BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Using bimmercode for the first time today...
      01-28-2021, 07:43 AM   #23
rounderman
148
Drives: 2019 X2 M35
2019 BMW X2 M35  [9.50]
glad it worked for you. Have fun and keep us posted
      01-30-2021, 12:23 PM   #24
Glen e
Retired from BMWNA
198
Drives: ‘21 X2 m35i
I like this you tube for beginners:
Glen
Ft Lauderdale
'23 228i GC
      01-30-2021, 10:24 PM   #25
Glen e
Retired from BMWNA
198
Drives: ‘21 X2 m35i
Ok, I’m done...my codes:
- [ ] Auto start stop remember last position from shutdown
- [ ] Restart volume on the audio to 30%
- [ ] Automatically fold the mirrors as soon as I lock the car
- [ ] Cancel seatbelt indicator and the gong for the driver seat
- [ ] Completely kill the seatbelt gong on start up
- [ ] M display on I drive on start
- [ ] Kill startup warning on I-drive
- [ ] Display full text messages
- [ ] Ringtone smartphone tone
- [ ] Rear Daytime running lights -outer part
- [ ] Brake force display-weak/30km/hr
Glen
Ft Lauderdale
'23 228i GC
      01-30-2021, 10:49 PM   #26
xPhantom
Eurowerkz
xPhantom's Avatar
Drives: 2003 BMW M3, 2020 BMW X2 M35i
I've been trying to see if I can enable screen mirroring via Bimmercode. I've gotten as far as having the menu option appear, and then getting it to say "Activating vehicle Wi-Fi..." but then it hangs and nothing ever happens. I was bummed because I was reading all the successes people have had with enabling it on other models.
2003 BMW M3 | 2020 BMW X2 M35i
Instagram | Flickr
      02-12-2021, 02:14 PM   #27
dago65
Italy
Drives: BMW X2 20i MX Sdrive
Originally Posted by trnguyen View Post
I have an 2019, but I got the ECU updated in December and Bimmercode worked correctly after, even in Expert mode. I have pretty much the same list and 2 other things that I really want:
If you want to leave the car running and lock it, you might want to disable the horn when you lock the car. It's kind of annoying and draw attention for nothing.
Also, I don't know if it's the same for the US version. Mine in Canada has the lights on automatically, even if the switch is at the position "0". I want to be able to turn it off like when I wait for my kid at school around 4pm in the winter. This one is in Expert mode, but easy to do.
could you explain me how did you set the lights off to 0 with bimmercode in expert mode?
Thanks and bye
      02-12-2021, 10:31 PM   #28
trnguyen
76
Drives: BMW X2
Thanks and bye
It is under "Body Domain Controller > 3068 LceMaster > FLC_Aktiv". Set the value to "freigeschaltet_in_Stellung_A"
1. Go in "Body Domain Controller"
2. Enable "Expert mode"
3. Go in "3068 LceMaster"
4. Search for "FLC_Aktiv"
5. Set the value to "freigeschaltet_in_Stellung_A"
6. Back to "Body Domain Controller" menu and code your changes
On mine in Canada, with the switch to 0, the front Daytime Running Lights (angel eyes) are still on. If it's the same for you and you want all lights completely off, you will need to enable the DRL setting in the iDrive menu to turn off the DRL. This one doesn't require expert mode. I don't recall in which menu it is.
dago651.50
      02-13-2021, 05:05 AM   #29
dago65
Italy
Many thanks for your availability and for the accurate explanation.
Greetings to everyone from Italy. (We have a wonderful car)
      02-13-2021, 02:48 PM   #30
trnguyen
76
Drives: BMW X2
You're welcome.
Fully agree about the car, but cannot enjoy it much with Covid-19 situation.
      02-25-2021, 07:50 AM   #31
Darren-Cookson
Drives: BMX X2 xDrive
Can you explain how to do the Lights off
Hi, I dont like this feature of them always being on, Can you explain in what part of the expert mode you can change this please?
Thanks
      02-25-2021, 10:12 AM   #32
trnguyen
76
Drives: BMW X2
Thanks
The screenshot in the post #30 above gives you a visual of it
      02-26-2021, 04:04 PM   #33
Glen e
Retired from BMWNA
198
Drives: ‘21 X2 m35i
Here’s an interesting situation, we’ve said that there are many alarms and alerts that go off after you’re done coding, they go away as soon as you instantly restart the car. But here’s one that lasts a bit longer: if you decide you want your AC climate control display to be orange instead of white, the AC indicator light will flash and you can’t Turn off the indicator light nor can you turn off the whole climate control system. It keeps flashing through two or three restarts of the car, and seems to go away after about 5 to 7 minutes by itself. I coded it back-and-forth twice as I didn’t really understand the switch, so I know it goes away.
