E9x Coding for track
05-29-2019, 08:14 AM | #1 |
21
Rep 80
Hey there, i never actually did any coding for track use and was wondering what need to be done exactly? Most likely going to do it myself this weekend just can't find a thread on exactly what options need to be changed
05-29-2019, 12:07 PM | #2 |
57
Rep 114
Drives: 2008 E91 ZSP
Find thread from paradoxical3 from 1-18-2016 titled Guide to BMW's electronic nannies (coding off e-diff and much more).
2008 E91, ARC-8, 255/40/17 NT01, ER sport cooler, TCK camber plates, coil-overs 400# front 700# rear, Koni SA shocks. M3 Subframe bushings, front + rear control arms, tension struts, strut brace. Quaife, Carbotech, Schroth.
Synectic20.50 |
05-30-2019, 03:24 PM | #3 | |
714
Rep 2,607
Drives: 06 330i E90, 18 530xe G30
https://www.e90post.com/forums/showthread.php?t=1216639 |
08-07-2022, 08:39 PM | #5 | |
1517
Rep 1,492
INPA is more complicated. http://dreamingin302ci.blogspot.com/...ve-handle.html |
RicBond0070.00 |
08-10-2022, 07:19 PM | #7 |
1517
Rep 1,492
08-10-2022, 11:40 PM | #8 |
Rep 65
08-11-2022, 08:58 AM | #9 |
1517
Rep 1,492
I can't help you with that. You have INPA right?
08-13-2022, 04:02 AM | #11 |
1517
Rep 1,492
08-15-2022, 08:36 PM | #14 |
Rep 7
I never knew there were so many nannies hidden in the car. I always thought the 5 second traction button press disabled most everything, but it looks like alot of these are still active even so.
08-16-2022, 09:14 AM | #15 | |
1517
Rep 1,492
You need to code out everything but e.diff. DME might lower power especially if you have 330 and not upgraded 328 LCI. Pre LCI are known to be more aggressive in limiting performance due to brake overheat function. Pressing DSC for 5sec won't do anything to override that. |
09-19-2022, 01:38 PM | #16 |
15
Rep 66
Kind of related to this, or I probably should start a new thread, but is there a knowledge database or any kind of list/guide to traction control values? Because coding out basic options that everyone does, is just barely enough. Because if one goes through the list, there are values assigned to undesteer, oversteer, power reduction etc, and I'm assuming those define how your car is when traction/stability module tries to "help" you while on track.
10-17-2022, 07:59 AM | #17 |
95
Rep 294
Id like to know where the power reduction is as well.....when at track and trying to launch from 2nd gear it wont let me go over 2000rpm without cutting power. Any ideas?
