05-05-2024, 05:26 AM | #13113 | |
215
Rep 1,338
05-05-2024, 01:06 PM | #13114 | |
19
Rep 66
You have everything like me, except the Cust Version. I asked already Andream to see if they have any updates. In case they give me some updates for CIC, I will attach them here so you can also use them. I am pretty sure you also have the Andream Version. |
05-05-2024, 01:15 PM | #13115 | |
Rep 17
1. My steering wheel controls work just fine on the car, there is no need for me to code anything, as seen by others, it simply doesn't seem to work with the Android Auto mmi box. 2. I do not have any bluetooth issues. 3. YouTube I never attempted to use, just made an observation that it will likely want to use the AUX instead of the car Bluetooth. I have no desire in loosing audio quality just to use YouTube via the MMI-Box, I'll have alternatives if I need them. Considering the box interfaces with the car, stays on and boots after some time, if you have this installed you WILL see codes in the HU_NBT portion when car is scanned, again, not the end of the world. Just something to keep in mind. |
05-05-2024, 02:33 PM | #13116 | |
215
Rep 1,338
05-05-2024, 04:36 PM | #13117 |
19
Rep 66
You just need to connect an iPhone device in the AirPlay menu of the MMI. Also, it says that you have to unselect "Use car's bt phone something" in the setup. I tried today with 3 iPhones, 15 Pro Max, 12 Pro and XR and none of them work so curious to see what Andream says about this.
Regarding your problem, you should send a message to ModsUK to assist you with the updates |
05-06-2024, 03:36 PM | #13118 |
Rep 4
Anyone knows where to get the Andream for NBT systems? Im located in Norway and cant seem to find it on AliExpress. Did however find a Andream website, and they also claim to have EU warehouses: https://www.andream-eu.com/product/ewm-bmcp/
Does anyone have any experience with this website? |
05-07-2024, 12:40 PM | #13119 | |
19
Rep 66
Did this update and still doesn't work. Maybe I need a new MCU Vers? Can someone help me with the latest one, please?
05-08-2024, 02:25 AM | #13120 | |
12
Rep 39
Did you try, disable Wifi and Bluetooth on the phone if carplay is connected, afterwards activate Airplay on the MMI and afterwards enable Wifi only on the phone and check if connected by wifi to the mmi box. If connected enable mirroring/airplay on the device. |
05-08-2024, 03:45 AM | #13121 |
19
Rep 66
Yes, I even deleted the Carplay connection for the MMI and phone just to be sure that Carplay doesn't affect in any way the Airplay.
05-09-2024, 01:46 AM | #13123 | |
12
Rep 39
Airplay with iPhone 13 and iPhone 15pro, both with Firmware 17.4.1 works on both cars without isssue. |
minulache18.50 |
05-09-2024, 12:15 PM | #13125 |
12
Rep 39
MCU on BMW 23.4.13.117
MCU on VW Golf 21.10.21.22 But with older firmware (BMW ER174 and Golf 1.6.14) with the same MCU Airplay does not work, wrote to RoadTop support for BMW and Andream for VW Golf, got for both updates and afterwards it works on both. |
minulache18.50 |
05-11-2024, 06:12 AM | #13127 |
Rep 4
Thinking of buying this Andream unit from this website: https://www.andream-eu.com/product/ewm-bmcp/
Attatched image of my NBT version. I have a 2016 330e. It says i have the NBT Evo, but i dont know if i should order the NBT version or the EVO version from Andreams website. Anyone knows? Also saw there was an option to flash from ID4 to ID5 or 6, but this requires a whole new headunit? Last edited by PinkGuy; 05-11-2024 at 06:13 AM.. Reason: Added extra info |
05-11-2024, 06:41 AM | #13128 |
Rep 1
Hi everyone, can someone tell me what software I need to use to update my Andream bmw mmi box? (backside has no small parts)
package has model EW-LBMCP-NBT02B Last edited by fatcatsurfer; 05-12-2024 at 08:30 AM.. |
05-11-2024, 10:30 AM | #13129 | |
Rep 58
05-12-2024, 08:50 AM | #13130 |
557
Rep 1,595
This firmware looks like from Europe, somebody else posted one similar recently. I’m not aware of any previous links or more information about these units.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
fatcatsurfer0.00 |
05-12-2024, 08:51 AM | #13131 | |
557
Rep 1,595
05-12-2024, 05:27 PM | #13132 |
Rep 9
Drives: 2014 BMW 328d
Can anyone tell me if I have the most recent firmware for my unit? I'm not even sure what B2 version it is or what firmware list I should be looking in on the Page 1.
(of course, it uploads my picture sideways... why not, eh?) Last edited by ddubs; 05-12-2024 at 11:46 PM.. |
Yesterday, 07:50 AM | #13133 |
12
Rep 39
Tags |
andream, android, android auto, apple, carplay, mmi, retrofit |
