Go Back   7Post - 7 Series Forum > BMW 7-Series Forums > (G11) 7-series General Discussions
      02-04-2022, 04:33 PM   #1
proel
Drives: e46 e65 f30 a7 a6 a8 g12
750i original exhaust modification
Hello everyone, new owner of g12 750i, i have stock exhaust not m and i want to make it louder and deeper v8 type sound, my last car was audi a7 3.0 tfsi, i did electrical valves behind rear mufflers and car sounded very deep and not to loud but not to quiet either (3x sound as stock). With g12 i have watched all youtube videos and read many threads on internet but cant decide what to delete: resonator or make flaps behind rear mufflers ( same as muffler delete ), looking for help from members who have did this muffler or resonator delete thanks and goodbye.
my a7 sound: https://youtube.com/shorts/bdWhHcjooZ4?feature=share
      02-04-2022, 06:37 PM   #2
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
814
Drives: 2013 BMW M5 | MSR Stage 3
I replaced the entire system with a new custom setup. Removed stock system and did 3" straight pipe from downpipes to custom X and from X to race mufflers. You can use Vibrants 1794 I thinks.
I'll see if I can upload a video I took which is better.
Videos don't do it justice. It sounds sick and 0 drone which was my goal. I came from an M5 and hellcat and wanted the 7 to be a little more alive.
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
      02-06-2022, 10:09 AM   #3
Nkbm82
Nkbm82's Avatar
75
Drives: 2018 BMW 750i
I removed the resonator and installed an x-pipe and the sound change is minimal.
      02-16-2022, 02:14 PM   #4
proel
will try do do muffler bypass
      02-17-2022, 01:59 PM   #5
red-lynx
Drives: 2016 750i XDrive
Everything that I've seen so far, is if you want to change the sound, remove the muffler all together. not a whole lot of mods I've been able to find. But here's a link to a straight piped 750. Linked it to where they show the muffler delete, but earlier on they do just the 2 resonator removal with an X pipe.
      02-17-2022, 02:27 PM   #6
proel
in this video its m550i but i think exhaust system should be similar and look what sound he gets with just middle resonator delete
      02-17-2022, 03:55 PM   #7
red-lynx
So that's what I was saying, earlier in that video I posted, is of just that, both resonators removed. They then later in the video just remove the muffler.
      02-18-2022, 01:01 PM   #8
g12newb
12
Drives: 750Li
Removing resonators and mufflers at the same time will cause lots of drone.
I seen the video of the straight pipe 750 and I don't think the guys doing the jobs are reputable.
An exhaust tech should know before hand how a twin turbo engine would react to a resonator delete and a muffler delete.
Best option which is probably the most expensive option is cat-less downpipes and an X pipe instead of the resonator while leaving stock mufflers on.
This gets expensive because of the added tune you would need to hide the check engine for the O2 sensors but you get non restricted airflow and pure turbo spool with the aggressiveness in sport mode.
I have catless DP on now with everything else stock and it sounds great. Thinking do to the X pipe now instead of the resonator.
      02-20-2022, 09:54 AM   #9
13M5F10
13M5F10's Avatar
814
I kept stock downpipes and went with a custom full exhaust on my G12 750i. Sounded amazing and no drone. X Pipe to aftermarket mufflers.
      02-20-2022, 11:25 AM   #10
g12newb
12
Drives: 750Li
What brand mufflers did you get?
Only reason I'm not switching from the M muffler is because of the valves and the way it sounds in sport mode. Sounds too good during downshifts. Did you have the M muffler too stock?
      02-20-2022, 11:27 AM   #11
13M5F10
13M5F10's Avatar
814
I didn't have M mufflers and I went with a custom setup from Kinneys Muffler shop in Watauga, TX. I would highly recommend replacing stock mufflers with Vibrant Race Mufflers which are similar to Kinneys. I had them in my Hellcat Charger and F10 M5. Sounds amazing.
      03-07-2022, 07:42 PM   #12
g12newb
12
Drives: 750Li
I have the M muffler as well that's why I didn't change it. From what I have gathered is that the M muffler makes a huge difference in sound.
My car too sounds great at downshifts in sport mode and can be quiet in comfort.
I assumed all G12's came with the M mufflers TIL
      03-07-2022, 08:05 PM   #13
g12newb
12
Drives: 750Li
This is the video I was talking about before:
IMO that G12 sounds horrible.
Important to note that he doesn't have have the M muffler on it.
      04-25-2024, 09:58 AM   #14
HardcoreTuner
No_Country
Drives: 2019 BMW x7 xDrive50i; 2016 75
Anyone know the part number for the M muffler? My car has the M package but using BM3, I'm not convinced my car has valves on the muffler. I bought it used so won't be surprised if someone swapped the wrong part after a repair or something. High Flow cats didn't make nearly any change in sound. My x7 saw a huge improvement with same cats.
7post
