TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Photo/Video/Audio Gallery
      01-09-2023, 04:20 AM   #1
Sophisticated Redneck
1416
Drives: 2012 BMW X5 50i
New Intake Design Pics
Been working on this for about a year, getting very close to release version. Coming out for the M, 50i, & 35d. Will make 35i version too if enough demand. Massive difference on the 50i, was stuck at 515hp with stock intakes + stage 2 tune, downpipes & JB4. With new turbo inlets & intake power bumped to just a bit over 600hp and dropped 0-60 to 3.6 & 1/4 mile to 11.7. This is on a engine/transmission with 185k miles and no launch control.
Appreciate 7
XRatedM136.50
argento538.00
askjeeves147.00
RL18273.50
TTV8M122.50
      01-11-2023, 06:52 PM   #2
argento
argento's Avatar
538
Drives: 2013 X5M
Gorgeous work! As usual…
      01-12-2023, 01:17 AM   #3
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Love it
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      01-15-2023, 06:00 PM   #4
Tundraguy
10
Drives: 2006 Corvette Z06,2008 tundra
Are these going to be available for purchase?
      01-17-2023, 10:36 AM   #5
xJonRx
14
Drives: '13 E70 X5M
Count me in for an S63 set. These look amazing
Appreciate 2
      01-18-2023, 03:40 PM   #6
1416
They sure are and very soon, getting everything lined up for production as we speak. Have few members who already pre-ordered I will be making for first and then will start taking more orders once those are in production. These are quite expensive and time consuming to make, M version will be cheapest as it doesn't need turbo inlets at 600 and the 50i version will be 700. Comes with full lifetime warranty as I stand behind all of my work. Will post more details as I get closer to launch for those interested.
      01-18-2023, 03:43 PM   #7
1416
Thanks!
      01-21-2023, 10:38 AM   #8
dew62
Drives: x8m
in for the M version
      01-24-2023, 01:35 AM   #9
1416
Thank you Argento! That means alot coming from you as your attention to detail is impeccable!
argento538.00
      01-24-2023, 01:37 AM   #10
1416
They sure will be, I will be making a formal announcement before the end of the month when I am ready to take more orders. I am finishing up the latest tweaks to the production of some pre-orders and also going to have full flow bench data and have more performance numbers on how it compares to the stock intakes.
      01-24-2023, 01:38 AM   #11
1416
Thanks! Will PM you both when ready to go into production and also make a an announcement on the forums.
      02-09-2023, 09:28 AM   #12
dnmcguire11
Drives: 2010 BMW X5M
2010 BMW X5M  [0.00]
Count me in!
Count me in as well. Looking for something new for my 2010 S63. Great looking product. Will this retain the rear OEM engine cover as well or will both the front air box and rear engine cover need to be removed for this to fit?
Thank you.
      02-27-2023, 08:20 AM   #13
1416
Thank you for the interest everyone, here is an Update: With the new addition of a CNC mill, I can now build fixtures that will allow me to print the air filter boxes much more efficiently with less material wasting supports and labor involved. This has delayed my roll-out but it is for the best and will vastly improve the quality of the intakes & strength making them virtually bulletproof.
I will also be using the mill to produce a complete CCV/Catch can solution for the M & 50i that will allow the use of clean -AN lines and fittings that will compliment the intake for the M & 50i and completely eliminating the need to use the stock plastic corrugated CCV lines that were always failure prone. If the CCV lines are an issue on the 35i & 35d I will also develop separate solutions for those platforms. Will update this thread as more progress is made, getting the new mill dialed in & setup now.
Appreciate 2
      03-12-2023, 07:12 PM   #14
Tundraguy
10
Please let me know when you have x5m intake pipes and turbo inlets. I'll buy them asap. My ccv is failing and I want to do catch cans.
Do you happen to know if I delete the ccv pipe to the turbo inlets and just run a catch can on the rest of the ccv , would that cause any issues?
      03-17-2023, 11:53 AM   #15
Bob H
Drives: E70 X5 diesel
I would love to see the mockup pics for the 35D - even if just a digital pic. Interested to see how you take the single inlet on the side up into this setup. As I said, I'm in for the first set!
-Bobby
      03-18-2023, 06:07 PM   #16
black_beast
Drives: 12' X5M, 05' 4.8is, 18' GLE350
I've purchased several unrelated items from OP and I can attest to an honest seller with quality products, this is an awesome alternative to the overpriced monopoly product by RK
      03-18-2023, 07:15 PM   #17
0-60Motorsports
Bahrain
792
This is going to be a Great product! I can’t wait to receive my X5M intake
Current Mods:
IG: @060Motorsports
      03-20-2023, 09:06 PM   #18
1416
ETA is Mid-April, will update this thread as we get closer and I am ready start taking orders. As for the CCV, on the E70 50i & X5M the CCV is a complex two stage system, the M further complicates this by adding cross-bank connections.
The Lower CCV lines run direct to the lower intakes that see both full vacuum and boost, under non-boost conditions, the lower CCV lines are used to vent all Crank Case gases. Under boost conditions, an small internal check valve switches to just the turbo inlet connections as otherwise boost pressure would flow into the crankcase.
You can technically block off the lower CCV lines and eliminate the cross-bank connections (this what BMW itself did on the TU update to the s63/n63 platform) and just use the turbo-inlet CCV connections. The turbo inlet connections must stay however as under boost conditions, this is the only place to vent the CC gases. You could also vent to atmosphere or into the exhaust via evac tubes but trust me when I say, the smell is absolutely horrible and is not tolerable for street use.
I did several write ups on converting to catch-cans, PM me for more info on how to setup.
      03-20-2023, 09:08 PM   #19
1416
-Bobby
You bet, will post some up soon. Also working with a fellow forum member who has a 35D for final performance and fitment testing on the 35D and will post up pics and performance data once he has his prototype for testing.
      03-20-2023, 09:09 PM   #20
1416
Thanks Beast! =)
      03-29-2023, 01:57 PM   #21
0-60Motorsports
Bahrain
792
Looking forward to it!
Current Mods:
IG: @060Motorsports
      04-14-2023, 06:58 AM   #22
1416
Update: I have finished the setup and install of the new CNC mill that I will be using to make a few parts for the intakes: Mounting brackets, screw bosses, & most importantly the fixture plates that will allow me to manufacture the intakes in single piece prints with superior strength & quality that will last the lifetime of the vehicle.
To dial in the mill and get it ready for production, I made up a simple test project: The M paper weight (or pet rock 2.0 lol). This was the very first cuts made on the mill and it turned out exceptionally well. I am going to make up a few more of these as I continue to get everything dialed in and the mill ready for the intake production. I will include one of these with every pre-order of the intakes just as a fun freebie .
Expecting to begin intake production in a about a week, will update again as we get closer.
Appreciate 4
