BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) 10" Subwoofer with Fiberglass Enclosure
      05-03-2020, 01:29 PM   #1
greg21040
41
Drives: BMW M240i xDrive
I figured I'd share some pictures for anyone who wants to attempt to build a fiberglass sub enclosure for the X1.
2017 BMW M240i xDrive - Mission Performance Stage 2 and transmission flash, CSF Intercooler, VRSF 4.5" downpipe, Dinan midpipe, BMW M Performance muffler, Agency Power Cold Air Intake. 11.58 @ 116MPH
CliveL163.00
Vulcan50432.50
      05-03-2020, 08:40 PM   #2
808X1
80
Drives: F48 X1 M-Sport
Nicely done
      05-04-2020, 11:06 AM   #3
greg21040
41
Originally Posted by 808X1 View Post
Nicely done
Thanks! My first one!
      05-04-2020, 11:22 AM   #4
Skyline2.0
Drives: 2018 BMW X1 xDrive
Fresh and very clean looking. Great job Greg.
      05-07-2020, 07:31 PM   #5
DarthRadonis
Drives: 2017 BMW X1 28i Msport package
That looks awesome. How hard is it to add the sub to the stock Idrive infotainment. I feel my H/k speakers need a lil more low end but not too much maybe an 8inch.
      05-07-2020, 07:39 PM   #6
greg21040
41
I replaced all of the speakers with GRS speakers. I got the 2ohm GRS subs for under the seat. I put in a Match plug and play amplifier from bimmertech. Then I used the RCA output from that amp to get the signal for a Kicker mono subwoofer amplifier. That makes it super simple. Then I tuned it with my laptop and was able to control the Kicker amp through the Match amplifier software.
      05-07-2020, 07:55 PM   #7
DarthRadonis
Neat that doesnt sound too hard. I am curious did you choose the sub based on the air that fits in that spot for the enclosure or cause you are a fan of the Sub itself? I am wondering if a 8inch JL W3 would work there?
      05-07-2020, 08:01 PM   #8
greg21040
41
I did. That sub can operate in 0.5 of airspace. I had a ported box at first with a Kicker sub. It required too much space so I checked some reviews and went with the JBL. I made it so that I could still lift the floor to access the underneath space.
There's so much how to videos on YouTube. I saw how to replace the factory amp on there. Took me about 20-25 minutes to do. Then, it took me about 10 minutes per door to change out those speakers and about 5 minutes to do the dash speaker. I also threw some sound deadening in my doors...oh, and in the fiberglass enclosure.
      05-07-2020, 08:08 PM   #9
DarthRadonis
Do you know how much air space is in that enclosure you made? i checked the JL site and the sub i was looking at said .30 for sealed enclose for best sound.
      05-07-2020, 08:09 PM   #10
greg21040
41
Yeah. It's about 0.7
      05-07-2020, 08:12 PM   #11
DarthRadonis
Hmmn thanks for answering my questions.
      05-07-2020, 08:12 PM   #12
greg21040
41
Also, I forgot to mention. The stock amp is located right behind the box and I put the Kicker amp under the box. If you pull out the plastic bin there is the perfect space for it.
      02-26-2021, 05:51 PM   #13
Bcborn59
18
Very Nice Job, Looks to be a 12" sub, is it?
What would you change if you made another?
      02-26-2021, 06:09 PM   #14
Fredro
GOLD Member
Fredro's Avatar
40
Drives: 2020 X1 xDrive Premium
It literally says 10" in the thread title...
Are you using the subs under the seats as well?
2020 x1 xDrive : Black Sapphire Metallic : Premium Package : Fine Wood Fineline Trim : Sport Seats : Wireless Charging : Trailer Hitch : WeatherTech Floor Lining, Cargo Mat, Bumper XL : Complete Blackout, Full Chrome Delete : BavSound Stage One Speaker & Ghost Subwoofer Upgrade : EuroStart Remote Engine Start : Heko Rain Guards
      02-26-2021, 09:29 PM   #15
Bcborn59
18
Fredro, I missed that small bold text lol.
Greg, great pictures, do you have more pictures between the two steps (see attached)? Did you leave the bracing in, that supports the sub mounting ring?
You should have taken a spray foam mold off the finished fiberglass body enclosure (hardest part) and you could have made money building complete sub enclosures off the mold.
      03-09-2021, 01:37 PM   #16
Bcborn59
18
Speaker Install
Greg, I wondering if I should tackle the doors and dash re and re myself.
I watched a could videos, doesn't look to hard. My concern is breaking any clips that hold it all together. Doing this back in the 80's remember always breaking a door retainer clip or it pulling out of the door panel.
I watched a video on the dash cover removal, it looks a little tricky, as the guy had to come at it from all angles.
I sure like your sub box.
      06-25-2021, 01:41 AM   #17
Humpus
Drives: BMW X1 F48 16d
greg21040 I assume you're using the JBL Stage WS1000 because it's one of the only subs that will fit in that enclosure because of the shallow depth, correct?
I cannot seem to find one here in Belgium, but I could go for a Rockford Fosgate R2SD2-10 (mounting depth 86mm) with a sealed box volume of 0.7 cu. ft. (19.8 Liters). That matches your volume exactly. Max mounting depth should be something like 10cm I assume.
The dashboard speaker is super easy. Just use a plastic trim tool and lift it up near the front (it hinges at the windshield side).
For the doors, there are two screws in the door handle and one or two at the bottom. Remove the door handle trim by wedging a screwdriver into the notch at the bottom of it.
Once the screws are removed, the whole panel comes off if you pull it towards you. Just check where all the clips are located and put them back before you re-install it.
Some quick pics here.
      06-25-2021, 10:16 AM   #18
Bcborn59
18
Match dash speaker and rear doors on backorder, here in Canada.
      06-25-2021, 06:23 PM   #19
CnSky
Ireland
333
Drives: BMW 530E 2017
Very clean job impressed!!
      01-01-2024, 12:03 AM   #20
Fitf8
Fitf8's Avatar
Drives: BMW X1 F48
Nicely done! Shows I wasn’t crazy when I started one similar.
Thanks for sharing!
