BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Transmission Error
      05-25-2020, 02:53 PM   #133
StefanJ
StefanJ's Avatar
68
Drives: BMW X3 G01 xDrive 20d
Originally Posted by jamessfarnell View Post
How to fix this issue, guide attached.
Good luck.
Excellent guide, congrats!
I hope that more owners will fix their error using the guide and will not accept to pay to BMW for a new gear selector.
Regards!
      05-26-2020, 02:04 AM   #134
Fuzzzy
Romania
Drives: BMW X1 F48 20d
Great job!
      05-26-2020, 02:08 AM   #135
coxmix
Drives: F48 2016
Originally Posted by StefanJ View Post
Hi,
I have the same strange behaviour starting from yesterday.
I went to a BWM garage repair shop and they told me that they can try to reset all the computers of the car - this may help. If the error will not disappear, then they should replace the mechatronic unit of the gearbox (and this is a very expensive repair).
Did you found the cause of the errors ?
Ștefan,
Did you repair it ? If yes can you tell me where and how you did it ? I am also from Romania. Thanks!
      05-28-2020, 03:30 PM   #136
StefanJ
StefanJ's Avatar
68
Originally Posted by coxmix View Post
Ștefan,
Hi coxmix,
I didn't repaired it. I changed the selector gear with an already repaired one.
But you better use the instructions from above in this thread and you will fix it yourself. You will save a lot of money.
Regards,
Stefan
      06-03-2020, 05:09 AM   #137
celik
Drives: bmw x1 f48
Just to thank your friend for a great guide. i managed to make, i just unwound the old spring one lap to extend and now everything works flawlessly. Thanks again.
      09-14-2020, 03:44 AM   #138
Bmwforlife?
Thanks James!
Good luck.
I used your guide and it worked! Minor difference in my car were 3 cables going to the arm rest for a cell phone docking accessory. It was a lot of work to get to that little spring. I wish I could just buy a new spring rather than adjust the broken one. I hope it doesn’t break again. It took me a long time to do everything, but it will be much faster if I have to go back in again. What a pain for a tiny little spring!
An improvement to your guide would be with your step 10 on removing the gear selector unit. All you gotta do is turn the unit over and align the gear to line up the semi-round clip to the hole at the bottom. Once aligned you need to push the semi-round clip through from the bottom using a small screwdriver like the jeweler’s flathead. I hope that helps others attempting this.
Another minor improvement would be to move the passenger seat prior to disengaging the battery for the second item of step 4.
Thanks again, James!
      09-14-2020, 04:39 AM   #139
hongkongloftus
hongkongloftus's Avatar
Hong Kong
17
Drives: 09/2016 X1 F48 18d
Good luck.
Dear Jamessfarnell
Great job and thank you very much.
      09-14-2020, 08:13 AM   #140
mrexcuse
34
Drives: Tiguan, M2 Comp, 330 Touring
Good luck.
The Guide was great, Here are some more photos to help fill in some of the missing photos and some other ideas for how it is done. I had the duct work in my F48 so you can see how that is installed as well.
After I reset the spring and plugged everything back in notifications disappeared. No reset was necessary and no coding was necessary. For reference it failed for me at around 115k kms I think.
Thank you again!
Shipa17.00
      10-04-2020, 02:17 PM   #141
RandomFactoid
Drives: F48 2.5D
Has anyone found a replacement spring instead of reusing the old one ? Started getting this error today
      10-05-2020, 03:26 PM   #142
mrexcuse
34
I couldn't find one easily for this. I wish I measured the spring but was running out of time. It is easy enough to uncoil and re-use.
One thing I should add is that when my error started to come up it was noticable more difficult to move the shifter periodically. This was because the white component with the spring mounted to it wouldn't be where it needs to be to allow for a smooth movement.
I'm assuming you are out of warranty?
      10-05-2020, 05:08 PM   #143
ryan-77
X1 in Canada with the same issue
Hi there,
I am currently in dispute with my 3rd party warranty trying to get this part covered.
