09-18-2023, 02:14 PM | #1 |
Rep 52
Oil heat exchanger leak, gaskets or r&r?
Hi all, it looks like my oil heat exchanger has bad gaskets 2016 F48 and is leaking coolant (found using UV dye) after i changed my water pump. Question, replace the gaskets (much cheaper) or replace the whole component ($200-350)?
Tags |
f48, oil cooler, oil heat exchanger |
