BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Blacked out dials scratches
      02-04-2020, 12:10 PM   #1
adi555
Drives: F48
I've got the model which has blacked out dials. And i can see a lot of hairline scratches all over. Only noticeable under direct sunlight. Looks damn ugly. Is this common?
      02-04-2020, 10:33 PM   #2
00max00
19
Drives: BMW X1 - option loaded
Not common. I thought the instrument cluster cover was the part of car that was least likely to be touched/scratched.
      02-05-2020, 01:20 AM   #3
adi555
Drives: F48
I thought the same but this version does not have a glass/plastic cover as seen in the other versions. I feel it's the black coating that is prone to scratches even if wiped with good cloth.
      02-05-2020, 04:37 AM   #4
Jorix
73
Yep. Mine also got tiny scratches, after a simple cloth wipe... Same for the black rooftop rails.
      02-05-2020, 10:01 AM   #5
adi555
Drives: F48
Any fix for this?
      02-05-2020, 10:23 AM   #6
kavatski
147
Drives: 2023 X3 30iX
Yes, it’s common. The anti-reflective plastic used for gauge covers is very easily scratched. I try not to touch it at all, but if it needs to be cleaned or dusted, I use a very soft eyeglass cleaning cloth. If you can’t live with it, a plastic polish like Meguiars PlastX may help a little, but I’d be very cautious and test in a small area to make sure you’re not making it worse.
      02-05-2020, 11:30 AM   #7
adi555
Drives: F48
Would PlastX work on this? Or will it peel of the black coat?
      02-05-2020, 01:15 PM   #8
kavatski
147
I have the same black panel and I think it’s a clear plastic on top, but regardless, PlastX is pretty mild and I don’t think would remove a coating, if there is one. However, the gauge cluster plastic is likely pretty soft, which is why it scratches so easily, so you’d have to be very careful indeed to avoid making it worse. Googling “Plastx gauge cluster” gave some results with good tips on how to go about it.
Pete17133.50
      02-06-2020, 11:16 AM   #9
adi555
Drives: F48
Can't believe BMW got so cheap parts in the car!
      02-07-2020, 02:12 AM   #10
Jorix
73
Yep mine is the same. Also the black paint around the gear lever...
      03-31-2021, 02:47 AM   #11
altziebler jános
Drives: f48 x1 sdrive20i
black panel
Sziasztok,én a sonax fényes műanyag és gumiápolóját használom rá.
Nem marad matt,fényes lesz de legalább a karc nem látszik.
MJE60678.00
      03-31-2021, 06:40 AM   #12
RuPo
Netherlands
Drives: BMW X1 (F48/ 2018)
Use soft materiaal, in the most wipes is added wood. Wood could made scratches.
g.Ruud
      04-01-2021, 11:39 PM   #13
///Makis
///Makis's Avatar
55
Drives: BMW 128i
I have the same problem, it's hideous and I hate looking at it, i can't imagine the clear plastic is too much work to remove and if not may be worth polishing it and adding a clear coating of some sort to give it some protection.
Does the x1 share the same cluster with any other models? If so maybe they have a better glass / plastic window?
      04-02-2021, 02:10 AM   #14
normanho23
Drives: X1 F48
I bought "custom cut" PPF from taobao to cover the scratches on the dials. Look ok now.
      04-02-2021, 03:06 AM   #15
MJE60
MJE60's Avatar
Translation
Hi, I use sonax glossy plastic and rubber care for it.
It will not stay matte, it will be shiny but at least the scratch will not be visible.
      04-02-2021, 03:14 AM   #16
MJE60
MJE60's Avatar
Best tip is never wipe these surfaces with cloth (even glass cleaning cloths). Use car detailing putty to dab and lift then dust, this eliminates risk of micro-stratches.
https://www.amazon.co.uk/Cleaning-De...s%2C159&sr=8-5
