BMW X5
      03-07-2024, 11:06 AM   #67
Ninefourteener
Ninefourteener's Avatar
1365
Drives: 2020 X5 M50i, 2020 Alfa 4C
Man..... this thread really did get hijacked! LOL
That's ok, there's lots of useful info in here. I haven't re-read this thread in a while.
Originally Posted by dentprotony@gmail.com View Post
OP how are your brakes holding up ? What are you running for rears ?
Front brakes are 100%. No issues, no problems. Still working great after a few years now. I do have to periodically lube the clips and pins.... that helps with squealing.
Brakes are back OFF the car now. I removed them to trade the car in.... only to later change my mind, and keep the car.
So..... starting from scratch. Calipers are getting refinished in red.
Wheels are getting re-powder coated in satin black.
I'm going for a new look.
In the meantime..... I'm buying a rear BBK in red..... from you..... to match the fronts
2020 X5 M50i, Alpine, B&W, Air Susp, anthracite, coffee, **CD player**:
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342
blau3er1160.00
      03-08-2024, 10:55 AM   #68
rantarM3
205
Drives: E90 M3
Ninefourteener and dentprotony@gmail.com, did you guys look into whether the bias would change with these brake upgrades? With 6 pistons and a larger pad up front, would you not be biasing breaking even more to the front than stock? I'm just wondering whether there might be unintended issues from the upgrade, especially with ABS and DSC.
      03-08-2024, 11:39 AM   #69
blau3er
1160
Drives: F31 30d
I think you are worrying about nothing here.
This set up is factory fit on the F95 which is built upon the G05 chassis.
Any changes will be minimal and likely the same sort of outcome as anyone fitting an aftermarket BBK.
On my own car for example (F31) I have fitted 400mm 6 pots and 380mm 4 pots and the braking is better than the factory set up (which was factory fit M Sport brakes) with zero noticeable ill effects to braking bias.
      03-11-2024, 03:00 AM   #70
Ninefourteener
1365
Yea... I noticed absolutely ZERO change in how the brakes felt after installing 6-piston brakes up front, and keeping the rears stock.
I've been on them a couple years now. It was purely aesthetic for me.
The rears? I expect will be similar. I don't expect the car to behave any differently.
The only "adverse" thing I noticed, is that 6-piston X5M brakes tend to squeal quite a bit more. The solution is to clean and lubricate the clips and pins.
blau3er1160.00
      03-16-2024, 01:21 PM   #71
417
Drives: 2018 f85
I will have to calculate brake bias for the dual caliper kit, but i am confident it will be within 10% from stock, which considering that rears only do 25-30% of stopping will not be noticeable, but the pad will be larger, and aesthetically will match the front calipers 100% better.
      04-30-2024, 11:31 PM   #72
djrabbi
djrabbi's Avatar
728
Drives: G05 M50i
If anyone wants. I can get you a set with 405MM rotors and 6 piston BREMBO’s with matching rears for $3000shipped.
      05-02-2024, 05:35 PM   #73
417
Drives: 2018 f85
Please post a few pictures, im sure many would be interested. Also please post weight of the rotors, and do you know if 19” spare wheel would clear your brakes, thanks!
      05-02-2024, 05:43 PM   #74
djrabbi
djrabbi's Avatar
728
Drives: G05 M50i
Here you go of a customers setup.
      05-02-2024, 05:59 PM   #75
blau3er
1160
Drives: F31 30d
Assuming these are the Chinese made Alibaba "Brembo" GT6 & GT4 calipers?
      05-02-2024, 07:06 PM   #76
djrabbi
djrabbi's Avatar
728
Drives: G05 M50i
No they are used calipers and will have all brembo stampings
Alibaba is sadly killing the market but oh well. I usually sell to e92/e46 people. I rarely sell to SUV guys but option is there
      05-05-2024, 01:51 PM   #77
blau3er
1160
Drives: F31 30d
The Alibaba ones have all of the stampings, sadly the market for Brembo GT6 and GT4 calipers is now mostly people buying Chinese fakes!
Brembo do not sell the calipers on their own, the only way to get genuine ones is as part of one of their complete kits, so thats an easy way to tell most of the time!
You are also right that the market is dead because of this - there will be loads of people driving round with fake brakes, thinking they've bought cut price, but legit Brembo's for their car.
djrabbi728.00
      05-05-2024, 03:35 PM   #78
djrabbi
djrabbi's Avatar
728
Drives: G05 M50i
Yup. Mine are used from the Porsche usually and def used calipers.
      05-05-2024, 08:30 PM   #79
417
Drives: 2018 f85
Will these fit 20” factory wheel or 19” spare tire ? Also can you provide weight for front/rear rotors ? Thanks
      05-05-2024, 08:33 PM   #80
djrabbi
djrabbi's Avatar
728
Drives: G05 M50i
Will fit under 20s but 19s spare it won’t unless you go smaller rotor
Each rotor depends on its size
