BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
      04-15-2024, 02:24 PM   #309
kzg1969
kzg1969's Avatar
Scotland
1301
Drives: X3M Comp / M3 E93
Wonder if someone can help me - I bought an e93 that had this camera conversion by the previous owner (@SaNGRia you did the coding for it).
Everything worked well for last 8month and then the camera stopped displaying the other day. Next day it was back to working and now has stopped again. See pic below where there is no image and camera controls are greyed out.
Any idea where to start fault finding? Camera? TRSVC PDC?
IS there any checks i can do to try and narrow it down?
      04-17-2024, 10:58 PM   #310
SaNGRia
SaNGRia's Avatar
990
Drives: LCI E93 M3 + F85 X5M
Hmm. During the malfunction check the modules related to RC to see which one is not functioning. If modules are responding properly then check the rear camera on the handle. Either cable issue or one of the module going bad.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post!
DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue,
, F85 ACC Retrofit
      04-18-2024, 07:11 AM   #311
kzg1969
kzg1969's Avatar
Scotland
1301
Originally Posted by SaNGRia View Post
...... During the malfunction check the modules related to RC to see which one is not functioning.....
Hi, when you say malfunction check the module, i am guessing you mean by NCSExpert or ISTA - neither of which i have.
the more think about this, i presume if it was camera relate it would at least show a blank screen from camera?
I guess therefore its TRSVC not sending signal to PDC module?
I presume there is no specific fuse for TRSVC? and since PDC works, it cant be that fuse?
      04-25-2024, 03:27 PM   #312
kzg1969
kzg1969's Avatar
Scotland
1301
I have done some investigations as follows;
1. checked all wires for damage
2. replaced cable from camera to TRSVC
3. replaced TRSVC
4. checked solder connection to canbus
5. continuity test from yellow/white/clear from TRSVC connector to CIC head unit
6. checked power to TRSVC - i am getting 11.5v, whereas the pic below shows 14v? Could it be somehow related to that?
Power to TRSVC seems to come in via the yellow connector which comes from the main loom near the MULF connector.
suppose next is a chance on a new camera?
but if anyone has any further ideas?
      04-25-2024, 09:29 PM   #313
SaNGRia
SaNGRia's Avatar
990
Or someone messed up the coding : )
, F85 ACC Retrofit
      04-26-2024, 12:37 AM   #314
kzg1969
kzg1969's Avatar
Scotland
1301
Hope not......you coded the car!!!
(When adam had it)
      04-28-2024, 10:53 PM   #315
SaNGRia
SaNGRia's Avatar
990
(When adam had it)
Everything was working like it should during the time i coded so obviously someone did something. Do you want me to diagnose and find the problem? I can definitely schedule you sometime for this week for remote session. Pm Me!
, F85 ACC Retrofit
      05-10-2024, 07:17 PM   #316
Julz90
Germany
Drives: F48 LCI, E87 LCI, E36 Coupé
So today I replaced the E70 Trsvc with an E84.
So no more error codes regarding missing cameras.
Would it be possible to flash the Trsvc (e70) to another zusb (E84) ?
url=https://postimg.cc/N98NGFGH][/url]
      05-10-2024, 07:20 PM   #317
Julz90
Germany
[QUOTE=Julz90;31143518]So today I replaced the E70 Trsvc with an E84.
m3post
