M2 Technical Topics > Track / Autocross / Dragstrip > ▀▄ eas - Antigravity Drop-in LiFePO4 Lithium Batteries for BMW - Save 40lbs!
      03-18-2021, 04:58 PM   #1
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
8271
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Antigravity Lifepo4 Lithium Batteries
While widely known for their MicroStart Jump Starter accessories, Antigravity Batteries has changed the game again with their latest Lithium-Ion Car Batteries. The newest RE-START line of batteries offers built-in WIRELESS Remote-activated Jump-Starting, plus a full Battery Management System (BMS) for the safest, longest cycle life possible. They come in exact-fit OEM sizes for most all modern Performance and Passenger Cars/Trucks. We are the First Lithium-Ion Battery company to offer the most popular BCI Sizes including H5/Group-47, H6/Group-48, H7/Group-94R, Group-35 and others. If you need a more compact battery that will be best for Race or performance car applications, see the RS-30 or ATX30-RS. They also feature a full BMS and RE-START technology. All Antigravity Automotive Batteries offer much higher power and are ultra lightweight compared to the lead/acid and AGM batteries they replace.
Specs
- H8/Group 49 OEM Automotive Case size (directly replace stock battery).
- LxWxH: 14 x 7 x 7.5 inches.
- Amp Hour Options: 60 or 80 Ah
- High Power: 60Ah=1800, 80Ah=2000 Cranking Amps
- Exclusive RE-START Technology with Wireless Remote Built-In Jump Starting!
- Complete Battery Management System built-in
- Ultra Lightweight: Drop 40+ lbs instantly over OEM BMW battery!
- Safest Battery Technology using full BMS and LiFePO4 Lithium chemistry
H8 Group-49 Battery
NEW! Lightweight Lithium Car Batteries with Wireless Remote Built-In Jump Starting! The first Intelligent Lithium-Ion Automotive Battery that won’t leave you stranded.
Antigravity Batteries has changed the game again with their latest Lithium-Ion Car Batteries. The newest RE-START line of batteries offers built-in WIRELESS Jump-Starting! That means if your battery is ever discharged, simply press the Button on our provided Keyfob, start the car and drive away! No need for a Jump-Starter, or Roadside Assistance. You don’t even have to open the hood of car to access the battery, and can do it from the safety of sitting in your car!
RE-START TECHNOLOGY: BUILT-IN JUMP-STARTING
Antigravity's amazing RE-START Technology is the first battery ever to offer Wireless Remote-activated built-in Jump Starting. (Can also be activated manually by pressing Restart button on top of battery.) So it won’t allow you to get stranded with a dead battery! For example if you left your lights on, the intelligent Battery Management System (BMS) in each RE-START battery would put itself to sleep before being drained dead, yet save just enough energy to start your vehicle again and get you out of that emergency. And with our WIRELESS REMOTE KEYFOB you can activate the Jump-Starting without ever opening the hood of the car. Simply press the Keyfob Button, start your car and drive away.
FULL BATTERY MANAGEMENT: BUILT-IN BMS FOR SAFETY AND LONG LIFE
The Antigravity Batteries RE-START system offers the latest technology for the safest, longest life cycle possible. Our superior on-board Battery Management System (BMS) offers Safety Circuitry to prevent Over-Discharge and Over-Charge, and has Short-Circuit protections, while additionally offering Cell Balancing and Thermal protections. These advanced features of our BMS make the battery not only as safe as possible, but also extend the life of the battery by keeping the battery in the prime operating zone and not allowing damage to the battery. Therefore creating the longest possible Life Cycle. From 7-9 years are expected from the Antigravity RE-START Batteries depending on use and climate.
PERFORMANCE BENEFITS
Weight: The ultralight 60Ah Antigravity RE-START Batteries weigh 18.5 lbs. The weight savings will lead the road in increasing your vehicle’s performance in several key areas such as handling, allowing shorter braking distances, improved acceleration and even better gas mileage.
H8/GROUP 49
Models Available in 60Ah & 80Ah - both feature better cranking performance than a 90Ah Lead Battery
FEATURES & BENEFITS
- First Battery with WIRELESS Built-In Jump-Starting! Wireless Keyfob Remote actuated Emergency Jump Starting. So you won't be stranded by a dead battery ever again!
- FULL Battery Management System (BMS) including Over-Discharge, Over-Charge, Short Circuit, Thermal Protections and Cell Balancing.
- RE-START TECHNOLOGY: The RE-START Battery has self-restarting capabilities. It intelligently monitors its status and if it senses over-discharge it will put itself into a sleep mode, yet saves enough energy to allow you to RE-START your vehicle. Simply press the wireless keyfob or activation button on the battery.
- OEM FITMENT: Exact Lead/Acid Replacement sizes. No additional modifications or trays necessary to install.
- LONGER LIFE: 2x to 3x the lifecycle of lead/acid and other Lithium batteries due to full Battery Management system.
- HIGH POWER: Up to 3x the Cranking Amps of similar sized lead/acid battery. Better Starting and higher voltage at start-up.
- ULTRA LIGHTWEIGHT: The Antigravity RE-START Battery can be as much as 70% lighter than the Lead/Acid equivalent. This equates to roughly 40lb or more lbs of instant weight-loss just by changing out the battery! That makes the Antigravity Lithium-Ion Battery the most cost-effective weight-loss product hands-down, while offering better starting, handling and braking! A real performance value!
