01-02-2020, 11:34 AM | #89 | |
4862
Rep 3,660
Drives: 981 Cayman GTS
Smee508.00 |
01-02-2020, 11:41 AM | #90 | |
1977
Rep 2,712
1. From the rumor mill, the crank snout on the V1 test rig was supposedly from an N54. So yes, it would not be impossible for the V1 splines to break an N54 based rig. 2. Not a rumor, but this is the 2nd confirmed V1 unit that failed to leave any spline marks on an S55 crank snout. This means the V2 is a must if you have an S55. I'm a big proponent of several BMW vendors, including VTT. I applaud VTT for continuing to develop products despite the constant hate they receive. However, unless this is a case of a few manufacturing defective units floating around, I believe there will be more S55 SCH reports pertaining to the V1 units as time goes by. blackey I'll get back to your PM later today. |
01-02-2020, 11:57 AM | #91 | ||
508
Rep 2,152
is your number 2 the same one as cntzl is referring to?
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
01-02-2020, 12:10 PM | #93 | |
384
Rep 923
behindthen0thing839.50 Smee508.00 |
01-02-2020, 12:40 PM | #94 |
1194
Rep 3,670
Because it says a lot about quality if they let the v1 hit the market in the first place, test products before selling, confirm it puts grooves into the crank not let customers figure out it doesn’t these are very expensive engines we are talking about IMO
01-02-2020, 03:20 PM | #95 |
Mr Bill
296
Rep 545
Hub Choice
I've decided to go with the Max PSI hub through SSR. I suspect the V2 will not spin, but not sure on the tooth wear, and decided to just not take a chance. It also is a better design if I have to pull the hub and rebuild the motor as it hasn't deformed the crank such that only the V2 can be used moving forward.
FYI here is the tooth wear of the V1 hub. It's a different chamfer / tooth profile than the stock one so hard to know if the wear is the different profile or a hardness issue. Chris thinks it's the hardness but until someone with some significant mileage removes a V2 and inspects the teeth it will be hard to know. So far EAS hasn't removed a V2 once installed. This is with 4000 miles, and only 2 sessions on the track btw.
2018 GLC63
2016 Miata 2020 X3M (sold) Turbo Miata Racecar (sold) 1995, 2009, 2015 M3 (sold) |
01-02-2020, 05:20 PM | #98 |
Mr Bill
296
Rep 545
The other sprocket is BMW factory (VTT used the factory oil pump sprocket). It looked perfect, as did my stock unit when I pulled it with 32K miles. My worry is the V1 and V2 use the same profile, so IF it's a profile issue V2 will be effected as well, although since it's a harder material it could take much longer. Who knows if that puts more wear on the chain instead as it might become the wear item at that point. A lot of questions that will not be answered until people have some significant mileage on the V2 and then inspect it.
2018 GLC63
01-02-2020, 05:25 PM | #99 |
758
Rep 1,337
Thanks blackey I edited my post as I checked to see that it was the oem oil sprocket. Wasnt quick enough
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
01-03-2020, 08:08 AM | #102 | |
103
Rep 125
01-03-2020, 12:04 PM | #103 | |
BimmerPost Supporting Vendor
641
Rep 1,029
Glad we were able to get you hooked up with the Maximum PSI Keyed crank hub kit! Let us know if you need any other support at all. Always happy to help! Shah @ SSR Performance |
01-03-2020, 01:07 PM | #104 |
Mr Bill
296
Rep 545
Hi Shah, thanks so much for getting me one so quick. Super appreciated!
2018 GLC63
01-03-2020, 01:09 PM | #105 |
641
Rep 1,029
01-03-2020, 01:11 PM | #106 |
1194
Rep 3,670
01-03-2020, 01:12 PM | #107 |
641
Rep 1,029
01-03-2020, 01:31 PM | #108 |
1194
Rep 3,670
01-03-2020, 02:05 PM | #109 | |
Enthusiast
248
Rep 304
Buy a new built engine to avoid some downtime and use that one in your car. Put together the old engine, sell it, recoup some money, and let someone else assume the risk. There's unaccounted metal. The metal came from somewhere... It's nice to save money, but do you think you won't have this issue again if you button it up and pray for the best? I wouldn't on a modded track car, and even if I did, the added worry would not be worth it. I would factor in the costs of what a missed track event would cost you. Hotels + Travel + Equipment + Track Fees + Ruined Weekend = Not worth it to hope for the best. |
01-04-2020, 01:42 AM | #110 | |
3257
Rep 2,164
I suspect similar issues with the Insane crank hub as well long term with its softer metal and non-tapered teeth. I don't understand why people would cheap out on a couple of hundred bucks when they're spending thousands on labor to get these in. Just spend the extra money people, get the best and find a great installer. Then you can sleep well at night. MaxPSI crank hub and SSR Performance FTW! |
