TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Photo/Video/Audio Gallery
      03-16-2016, 10:31 AM   #45
Deftronix
170
Drives: 12 X5d & 20 X7 M50i
Originally Posted by saleen01 View Post
What tips re those....I have a set of 4" and 5" that i cant decide which to put on....im powder coating them black
What are you lowered on Saleen? Everything looks very good, great choice painting the front side vent splitter to match the wheels.
The tips are supersprint 120mm (4.7"). At 5" you will most likely be hitting the bumper surround. I have very little clearance right now and are already a bitch to clean!
      03-16-2016, 01:07 PM   #46
saleen01
Drives: 2011 x5
thanks
Lowered on H&R 1.2" rides perfect
I colour matched the splitter and the rear trunk roundel
I colour matched the door trim and the aero kit obviously
rims too.. they are real style 215...i colour matched them also, with H&R spacers
I was going to colour match the running boards, but I thought it would be overkill and too much
I can make the 5" tips work, its tight but it will work....yours convinced me in black it wouldn't be too rice.
thanks
      03-16-2016, 02:28 PM   #47
Deftronix
170
Nice work. Wish the Eibachs came down more in the rear like that. I was thinking about doing the rear roundel mount too but was worried about getting it back on there perfect since there are no guide holes. correct?
      03-16-2016, 02:34 PM   #48
socale39
209
Drives: 04 545i SMG
Yeah my Eibachs settled at only .5" drop in the rear. Not too happy about that but it rides very well.
      03-16-2016, 02:41 PM   #49
saleen01
Drives: 2011 x5
yes there are guide holes....pry it off tape the emblem primer and paint...no problems
      03-16-2016, 05:02 PM   #50
Deftronix
170
Thanks for the clarification. Did they sand/paint the door mouldings in place or did you end up buying some primed mouldings for the m / msport?
      03-17-2016, 06:05 AM   #51
saleen01
Drives: 2011 x5
yes i bought the m sport...made life easy
      04-26-2016, 09:15 PM   #52
peloterogq
Drives: bmw x5 50i
Hi everybody how I can get the size kit what is the par # please
      05-03-2016, 11:54 PM   #53
Deftronix
170
Hey Saleen - Could you do me a favor and post close-up pics below the skirts? I would like to see how they aligned them. Whether its the same alignment used on the skirts the trim were meant to be mounted to or if they pulled them out for better alignment. Do you happen to know if they ended up cutting off the alignment nipples on the top edge of the trim and just used the 10 c-clip/bolts + mount tape to secure or did they drill holes for the nipples too (absolutely no room for error)?
I am working on making a template right now off the side skirts that the trim were meant to be mounted to(w/holes already drilled) but this will get interesting due to the curved surfaces. Built up a couple layers of painters tape over the whole surface, punched holes and marked for alignment grooves at the edge so I can properly align the template when transferred to the other piece. Layering it up should make it transferable without stretching or distorting but the slightly different curve could prove to be a disaster. Which is why I am leaning towards cutting the nipples off the trim and just using all the other mount points instead which will allow me to have a little more wiggle room without the risk of having an exposed hole on running board due to a very slight misalignment. Thoughts?
Anyone have recommendations for making a better template? Sorry for the long winded post.
      05-05-2016, 10:05 AM   #54
saleen01
Drives: 2011 x5
90% of the skirts line up...the 2 ends need to be pulled tight...little brackets were made to pull them as tight as possible and then an eith of an inch bead of silicone was used...about 2-3 inches of it....my truck is black ..you don't notice it at all..
we cut off alignment nipples and free handed everything...
the used c-clips, no glue at all....
my advice is to cut the nipples off...and feel your way to an optimal fit
do everything off the car...makes it easier
guild the skirts by feel...you'll see the optimal fit
you need two people to do this ....gets awkard...
      05-06-2016, 09:42 PM   #55
Deftronix
170
Thanks for the additional info Saleen. Was really trying to avoid cutting the nipples off in case I wanted to go plan B and just use the skirts that were meant to be used instead of the running boards but seems impossible otherwise.
