car, I HIGHLY doubt the margins on it are large enough to warrant a massive price decrease. This isn't a 911 here, where the margins are near 50%. There is little wiggle room.
02-13-2020, 02:24 PM | #1459 | |
767
Rep 904
As far as the Supra goes, it's a fine performing car, but I don't like the style, I don't like that it's basically a BMW underneath, and I don't like that it doesn't have a manual. I'd rather have a used M2 with a stick, and it's much more practical to boot. |
02-13-2020, 02:26 PM | #1460 | |
4465
Rep 9,160
duder13767.00 MaC-N54-E82486.50 |
02-13-2020, 02:33 PM | #1461 | |
5568
Rep 5,381
https://www.2addicts.com/forums/show...7&postcount=74 https://store.vacmotorsports.com/vf-...35i-p4585.aspx https://f87.bimmerpost.com/forums/sh...8&postcount=30 Tunes simply elevate the curve and power still tends to peak between 6000-6200rpm.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
02-13-2020, 02:36 PM | #1462 | ||
4465
Rep 9,160
You asked why the opinion remains that the N54 was better. For the great majority of the N55 run, the N54 was a better lump. I don't own either now, don't really miss either. I'd take a goofball, please shim my valves again, S54 over either. |
02-13-2020, 02:37 PM | #1463 | |
5568
Rep 5,381
These cars run lower 12s stock. They make around 350whp/400wtq stock. A tune alone pushes them into the 400-420whp and 500wtq range. That's a deep 11 second car with $600-800 in mods. If one wants a fast and generally reliable, 2 seater, for around $50K, the Supra fits that bill well.
Tacoma944.50 |
02-13-2020, 02:40 PM | #1464 |
Ring Leader of G8X Haters
25086
Rep 8,762
4-Cylinder model officially confirmed, now gets the 382hp Inline-6, or at least they changed the stated HP numbers.
https://www.caranddriver.com/news/a3...a-photos-info/
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300 |
02-13-2020, 02:53 PM | #1465 | |
5568
Rep 5,381
It didn't take them 9 years to make a "better" motor to succeed the N54 either. In 2014, the N55 surpassed the stock whp/wtq of the N54. 1M and M2 N55 make similar peak power numbers, but the N55 breathes longer thus the reason why it's the quicker and faster car. You probably don't know that the 2014+ N55 also uses the S55 forged rods and rod bearings or that the crank in the M235/M2 N55 is forged (vs cast in all other N55s) along with additional oil coolers so that oil overheating is never an issue in those two cars. By better, you're surely not talking about reliability between the N54 and N55
02-13-2020, 02:57 PM | #1466 | ||
4465
Rep 9,160
02-13-2020, 03:03 PM | #1467 |
767
Rep 904
I don't necessarily agree with that, even with early N55s, unless you're looking for power over 400whp, and even that is started to get negated when adding aftermarket turbos, the later N55 forged crank, etc. Outside of the obvious reliability advantage, the N55 feels better and sounds better than the N54, but I only have mine tuned to around 360 whp. Also, the N55 had better cooling in the block.
02-13-2020, 03:07 PM | #1468 |
4465
Rep 9,160
Looks like no manual, but more power for the 6.
https://www.caranddriver.com/news/a3...a-photos-info/ |
02-13-2020, 03:09 PM | #1469 | |
5568
Rep 5,381
An extra 50whp in the powerband will equate to a drop of around 0.5 seconds and an additional 4-5 mph in the 1/4 mile. It should be a solid upper 11-second at 116-118mph car. It should be quicker/faster than the M2C, Mustang GT350, and Camaro SS 1LE which are all in that $50-60K price range. Still well off the pace of the C8 though.
02-13-2020, 03:16 PM | #1471 | |
5568
Rep 5,381
Back on topic, turbo access on the Supra is wide open. Turbo replacements now take a couple of hours because of the lack of an external exhaust manifold. It's all right there once you remove the airbox. It's so different (and easy) compare to the N54 and N55 which required a ton of time to remove and replace turbos. Pure Stage 2 turbo, tune, and E30 and you're deep into the 10s. I do wonder about longevity of the ZF 8AT behind that kind of power and the cooling capacity of the radiator and water to liquid IC at those sort of power levels.
02-13-2020, 03:30 PM | #1472 | |
1576
Rep 1,049
02-13-2020, 05:38 PM | #1473 |
90
Rep 210
I wonder what this will mean for the 1,700 new Supras currently on dealership lots.
I would have to imagine that is going to sting dealerships that are holding on to the slower expensive version. Unless of course their is a big price increase for 2021. |
02-13-2020, 05:54 PM | #1474 |
5568
Rep 5,381
This may explain the rather sudden multi-thousand below MSRP mark downs I've seen over the past week.
