09-16-2016, 05:25 PM | #2 |
282
Rep 1,491
There is a semi auto hold function...of sorts. If you're stopped in traffic, apply the park brake, lift your foot from the brake and the car will hold. Traffic starts moving, so press the accelerator and the park brake automatically releases. Works well enough for me in these situations I need it.
09-16-2016, 06:43 PM | #3 | |
86
Rep 510
In answer to the original question - no I don't think you can. I asked about this when I was looking at the X1 and realised (in our Australian market and apparently yours as well) it didn't have an auto-hold function. While most of the work is just coding, you still need the button to engage auto-hold (which is blanked off in X1s in our market) which works with the coding. Tony |
09-17-2016, 01:59 AM | #4 |
282
Rep 1,491
Geez, calm down Tony....I did say "semi-auto hold", which does everything auto hold does AFTER you've engaged the park brake. And no, there's no coding alternative in any market, so far as I'm aware. Which is as good an answer to the question as anything else. OK?
09-17-2016, 03:40 AM | #6 |
268
Rep 1,597
It's really frustrating that they left this feature off the X1! Just can't see the logic in not having it present.
I do the same as ttimbo although it's nowhere near as smooth as auto hold and you have to have your foot firmly on the brake or it triggers the stop start when you release your foot from the brake |
09-17-2016, 03:56 AM | #7 |
Quadrex
1093
Rep 1,424
Drives: W212 Mercedes=Benz E Class
I have BMW i8 ,it doesn't have it either . However, it works when you are on the hill and apply the brake for 2 seconds then you let your foot off the brake pedal without having to press the electronic P button ,the car holds . Slightly touch the gas pedal , the car moves.I find it a bit weird given the fact that it only works only when you're on the incline
09-17-2016, 07:49 AM | #8 | |
1312
Rep 10,185
BMW if you are reading, I need a job, Please. |
09-17-2016, 07:56 AM | #9 |
1312
Rep 10,185
It was never incorporated into the Mini F56 systems the X1 systems are based on
09-17-2016, 06:29 PM | #10 | |
86
Rep 510
Tony |
09-17-2016, 06:34 PM | #11 | |
86
Rep 510
Tony |
09-18-2016, 08:41 AM | #12 | |
268
Rep 1,597
However it wasn't a deal breaker as for us the X1 was a much better vehicle than the alternatives we were looking at... I've got used to using the electronic brake when I drive the car, it's not ideal but workable
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
09-18-2016, 09:32 AM | #13 | |
1312
Rep 10,185
Higher models always have better equipment and fittings.
05-15-2019, 10:22 PM | #14 |
Rep 32
I opened the electronic parking break switch and the switch to turn on the auto hold is there on the circuit board behind the e-brake, it even has the led light. It activates auto hold without the need for any coding, But no actual actuator button is there. The enclosure does not have a place for a button for activation of auto hold. I drilled a hole so I can activate the auto hold switch with a thin metal rod, but that is not the cleanest way to do this, buying switches on eBay to see if any of them can be retrofitted. I'll post photos tomorrow
05-16-2019, 06:59 AM | #15 | |
144
Rep 491
iceman7117.00 |
05-16-2019, 11:52 AM | #16 | |
Rep 910
http://www.bavarianmw.com/guide-3174.html |
