12-04-2023, 09:37 AM | #45 | |
13100
Rep 18,779
Tokenmaster last blog is Nov 22. Seems like he is under the radar for now until coding2.0 is cracked.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
VirtualGuitars7869.50 |
12-04-2023, 09:43 AM | #46 |
7870
Rep 5,796
Drives: 2024 BMW XM Label
I don’t know how in the world they are going to crack this considering the “not-so-local” files have to come from BMW’s servers…. Even if you were able to get your hands on the CAFD files, there’s no way to get them to the vehicle without being digitally signed by BMW. Even if they’re able to make this magically happen somehow, it will probably eff with the ability to get future software updates when the “hacked” digital signature checksums don’t match.
r33_RGSport13099.50 |
12-26-2023, 08:53 PM | #47 |
Rep 4
This is my 4th BMW. I've never had an issue with one until now, but also my first hybrid.
I've had my XM Label for 6 weeks and my CEL light came on while traveling . Initially, "Fuel tank gauge and range display malfunction". Filled tank to be certain I had enough fuel to travel last 30-40 miles. After refueling, fuel gauge didn't update and displayed zero fuel. Also, even though I wasn't in Hybrid or Electric Mode, my battery power level continued decreasing.. Received 2nd message "Range low, Avoid overtaking. Substantial reduction in drive power possible. Refuel and charge for full drive power." Called BMW where I purchased and was told to use Sport mode and continue driving. Battery power remained at 8 miles for remainder of trip, and then received 3rd alert message "Cont. driving possiblerivetrain. Range 8mi. Fuel tank gauge. Cont. driving possible" Anyone else with a fuel/range display malfunction issue? I am taking it in tomorrow. Praying for a quick repair. 🙏🏼 |
12-26-2023, 09:11 PM | #48 | |
7870
Rep 5,796
I really wouldn’t worry about it unless you see error message repeatedly. It’s not uncommon to get erroneous errors like this with iDrive 8 and newer. By the way, if you set one of your M buttons to e-control, that will disable the electric motor for that drive session and your vehicle operate with engine-only. If there ends up being a problem with the charging system, you can still drive your vehicle with the engine-only. We used to get erroneous errors like this on a daily basis in the early days of the iX platform. The consensus was not to worry about it unless the error messages return. With all of this being said, I haven’t had any of these issues on my XM Label. |
12-26-2023, 09:26 PM | #49 | |
Rep 4
When I pull up My BMW app, it indicates fuel level at 81%/ - - mi. I hope you're right and this is a simple fix. |
12-26-2023, 09:32 PM | #50 | |
7870
Rep 5,796
I have my M1 button setup this way which I press after each time I start the vehicle. In this scenario, you won’t be using the electric motor at all and the battery level will probably say consistent or higher as it recharges due to braking - which is when it recharges itself. If it keeps coming back after iDrive reboots, then you probably do have an issue with the charging system. |
12-26-2023, 10:04 PM | #51 | |
Rep 4
Would a charging issue affect the fuel gauge reading? I did plug in XM after this incident and it completely recharged battery. |
12-26-2023, 10:07 PM | #52 | |
7870
Rep 5,796
Don’t forget that the hybrid mode is there for performance, not range. My battery range stays at 98% all the time because I’m not ever using it. If I was actually going to race someone, I would turn hybrid mode back on. |
03-13-2024, 05:42 PM | #53 |
190
Rep 425
For the record and to keep this thread going - I just got the CEL on my brand new XM. I had just hit the 300 mi and within minutes the CEL came on. I called Service (I just left the BMW place 2 hours ago) and he was busy, called my SA and she went over to service to let them know I'll be bringing it in tomorrow if it doesn't clear on its own
03-13-2024, 06:40 PM | #54 | |
7870
Rep 5,796
03-13-2024, 11:11 PM | #55 |
190
Rep 425
yes, very sorry about that - but I was following along different threads, and knowing few people read some of these threads figure I would inquire with people who were following the other threads. Plus I was in a parking lot with new CEL trying to get through to my SA and BMW service to find out some answers and wondering if I could drive home - which I did eventually. the Service guy said it shouldn't be a problem as long as the vehicle didn't feel it was driving differently.
