BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Glovebox Light
      01-15-2020, 11:10 AM   #1
Kansai12
Drives: 2016 X1 xDrive 25d M Sport
Glovebox Light
Hi guys,
I've removed the old halogen bulb from the glovebox light however, the cable does not appear to be long enough to re-attach to the bulb holder. Any ideas? Do I have to remove the glovebox?
Cheers
Jason
      01-15-2020, 05:09 PM   #2
Skyline2.0
137
Drives: 2018 BMW X1 xDrive
I would try using a pick tool or wire coat hanger to fish out the connector end that's inside the interior glove box area. There should be enough slack to pull it close to the opening and reconnect.
If that doesnt work, maybe you can gain access by taking off the fuse box cover in the back panel.
      01-16-2020, 01:50 AM   #3
Fuzzzy
Romania
Drives: BMW X1 F48 20d
Indeed the cable is very short, but it has a little spare, just enough to insert it back to the light. Try pulling gently. There is no need to dismount anything.
      01-16-2020, 06:56 PM   #4
Kansai12
Cheers guys, I will give it a go!
      01-17-2020, 11:57 AM   #5
Kansai12
Thank you kind sirs, it worked. I pulled it a little further out however, I wish it had a little more slack.
