The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Combox replacement - need coding?
      02-13-2020, 02:57 PM   #1
jbruno
Drives: 2011 328xi E90 LIM
Hi all, I'm new to the world of coding and I'm hoping you can help clarify something for me.
I'm planning to replace my defective combox on my 2011 328xi E90 with a similar, used one. My Bluetooth, USB and AUX stopped working.
This is what I have on the car right now:
S609A Navigation system
S620A Voice control
S639A Preparation f mobile phone cpl. USA/CDN
S645A BMW US Radio
S676A HiFi speaker system
S693A Preparation BMW satellite radio
S697A Area-Code 1 for DVD
S6AAA BMW TeleServices
S6ABA Control, Teleservices
S6FLA USB/audio interface
S6VCA Control, Combox
Do I need to do some coding to get this working?
These are the 2 comboxes I plan to swap. First one is on the car right now.
      02-13-2020, 03:12 PM   #2
elthox
Drives: E91 330xd stage 1
You have a long way ahead. Flashing, coding, navi enabling fsc codes
      02-13-2020, 03:22 PM   #3
jbruno
I actually wanted to ask: is the navigation done through the combox? What’s puzzling is that navi works ok for me right now
      02-13-2020, 05:27 PM   #4
sdbmwcoding
185
Drives: BMW M3
Default code Media and CIC and everything will return to default
      02-13-2020, 05:59 PM   #5
sdbmwcoding
185
Drives: BMW M3
No need to flash or enable navi, he's replacing the combox not headunit
      02-13-2020, 06:00 PM   #6
elthox
Originally Posted by jbruno View Post
I actually wanted to ask: is the navigation done through the combox? What's puzzling is that navi works ok for me right now
Headnunit not replaced? Misunderstood. Then just coding.
      02-13-2020, 08:20 PM   #7
jbruno
Hm, funniest thing happened - I replaced the combox and everything seems to work again. BT, USB, AUX (this were broken before) + Navi, Radio, CD (worked before). Am I missing something? Didn't do any coding...
      02-13-2020, 09:49 PM   #8
FaxData
98
Drives: 2017 330e (F30)
If the new unit came from a same spec car then practically nothing needs to be coded. To be safe, default code MEDIA. No other units need coding since you’re replacing a module with an identical module.
      06-13-2020, 02:21 AM   #9
TonyW1967
Drives: BMW GT F07 2012
Hi there, I'm about to replace my Telematics combox too, but just wanted to ask, did you just swap out the units? Isa there any prep work needed, like disconnecting the battery, or order of plug removal/fit?
      06-18-2020, 09:19 PM   #10
smass
399
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
It really depends on what the donor car had for options. E series Combox was available in cars without CIC and these did not have BT music streaming. In this case, the combox needs to be default coded before it will work with a CIC.
      04-03-2022, 09:27 AM   #11
BWbimmer
BWbimmer's Avatar
Germany
277
Drives: BMW F36, E36, E93
S620A Voice control
S645A BMW US Radio
Did you experience any issues later? I was wondering if the change of the IMEI and SIM made any differece?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required
      03-15-2023, 07:03 AM   #12
Kocho
Drives: BMW M3 E90
How do you default code Media on the new combox? I have the same problem as the OP, bought a used combox with the same number, plugged it and now everything is in the menu (Aux working, USB working, but I cannot see the the BMW bluetooth on my phone when I try to pair my phone) and I have now a SOS error wich I didn't have with my old combox.
      01-15-2024, 03:25 PM   #13
catarina919
Drives: BMW 328i F30
Default code MEDIA
I have the same (newbie) question about how to default code MEDIA for a combox that replaced one that failed. Thanks!
      04-23-2024, 11:49 AM   #14
pwns
Drives: E92 335xi Coupe 6MT N55
Bump!
Would anyone kindly explain?
      04-23-2024, 01:09 PM   #15
mattanderson
201
Drives: 2007 E92 328i
To default code any module:
1. Run NCS Expert with expert mode profile
2. Choose your chassis
3. Choose ECU you want to default code
4. Change job to SG_CODIEREN
5. Execute job