Glen
Ft Lauderdale
'23 228i GC
      02-27-2021, 11:51 PM   #34
tesmithp
Drives: 2019 X2 M35i
Originally Posted by Glen e View Post
Here's an interesting situation, we've said that there are many alarms and alerts that go off after you're done coding, they go away as soon as you instantly restart the car. But here's one that lasts a bit longer: if you decide you want your AC climate control display to be orange instead of white, the AC indicator light will flash and you can't Turn off the indicator light nor can you turn off the whole climate control system. It keeps flashing through two or three restarts of the car, and seems to go away after about 5 to 7 minutes by itself. I coded it back-and-forth twice as I didn't really understand the switch, so I know it goes away.
When I last did that two days ago, a warning popped up saying I needed to let the AC recalibrate for a few minutes (blinking) and to avoid engine RPMs over 1500. I did that and the blinking stopped after about 1-2 minutes.
      02-28-2021, 03:39 AM   #35
Glen e
Retired from BMWNA
198
Drives: ‘21 X2 m35i
interesting, no warning here, just a blinking ac light for 5 min....my car was idling the whole time...Also, it now only seems to be orange when I have the lights on at night, during the day, it reverts back to white? In retrospect, I don’t think I’d make this coding change again.
Glen
Ft Lauderdale
'23 228i GC
      02-28-2021, 08:37 AM   #36
xcelir8bmw
xcelir8bmw's Avatar
402
Drives: 2022 BMW M240ix
interesting, no warning here, just a blinking ac light for 5 min....my car was idling the whole time...Also, it now only seems to be orange when I have the lights on at night, during the day, it reverts back to white? In retrospect, I don't think I'd make this coding change again.
That's default for me.
      02-28-2021, 09:31 AM   #37
Tarekith
Tarekith's Avatar
48
Drives: BMW M35i
Indeed. A lot of the controls in my M35 are white during the day and orange at night. The needles on the speedometer and tach for instance, just noticed that last week.
2020 M35i
      02-28-2021, 09:50 AM   #38
Glen e
Retired from BMWNA
198
Drives: ‘21 X2 m35i
OK then ignore all my postings. If you choose active, it means white during the day, orange at night, if you choose not active, it means white all the time. I was hoping by changing it from the default it would be orange all the time and I don’t think that’s possible. At least in the non-expert settings
Nevertheless, the original point still stands, this is the only coding change I’ve seen where the alert/error doesn’t clear with a restart ,it happens a bit later.
Glen
Ft Lauderdale
'23 228i GC
      03-01-2021, 09:55 AM   #39
rice_rocket88
Drives: E60 F48 F39
Hmm so which option are we talking about here? I was thinking in my mind that why did BMW CHANGE the way things worked on my car vs all my other cars? The needles etc are white for me at night which makes it a little "too bright" same with on the HUD. So which option are we talking about to make it flip back to orange at night?
      03-01-2021, 10:17 AM   #40
Glen e
Retired from BMWNA
198
Drives: ‘21 X2 m35i
If you choose “Active” as the code, the climate display will be orange at night (I think)....
Glen
Ft Lauderdale
'23 228i GC
      03-01-2021, 11:43 AM   #41
rice_rocket88
Drives: E60 F48 F39
Sorry.. but is it in the body domain for ac control colors? That's the part that gets foggy for me when I was following the thread. It seems maybe that the 2020's might have had it change. Tarekith can you confirm if it's just the a/c controls and speedometer, or does it also include the HUD? I don't want to go messing around if it won't do me much good
      03-02-2021, 05:46 PM   #42
rice_rocket88
Drives: E60 F48 F39
Nevermind.. just getting out of work late.. My ac and the needles are orange..I was hoping for the hud lettering to go orange too.. or the background of the needles to change orange.
      03-02-2021, 06:11 PM   #43
trnguyen
76
Drives: BMW X2
Now you guys make me wondering. I never paid attention about it so far. I have to check on mine...
      03-02-2021, 06:37 PM   #44
rice_rocket88
Drives: E60 F48 F39
On our '16 X1 everything including the hud changes to orange which is much easier on the eyes. The white display on the X2 is sharp, but unnecessary since it's way too bright even I go to the very dark and residential around my house.