Good to know that the two ends dont fit perfectly, makes me lean more towards not cutting anything and just buying the proper supports and using the skirts instead. Decisions.. decisions..
Anymore pics?
      10-03-2016, 12:22 AM   #56
jplatt83
14
Drives: BMW 2011 x5 35d
Would like to see the final pics too since Im still trying to decide whether to attach them to the running boards or skirts but leaning towards the boards. Rockers are in route anyway. Just finished up the front/rear install:
Where did you get your black license plate frame from? Very subtle and clean looking
      10-07-2016, 10:08 AM   #57
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
CA DMV. Legacy plate program.
https://www.dmv.ca.gov/portal/dmv/detail/legacyplates/index
      10-07-2016, 10:10 AM   #58
jplatt83
14
Sorry not the plate itself. The black frame around the plate.
      03-06-2017, 09:51 AM   #59
ayegconron
ayegconron's Avatar
Drives: 2013 M5
Originally Posted by nigxdoof View Post
Second, There is no PDC harness / holder on this. I was sitting there for 20 minutes trying to figure out what to do. I decided to just use some 3M double sided tape to attach it on and have it not move at all.
Those are the two main things that really pissed me off. Once those were out of the way, everything was smooth sailing. Sort of. Since I didn't have instructions, I wasn't sure what to do. Luckily, someone on the forum was able to post pics and somewhat of a DIY. It helped a lot.
Bringing this thread back to life. nigxdoof, I also got the rep kit but the front lip portion only. As you said, it does not come with a PCD harness/holder or hardware. Literally just the lip in the box. With that being said, how did you mount it? Drill directly into the bumper and use 3m tape on the middle section to hold it to the car? Any help is appreciated, thanks.
'13 M5, Alpine White/Black full leather interior
Instagram: @ayegconron
      03-15-2017, 08:48 AM   #60
sirdaft1
sirdaft1's Avatar
2203
Drives: X5 & E90 WTCC Widebody Racecar
Those tips look really clean. Which tips did you go with? And curious what is the diameter of the inlet and outlet piping?
      03-15-2017, 12:07 PM   #61
Deftronix
170
It is a gloss carbon fiber frame but cant find this particular one anymore but there are definitely alternatives out there.
Thank you, I think they fit the truck perfectly! It's the supersprint 120mm kit. Took a month to come in but worth it. Cut the OEM piping couple inches before muffler, use new hangers and clamp on. The piping is 3" and flared to the tips edge. I believe this kit only works with the diesel oem muffler, otherwise you will need their catback without custom piping.
      03-15-2017, 11:29 PM   #62
sirdaft1
sirdaft1's Avatar
2203
So it's a full muffler replacement or only replacement tips That you used? Just want to make sure I'm understanding you correctly.
      03-16-2017, 12:29 AM   #63
Deftronix
170
I see in your profile you have a 35i. You would need the mufflers and tips to work unless you did something custom. Since I have a diesel the tip kit lines up with the oem muffler outlets so I was able to get away with buying just tips.
      02-01-2018, 02:11 PM   #64
saleen01
Drives: 2011 x5
does anyone know who stocks the aero kit, i just need the front lipped, cracked mine unfortunately and i can't remember who i bought the kit off in germany
      02-01-2018, 04:48 PM   #65
Googone20
Googone20's Avatar
176
Drives: 2015 X5, 2007 M6
I bought my kit from ECS Tuning. Does anyone have the part number for those Supersprint 120mm tips?
2015 BMW X5 35d Msport Carbon Black/Mocha Nappa
2013 Cadillac Escalade Platinum Diamond White Pearl/Cocoa
2007 BMW M6 Sapphire Black Metallic/Black
2005 Ninja 636 Lime Green
      02-02-2018, 09:05 AM   #66
saleen01
Drives: 2011 x5
having a tough time sourcing just the front lip.....ECS can get it, but comes from germany....shipping is triple the worth of the part
