03-23-2020, 08:07 PM | #23 | |
2226
Rep 1,897
flipnkraut135.50 |
03-23-2020, 08:15 PM | #24 |
249
Rep 391
Focus on your electrical installations. Meet with your electrician and discuss what the Porsche/Tesla home fast chargers use and wire it for that (for a future fast charging option). Will be something like a 60amp or two 30 amp plugs. Maybe one 220V and one at 110v. Can then have option of running a decent welder set up off it as well. or lathe or milling machine. All things on my list if I was building.
I’ll never own a Tesla, but there will be great electric sports cars in 10-20 years that I might own or a classic car (e30 or 911) electric convert. Cost is basically some expensive heavy gauge cabling and you can terminate the wiring into a box for future plug installation, you don’t even have to hook it up yet, just get the cable run in the walls that’s heavy enough and with enough wires in it for 220v. Also design your breaker box with your electrician so that it has capacity for all this. Yes it’ll triple the hardware cost but really a lot cheaper now than retrofit in the future. And the hardware is not a huge bill anyways, neither are extra 2 dollar outlets. I’d also go overkill on how many outlets Installed in The garage. Put some at chest height where work bench would be (I have 6 outLet’s on my bench, all are full of chargers for various tools. You will need lots. Then put an outlet every 6 feet all the way around the garage walls. Trust me you will need them as the garage gets full of shelving, lockers, tool boxes, car projects, etc. |
flipnkraut135.50 |
03-23-2020, 08:39 PM | #26 |
2850
Rep 4,322
I didn’t see anyone list it, or maybe I passed it.
I would get a good air compressor with a reeling hose. If you have the space, a 2 post lift is best. You could do anything with it. I just set up my small 1 car garage to fit my car in there and do some work in there. |
flipnkraut135.50 |
03-23-2020, 09:12 PM | #27 |
Remove Before Flight
6746
Rep 1,608
When you put the hose bib in, plumbing it for hot/cold is OUTSTANDING if you're working on the car in even slightly chilly weather.
My father did this when building his house in WA and it's something that I'm thankful for every single time. If it's below 50 degrees, it's nice to have hot water, regardless of what you're doing. R. |
flipnkraut135.50 |
03-23-2020, 09:15 PM | #28 |
595
Rep 145
Beer assistant
Current : 2007 Z4MC, 2010 F650gs, 2018 340i M Performance Edition, 2020 G310gs, 2009 128i
Past : 2001 325 cab, 2002 325xit, 1992 325 M tech ll appearance pack cab, 1990 325is, 1988 M3, 2012 328xit, 2009 M135i cab, 2016 M235i cab, |
flipnkraut135.50 wdb4716.50 |
03-23-2020, 10:38 PM | #29 | |
481
Rep 96
flipnkraut135.50 tim99ws6110.00 |
03-23-2020, 11:03 PM | #30 | |
136
Rep 170
03-23-2020, 11:11 PM | #31 | |
6746
Rep 1,608
We use it at my dad's house (I'll inherit, eventually) FAR more than I would have thought. And, it really was a pittance since he was building the house. Just run a little more flexible tubing and Bob's your uncle. |
flipnkraut135.50 |
03-23-2020, 11:17 PM | #32 | |
136
Rep 170
03-24-2020, 07:01 AM | #33 |
3566
Rep 10,346
Must haves:
2-post lift. Ceramic tile floors. Ductless minisplit Most important, if the garage is part of the house you want to air-seal and insulate it from the living space. I'm talking from roof down to the slab. If there's living space above the garage then insulate the garage ceiling really well (Mineral Wool, Cellulose).
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
flipnkraut135.50 |
03-24-2020, 10:19 AM | #34 | |
136
Rep 170
03-24-2020, 11:11 AM | #35 |
6629
Rep 4,145
Drives: '18 M2 6MT
Loft with a wood ceiling, and a medium dark tile floor. First example is of the ceiling, second is of the floor.
flipnkraut135.50 Frupal788.50 |
03-24-2020, 11:17 AM | #36 |
481
Rep 96
What about those big exhaust vacuum hoses you hang on your tailpipe and see in dealership service bays or fire departments? I assume if done right you can have your car running in the garage when working on it?
flipnkraut135.50 |
03-24-2020, 11:31 AM | #37 | ||
3566
Rep 10,346
03-24-2020, 11:55 AM | #38 |
3216
Rep 2,385
Have these guys in my garages right now - although they might not finish both as we go into lockdown tonight.
http://www.garageliving.com They're doing: 1. Epoxy floors 2. Slat walls 3. Built in cabinets 4. Built in benches in the alcove 5. Overhead storage Phase 2 (not by them - will be different companies) will be: 6. Raised garage doors with side motors 7. BendPak Wide 4 post lift for stacked storage in single car garage 8. MaxJax 2 post lift in the middle of the 2 car garage for working |
03-24-2020, 12:07 PM | #39 |
561
Rep 755
I know not everyone likes the "industrial" look but as far as putting in lots of outlets, I insisted to my electrician (my father-in-law) that I wanted junction boxes and conduit mounted on the outside of the finished walls. I mounted the conduit and my compressed air piping on Unistrut so there wasn't even any need to bend offsets. Straight pipe into the boxes and straight out. Went up 1 size conduit than needed so that if I ever needed to add 220v outlet or whatever I could just run the wire through existing pipe. I love it.
wdb4716.50 |
03-24-2020, 03:16 PM | #40 |
9153
Rep 14,522
here's what i've got done so far. still need to order the rest of the Racedeck tiles. i built this for me and only me. so i wanted more of a showroom look.
already installed LED shop lights throughout painted the walls a medium gray while leaving the windows satin white and the ceiling flat white i still have to order the black utility sink since my white one looks out of place will order a view banners for the walls and a few mechanic chairs
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
03-24-2020, 03:28 PM | #41 |
6746
Rep 1,608
03-24-2020, 03:46 PM | #42 |
136
Rep 170
03-24-2020, 07:20 PM | #43 | |
219
Rep 361
To make a suggestion to the OP - I would strongly consider a perimeter of upper shelving. It has been eye opening to me how much I actually use this space. I have attached some older photos of my garage below. -Mark
2011 BMW 128i - Check out my STX build thread!
flipnkraut135.50 |
03-24-2020, 08:42 PM | #44 | ||
136
Rep 170
Unknown_Car447.00 |