They are claiming this is not an internal component of the transmission.
Anyone else have experience with this? Any chance anyone has a transmission diagram that I can show them to further prove my case?
Any assistance is greatly appreciated. I am being quoted $1400 CAD for the repair without warranty.
      10-05-2020, 09:15 PM   #144
mDrive2
Drives: x1
Vin: WBXHT3C39G5F65206
Mileage: 50,100
Email: allextim.at.hotmail.com
      10-06-2020, 07:56 AM   #145
mrexcuse
34
Originally Posted by ryan-77 View Post
Hi there,
Unfortunately it is just a selector for the transmission and is not internal to the transmission components. You can argue that if the selector is malfunctioning there is a risk that the transmission will also not work. In addition there is a risk that the warning holds a vehicle rolling risk that could lead to injury or death. Maybe even allowing the vehicle selector to go into park or reverse while in motion (likely electronics to protect from this but I am not sure).
The fix works and instructions are quite detailed as a last resort. Good luck!
      10-07-2020, 11:02 AM   #146
mDrive2
Drives: x1
I just got a quote from a local BMW dealer:
$900 for the gear selector assembly
5hx$150 labor
the decision is obvious, I'll do it myself
      10-07-2020, 11:54 AM   #147
mrexcuse
34
5hx$150 labor
There are rebuilt gear selectors available on ebay as described previously, but they may require coding to get working. The spring fix described in the write-up does not require any coding and all error codes go away.
      10-08-2020, 01:12 PM   #148
link_sy
Drives: X1 F48
Can you tell us how? Please?
We asked several times but haven't received any feedback. We have sent our mutual claim in November 2019 and the part was replaced under the Godwill programm. I could share the letter copy if you would give us your email.
Hi everyone
I had this same issue a while back and it disappeared by itself. I also created a thread on this without realising how much effort had gone on here. My car is also out of warranty and I'm a bit concerned It may come again. Can I get the letter too? Also the exact part number that was replaced. It may be worth keeping it in hand in case I need it for later
Thanks
      10-08-2020, 06:05 PM   #149
CYclonic
I have the same issue recently. My car is 2016 X1 F48 i20. I'm asking if the recall has any progress and how it could be repaired in Australia. I also asked if they can deal with the spring using the guide.
      10-09-2020, 04:13 AM   #150
jamessfarnell
South Africa
20
Drives: F48 X1 SDrive18D 2020
Thanks for the feedback - glad it helped!
PS - I dont have power seats, so moving the seat after battery was not an issue for my car.
      10-09-2020, 04:31 AM   #151
jamessfarnell
South Africa
20
Hello All,
Seems there have been a few replies since my fix:
I have taken mrexcuse feedback and added his notes to the guide. Credit is given - Thank you!
Here is the updated guide if you need it.
@Ryan-77 - You will not win this one with extended warranty providers.
CYclonic No recall on this part. (Maybe Goodwill claim if your BMW Dealer is nice to you)
File Type: pdf 2016 BMW X1 F48 - Shifter Fault v1.2.pdf (2.38 MB, 1141 views)
      10-11-2020, 09:19 PM   #152
CYclonic
Thank you jamessfarnell!
BMW Australia quoted a $264 diagnosis fee to start the conversation...
I would take the courage to try the guide method. It will be a HUGE life milestone for me if it goes well.
If anyone may find a replacement product number or eBay link would be greatly appreciated!
      10-12-2020, 05:36 AM   #153
mDrive2
Drives: x1
That's the one.
It took 6h to complete, including 2h to come up with a plan for how to fix the spring.
As suggested earlier, take lots of pictures when disassembling. It will be helpful on the way back.
@jamessfarnell and all - thanks for the quite detail procedure.
Cheers.
5hx$150 labor
      10-15-2020, 03:26 PM   #154
kmeyer75
Have the same issue with my 2016 X1, will try and follow the guide but am hesitant as I am not very mechanically savvy. If I am unable to do the repair immediately will there be any bad effects or is this something that I can leave alone for a while without causing further issue?
