03-25-2018, 04:05 PM | #1 |
13
Rep 29
Boot space
The boot space of the VW Tiguan is 615 litres but that is with the sliding seats forward.
Now the boot space of the X1 is 505 litres but is that with the sliding seats adjusted fully forward if not then it must have a similar capacity of the Tiguan |
03-30-2018, 02:37 AM | #2 |
Όλα ρόδες
760
Rep 559
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
No it's 505 litres with the seat adjusted all the way back.
01-30-2020, 03:48 AM | #3 |
Rep 10
If you have the sliding seats the trunk space is a little bit smaller.
I have seen this difference from the floor mat which I ordered for the trunk. By mistake I ordered the floor mat for the car which does not have sliding rear seats. And that mat was like 3 cm longer than the one which is I needed. So with sliding rear seats all the way to the back, the trunk space is 3 cm smaller. (in length) |
01-30-2020, 07:57 AM | #4 |
163
Rep 334
I'm looking around at potential replacements for the X1 at some point, and boot/trunk space is a factor due to our requirement to squeeze two dogs in the back... I'm not clear on whether the quoted "505 - 1550 litres" in the handbook include the space *under* the boot/trunk floor as well, or just the more useful space above. Does anyone know for sure, as I want to compare like-for-like? I'm using this site as a guide:
https://www.automobiledimension.com/compact-suv.php Last edited by CliveL; 01-30-2020 at 09:42 AM.. |
01-30-2020, 04:26 PM | #5 |
129
Rep 419
Your dogs are measured in liters?
I would assume it's 505 with the seats up and the floor space covered. You might want to measure for a crate though (instead of going by volume). They'd be a lot safer in one, in which case it's all about geometry. Or consider a grille, to keep them from going over the seat. |
