BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Spare Wheel
      02-05-2020, 09:21 PM   #1
sdp77
Drives: 2018 BMW X1
Spare Wheel
Doesn't the X1 2018 come with a spare wheel?
      02-05-2020, 09:37 PM   #2
sdp77
Drives: 2018 BMW X1
I guess I should have googled first!
Got my answer, had no idea the spare wheel was optional.
      02-06-2020, 08:47 PM   #3
xlr8it
xlr8it's Avatar
30
Drives: F48 X1 20d, SLK55AMG
I just have gone through the same , ended up buying a space saver wheel form a mercedes SLK R171/R172 , and a tire size of 155/80/17
The mercedes spare wheel fits the X1 perfectly, but you need to replace the mercedes tire with 155/80/17
      02-07-2020, 09:22 AM   #4
bimmoris
16
Drives: BMW
I _believe_ if you opt out of run-flat tires, you do get a spare wheel. But the RFT models do not come with a spare.
      02-07-2020, 12:43 PM   #5
CliveL
163
When I specced my X1 back in early 2016 I went for non-runflat tyres and added the spare space-saver wheel and jack to the order. Cost was about £75 GBP. It was an option on the price list available to all models.
      02-07-2020, 03:59 PM   #6
Skyline2.0
Drives: 2018 BMW X1 xDrive
This is true for US market. The dealer I purchased from had no X1s with spares as they all came with RFTs. I was annoyed but couldn't do anything about it except get a spare after the fact.
      02-07-2020, 04:55 PM   #7
AUS_Tin_Pusher
AUS_Tin_Pusher's Avatar
23
Drives: F48 X1 xDrive25i
Why did you do that?
A genuine BMW space saver rim with tire fitted from a dealer cost me $A336.
      02-07-2020, 07:25 PM   #8
Doppelbock
Drives: 2020 X1 xDrive28i
On the US build site, there is an selection for "Space-Saver Spare" under the options tab, once you scroll down from the Packages. The cost is shown as $150 USD. You may be able to order it from the dealership, though I haven't tried myself so I can't say for sure.
      02-08-2020, 02:02 AM   #9
xlr8it
xlr8it's Avatar
30
BMW dealer in Sydney said they can not get it, cost me $50 for the wheel from a local wrecker and $20 for the tyre (commodore space saver is the correct size), so all up $70 and it fits perfectly.
      03-11-2020, 04:06 PM   #10
alanzillo
Drives: X1 2016
Hey guys, do you know if a 2008 528i spare tire (135/80r17) fits the X1 2016? I saw a pretty good deal on a new one.
      03-11-2020, 04:17 PM   #11
Beagler
75
I cannot have a spare wheel for my MSport Xdrive. There cannot be more than 2mm difference in tyre dia. as it affects the AWD and will cause damage due to different tyre wear.
      03-11-2020, 06:38 PM   #12
NorcalMike
NorcalMike's Avatar
20
Drives: 2021 X5 M sport
I think you need to research that a little bit more these X1s are front wheel drive and have a totally different all wheel drive system.
The tire size is more critical when you have a rear wheel drive standard BMW
2021 X5 Xdrive 40i M Sport
Mineral White, Tartufo leather
      03-11-2020, 10:29 PM   #13
xlr8it
xlr8it's Avatar
30
I believe the bolt pattern is different to the X1/X2
      03-12-2020, 02:12 AM   #14
Beagler
75
I spoke to BMW Uk and the dealer both confirm cannot have spare wheel for my XDrive.
      03-12-2020, 05:52 AM   #15
CliveL
163
I have xDrive on my xLine, and I specced the space saver spare wheel when I ordered it. The handbook gives instructions on fitting the space-saver in the event of a puncture of the original, and the only warning is keeping your speed below 50mph. There is no indication that it shouldn't be used if you have the xDrive system.
Beagler74.50
      03-12-2020, 06:16 AM   #16
Beagler
75
I need to get to the bottom of this as I would buy a spacesaver if I could. I have emailed BMW Uk.
      03-12-2020, 06:19 AM   #17
Jorix
73
Usually space-savers shouldn't be used with AWD systems, because you risk damaging them. Not sure about xDrive specifically, but for most AWDs that's true.
Why would you need space-saver anyways? There are modern repair kits.
      03-12-2020, 06:54 AM   #18
CliveL
163
If it helps, I ordered my xDrive xLine 20i back in 2016, and I'm looking at the handbook from that time. The price list from that time, which I still have in PDF format, lists run-flat tyres as a £180 option available on *all* models (sDrive and xDrive) and also lists the "Space saver wheel with car jack (option code 300)" as a £75 option on *all* models. There's no distinction between sDrive and xDrive.
I wouldn't use one for an extended time, but it has seen use in the past on my car when we drive over a large bolt rattling around on the road that punched a hole through my regular tyre. It got us the couple of miles back home, and then the couple of miles to the tyre centre the next day. I don't know if a run-flat tyre would still have been usable for even those short distances with a 10-15mm hole in it, and even if it retained its approximate shape I'm pretty sure it would have been outside this 2mm circumference difference tolerance that's been mentioned above. I've not seen that tolerance mentioned in the handbook by the way...
I'm happy to be corrected, but I'd also be concerned if BMW say that you shouldn't ever use a space saver with xDrive, as they listed it and sold it!
      03-12-2020, 06:58 AM   #19
Skyline2.0
Agreed, Jorix. But, many AWDs do have a space saver spare option or come with one from factory (e.g., Subarus). Using a space saver for a short drive at low speeds with it on the rear axle shouldn't be a problem. If it was, I doubt companies that sell mostly AWD models would even offer a spare.
There are limited scenarios where a spare, regular or full, would avoid getting stranded. I got TWO nails in my rear tire a few months back. One was too close to the sidewall to patch. Luckily it held enough air to get to a tire shop. I swapped on the spare to drive for a day(<10 miles) until the tire was replaced. Also, a patch kit wouldn't be of any good with a bent or cracked rim.
      03-12-2020, 09:24 AM   #20
Beagler
75
Hopefully my recent email to BMW Uk will resolve my issue but it was not an option for my car at website configuration nor at purchase point according to dealer. BMW Uk I spoke to on the phone confirmed this. I look forward to the reply to my recent email to BMW.
      03-12-2020, 05:12 PM   #21
alanzillo
Drives: X1 2016
Yeah, I look at that information, do you think a 135/80r17 will be ok? I saw that everybody use 135/90r17 but I don't know if it makes any difference
      03-12-2020, 06:59 PM   #22
Skyline2.0
Yes, the 80 vs 90 is the aspect ratio. Higher the number, the greater the width of the sidewall. This translates to a slightly larger overall diameter of the tire when all other factors are the same.
Given the greater discrepancy in tire diameter, driving long term on spare isn't a good idea.