- LOW SELF-DISCHARGE: The RE-START Battery does not self-discharge like Lead/Acid Batteries. It offers a longer storage time provided there are not excessive parasitic drains on the battery.
- DURABILITY AND CAR SAFE: Much more resilient to vibration than Lead/Acid. Incredibly shock and vibration resistant; no liquids or acid inside to spill or drain out. Will not release dangerous Hydrogen while Charging and will not leak liquids that are damaging to your finish or chassis such as acid.
- ENVIRONMENTALLY SAFER BATTERY: No Acid or Heavy Metals such as Lead, Cadmium, or Mercury. Always remember to Recycle your batteries responsibly!
Models Supported
BMW F22 2-Series
BMW F30 3-Series
BMW F32/F33 4-Series
BMW F87 M2
BMW F87 M2 Competition/CS
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      03-18-2021, 04:59 PM   #2
tom @ eas
tom @ eas's Avatar
8271
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Antigravity LiFePO4 Lithium Battery installation
We've been long-term testing and collecting datalogs of this battery type since last year on a daily driver/weekend warrior M4 with no absolutely no voltage issues or starting.
While these steps are for M3/M4, same steps apply for 2-Series/M2:
Comparison of OEM battery and Antigravity
OEM battery weight @ 58lbs
Antigravity weight @ 18.6lbs
The Antigravity batteries come ready to install, no additional parts are needed. In this install, we used the H6-40-RS (60Ah) as it closely matches the OEM battery specs while shedding 11.5 lbs of weight over the stock battery. Its size allows the use of the factory battery hold down cleat without the use of battery adapters or trays. We also include a replacement negative cable with integrated IBS sensor, which keeps monitoring happy and in charging in check.
Only tools needed is a 10mm socket.
Open trunk, battery is located behind access cover of passenger taillight
OEM battery location
Remove negative cable first
Remove (2) 10mm bolts holding in holddown bracket
Unplug IBS sensor from battery cable
Remove 10mm bolt holding battery cleat
Battery cleat removed, set aside
Remove battery vent tube
Remove battery from trunk
Install Antigravity battery and secure down with battery cleat
Reinstall positive terminal
Reinstall negative terminal
Reconnect IBS sensor plug
Reinstall battery holddown bracket
Reinstall battery
      03-18-2021, 05:01 PM   #3
tom @ eas
tom @ eas's Avatar
8271
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Programming and Registration
After installation is completed, the battery needs to be registered like OEM using AGM/LiFePO4 profiles either through ISTA, your favorite 3rd party device (Bimmercode/Bimmerlink), or BMW independent shop. For the H8-60-RS, choose 70Ah AGM setting while H8-80-RS will require the 80Ah AGM setting. This can be done at your local dealership or independent or as we'll describe shortly - at home using your iPhone.
IMPORTANT: Do not skip these steps or it can damage your battery long term. For the DIY user, you will need the following iOS apps and OBD reader:
Bimmerlink
https://www.bimmerlink.app
Bimmercode
https://bimmercode.app
Veepeak OBDCheck BLE OBD2 Bluetooth Scanner
https://www.amazon.com/Veepeak-OBDCh.../dp/B073XKQQQW
Bimmercode - Select vehicle and go into Front Electronic Module (FEM_01), select "Battery Type"
Bimmercode - Change battery type to "70 Ah AGM"
Bimmerlink - Select 12 V Battery
Bimmerlink - Select "Register New Battery"
Bimmerlink - Select "Same Capacity and Type"
[B]Bimmerlink - Select "ok"
Bimmerlink - Battery registered successfully - you're done!
Job complete! Enjoy your new battery. If you have any questions, please ask in the thread or PM.
      03-18-2021, 05:18 PM   #4
SEAT TIME RULES
SEAT TIME RULES's Avatar
1105
Drives: 20 BMW M2C 17 Mazda MX-5 RF
2020 BMW M2C  [5.00]
I have this battery (40 Amp) in my M2C.
Anti Gravity H7/Group 94R OEM Automotive Case size (directly replace stock battery) @15 lbs.
I've had AG batteries in my last 3 cars and all 3 have been stellar.
Big thumbs up on this mod..
2005-2006 BMWCCA Boston Chapter president
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
My 2020M2C Build: https://f87.bimmerpost.com/forums/sh....php?t=1696726
FTP2034.00
      03-18-2021, 05:34 PM   #5
tom @ eas
tom @ eas's Avatar
8271
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
I see you have the battery tracker also, perfect.
      08-18-2021, 08:58 AM   #6
inTgr8r
inTgr8r's Avatar
2435
Drives: M2 Comp
what is the battery tracker??/
      08-18-2021, 10:32 AM   #7
-Eidos
@lbb_kev
496
Drives: 2018 BMW M2 (LBB)
It's a bluetooth device that hooks up to the terminals of the battery. From there you can download an app on the phone that shows you the battery life remaining.
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
inTgr8r2434.50
      08-18-2021, 12:44 PM   #8
tom @ eas
tom @ eas's Avatar
8271
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
As well as logging features. Very handy in determining battery draws with graphing.
inTgr8r2434.50
      02-10-2024, 10:59 AM   #9
bmwstephen
54
Drives: 95' M3, 17' M2
curious but on the f80 platforms, how long did the factory LiON battery last?
Tags
antigravity, battery, eas, lifepo4, lithium
m2