03-13-2024, 11:16 PM | #56 | |
7870
Rep 5,796
leightos189.50 |
03-14-2024, 07:26 AM | #57 | |
Alpina!
364
Rep 298
leightos189.50 |
03-14-2024, 01:12 PM | #58 |
169
Rep 173
Off-topic. How’s Manheim nowadays.? When I use to live in Baltimore, I had a guy that I bought cars from for over 20 years. I use to love going to the exotic Thursday auction with him even just to go.
03-15-2024, 05:28 PM | #59 |
190
Rep 425
Verdict on my CEL - it was an expansion valve related to the cooling of the battery. Others have stated a similar diagnosis. They cleared and replaced it and ran the car for a time. We'll see what happens.
Edit: did anyone who had this CEL early and the same valve problem get their valve replaced and the problem returned ? I've read the posts and see most say it was cleared of course but not sure if they had the faulty part replaced. I know we were lucky here in Vegas to have the part on hand. Update: yesterday they kept the car because today (Saturday) they wanted to replace the other valve just to be sure and to flush the refrigerant system and charge it and run it a few miles. All good let's hope. Last edited by leightos; 03-16-2024 at 09:16 PM.. |
Bornagain73168.50 |
03-15-2024, 07:09 PM | #60 |
941
Rep 594
Drives: XM/XB7
I was diagnosed with this problem also…then had the CEL cleared and it not comeback while waiting for part….then I had valve replaced and have not had CEL comeback yet. I can tell you the day with CEL I drove all electric and drove down to zero miles twice in a day and it was hot. I have a theory valve got stuck when battery got too hot….so I haven’t been driving in electric only to 0 miles from full in a while.
leightos189.50 r33_RGSport13099.50 |
03-15-2024, 07:40 PM | #61 |
7870
Rep 5,796
You guys can buy any ODB adapter for 20 bucks at any auto parts store and clear these codes yourself. It doesn’t hurt anything to do so. Something as simple as an open gas cap can cause the check engine light to come on. if it’s really a problem, the code will keep coming back anyway not to mention everything is logged for BMW to see next time you check-in to the dealer for service.
I also recommend purchasing the following app which is written by the same developer that authors the very popular BimmerCode app. It’s used for diagnosing error codes from the ODB port and decoding some of the BMW language. Worth every single penny. https://apps.apple.com/us/app/bimmer...i/id1065360416 |
03-23-2024, 12:16 PM | #62 | |
190
Rep 425
I did also get a brief DRIVETRAIN MALFUNCTION error on the dash - I have spoken to local BMW service and sales - they will look at the vehicle on Monday. BMWNA is closed today. But I filled out the form online. |
03-23-2024, 12:19 PM | #63 | |
7870
Rep 5,796
You should see the amount of erroneous errors that come up on the full EVs. They sound horrifying, but rarely come back unless there’s an actual defect. I attribute most of those to the original iDrive 8 release which was buggy AF on the EVs. Back to the break-in, you need to get to 1200 miles on the engine before you take it in, not 1200 miles total on the the vehicle. |
03-23-2024, 12:27 PM | #64 | ||
190
Rep 425
I'm def going out today to buy an OBD2 reader. Last edited by leightos; 03-23-2024 at 12:35 PM.. |
03-23-2024, 12:31 PM | #65 |
7870
Rep 5,796
Yeah, a lot of newbies don’t realize that and in their defense, BMW does not make it very clear. Since it is an engine break-in, I guess they assume the driver will understand that. When I first got mine, I was driving in hybrid mode not realizing I wasn’t really working towards the 1200 miles. It took me 100 miles before I realized it.
leightos189.50 |
05-01-2024, 02:25 AM | #66 | |
112
Rep 308
And while it doesn’t affect the drivability, it is pretty annoying. |
