06-14-2009, 03:01 AM | #1 |
242
Rep 735
Preping for storage...
I'll keep it short and to the point.
I'm leaving my M3 for 6 months. How should I prep it. Btw, I park in my condo garage, which is shared by other residences, so I can't use a trickle charger.
Current: BMW F32 435iA M-Sports; BMW E92 M3, M-DCT; Mercedes W221 S550 4matic; Ford Fiesta ST; Nissan Silvia S15 Spec-R Retired: BMW E93 323iA; BMW E85 Z4 3.0i, SMG; Lexus IS 250 AWD; Lexus GX 470; Mercedes W203 C230 Sportscoupe; Peugeot 206 S16; Peugeot 206 RC |
06-14-2009, 04:32 AM | #2 |
2159
Rep 5,623
put alittle extra air into tires, fill gas, clean interior and let dry, close all windows and sunroof and voila done.
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
06-14-2009, 09:32 AM | #4 |
755
Rep 4,649
everything mentioned above plus car cover should do the trick. make sure you fill the tank as opposed to leaving empty to avoid moisture getting in the tank.
06-15-2009, 07:55 AM | #5 |
17
Rep 478
I grabbed this list of s2ki.com. I don't know the original authors screen named otherwise I would give him credit...
1. Change the oil and filter, unless you are still within the “break-in” period (pre-3,750 or 7,500 miles). Let the engine run for a while. 2. Fill the gas tank to the top. You want the smallest air gap in the tank because temperature changes will cause condensation in there. The consensus seems to be that fuel stabilizers are NOT necessary. 3. Wash and detail the car including treating the inside vinyl and leather. Drive the car to remove any standing water that gets trapped in the nooks and crannies and to remove moisture in the exhaust and engine. 4. Run the air conditioner for about 10-15 minutes on the last drive to ensure all the moving parts get the lubricant circulated so the seals don’t dry out. 5. Clean out the interior really well, leaving nothing behind. Check all small compartments, ashtray, etc. Mice getting into the car can eat wires, vinyl, leather, carpet, etc. 6. Apply a silicone spray lubricant to door and trunk seals to minimize sticking. 7. Stuff a rag into the airbox intake to keep mice out. 8. Stuff a rag into the end of the tail pipes to keep mice out. 9. For those who are paranoid about mice, place several mothballs around the interior, placing them on small paper plates so they are not in contact with the car. Place several mouse traps around the car, bait them with peanut butter. 10. Spray lightly a bit of Febreeze (fabric deodorizer) on both floor mats. 11. Make sure the window wash fluid is the anti-freeze kind and not straight water. 12. Check the anti-freeze and adjust if needed. 13. Top off any other fluids under the hood. 14. Keep the CV joints in good shape by keeping the CV boots in good shape. When stored, the boots do not go through a regular routine of being flexed and this may cause them to develop a sort of “memory” such that when you drive it in spring, it may aggravate the start of cracking. You might want to consider going under there and liberally using some “rubber safe” silicone spray and get those (there are 4 on the rear half shafts) babies dripping wet with silicone. 15. Depending on how long you plan to store the car (more than a couple of months), you might also look into an “oil fog spray”. They sell these in auto supply stores. It is an oil mist that comes in a spray can, specially marketed for this application. Just before you put the car to bed, after your last drive, you take off the intake hose to expose the throttle body. You then spray this mist into the throttle body till the car begins to run a bit rough. Stop the spray and immediately shut the car off, replace the intake hose. This will keep a coat of oil film on all the internal engine parts so that the first start of next season will be less metal-to-metal wear. 16. Open up the battery cells and fill up with distilled water, NOT tap water. Tap water contains impurities that can shorten the life of batteries. 17. Pump the tires to about 45PSI to avoid flat-spotting. Place a piece of scrap carpet or foam insulation under each tire while parked. 18. Support the wiper blade arms with a rag to help maintain the rubber. 19. Put the transmission in reverse. 20. Roll the car ¼ to ½ turn 3 to 4 times per winter to ensure the rotors don’t stick to the pads. Work the pedals. 21. Keep windows down half way to keep condensation and moisture from collecting in the car. Do NOT set the ventilation selector to “re-circulate”. Leaving it selected to “vent/floor” will allow for air to expand and contract in and out of the car. 22. Keep the parking brake off to avoid having the pads rust to the rotors. 23. Sweep the garage floor and lay down a plastic tarp or park the car on linoleum. Concrete can get damp in the winter and if the car sits on linoleum or a tarp it will help to keep most of the moisture away from the car so the underbody does not collect condensation. 24. Disconnect the battery. Some recommend removal of the battery and taking it into the warmth of the heated house. Removing it will completely prevent electrolysis between the thousands of spots in your electrical system where it could occur. If you remove it, do not store it on concrete. Make sure you have the stereo code before unhooking the battery! Buy a “battery tender” which differs from a “trickle charger” in that it knows (has a chip in it) when the battery is fully charged and thus turns itself off. Two sources are: (http://www.griotsgarage.com/catalog.jsp?&SKU=77655 ) (http://canadianbiker.com/tender.html ) 25. Put a breathable car cover on. 26. DO NOT start the car unless you are going to drive it. When the car sits, all the oil drains into the oil pan. Starting the car is the hardest thing on the engine. Doing it once in the spring is better than several times throughout the winter. 27. You may want to call your insurance agent to suspend some of your insurance while the car sits in the garage. Rumor has it, if we have a nice day in the middle of winter and you want to take it for a drive you can call your agent and get coverage restored for the day. Call your agent to make sure this is an option with your policy first! 28. In the spring, start it up and let it idle until it's almost warmed up before driving it anywhere and then drive it easy for a couple of miles so your transmission, differential & CV joints can get a good lube "workout". 29. Remove the CD from the CD player. If you have a CD changer, remove the CD magazine. |
06-15-2009, 08:14 AM | #6 |
21
Rep 314
disconnect your battery! im having issues literally right now and my car was started every week while i was gone.
'16 340i M-Sport F30 Estoril blue, Oyster, Bootmod3, CTS high flow cat, CTS intake
Sold:'07 335i E90 Montego Blue on black leather, Navi, premium, sirius, sport pkg, CA, logic7 Sold: '07 328i E92, SG, Saddle Brown, Gray Poplar, ZSP, CA, Heated Seats, BMW Performance Exhaust, BMW performance SSK, Valentine1, european delivery - Military Sales |
06-15-2009, 01:54 PM | #7 |
2070
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
I would put extra air in the tires, wash wax and car cover and then take your battery out and trickle charge it in your condo. It will die if you just leave it, I know from experience. I also top off gas and put some Stabil in it, run it fr 5 minutes, then shut er down for good.
That is pretty much all I do for my car and motorcycle over the winter.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
06-16-2009, 10:50 AM | #8 |
Rep 127
My Integra is in an old underground mine right now. Will be coming out in September.
2009 135i
Cashmere Silver - Auto - Sport Pkg - Nav - BT - iPod - Leatherette |
