N53 n54 injectors
05-03-2022, 05:04 PM | #45 |
102
Rep 681
05-03-2022, 05:27 PM | #46 |
623
Rep 3,199
Drives: E92 325i MSport Coupe
TBH no. Same sound, same feel. I did wonder if they felt a bit spicier at WOT, but it could be my imagination. Since the ECU tells the injectors precisely how much fuel each cylinder needs, the fact that the injector is capable of delivering more (when fitted to an N54) is irrelevant I guess...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
05-03-2022, 07:23 PM | #47 | |
Rep 14
I presume the car is completely undrivable until they're coded in? Or could I limp to the Indy provided it's nearby after fitting them myself? |
05-04-2022, 02:30 AM | #48 |
623
Rep 3,199
The re-coding should be a half hour labour max. If you're asking an indy to do just the re-coding, make sure you note the individual injector values as you fit them. Yes the car will drive without coding, though it might be a bit rough to start with, as the car adapts to the new injectors.
05-04-2022, 02:31 AM | #49 | |
69
Rep 316
Just FYI - you do need to drive in a certain way immediately after the adaptions have been cleared to help the re learning process. It depends if the indy includes this in the time taken to clear them or not. You can get most of the way there to re learning the adaptions after an hour. As I said in the other thread I reccomend doing this and addressing any other faults before you take the plunge on a new set of injectors anyway, as it can sort some rough running and cold start wobble but a bit tricky if you don't have the software (which isn't expensive to buy either, about £25 for a cable). Depends how involved you want to get. |
05-04-2022, 02:42 AM | #50 | |
Rep 14
Infact I just checked and programming the injectors is doable through protool, so surely resetting the adaptations is possible too. Can anybody speak from experience on that? |
05-04-2022, 05:34 AM | #51 |
Rep 1
Very interesting! I'm in the same position having almost given up on finding index 11s. Had seen comments previously saying index 12 in an N53 is a bad idea but maybe it's worth it then seeing as it's impossible to source any 11s.
I can't say anything for protool as I've never gone that route but I'd strongly recommend getting a cheap OBD cable and getting ISTA/INPA. Personally, I've only used INPA as bimmerprofs is full of helpful guides, all be it with some questionable English at times. It's amazing the detail you can go to with it, I can see all the adaptions for the injectors. With that, I am thinking I might be able to get away with just replacing one bank with 11s/12s and putting all the supposedly good ones in the other bank till my wallet is looking healthy again. With regards to coding/re-adaptation, it should be a breeze if you are technically inclined. I'd look at [https://bimmerprofs.com/injectors-adaptations-coding/] for some insight on the current injectors and possibly [https://bimmerprofs.com/not-encode-injectors/] for some help on coding although I haven't looked at that properly I'm sure there are loads of guides out there. With regards to re-adaptations, this guide is all you need [https://bimmerprofs.com/re-adaptation-engine/] I got all the tools from [https://www.bimmergeeks.net/downloads] and [https://bimmerprofs.com/msd80-loader-2-023/] update package as well. Hope that helps and I haven't hijacked the thread too much but I'm glad the index 12s could give me hope!! Reply or DM if you need help, I should probably get back to work for now! |
-claw-4.50 |
05-04-2022, 10:15 AM | #52 |
69
Rep 316
I have installed both ISTA and INPA. Both are easy to use and readily available and a must have if you want to get involved.
For day to day fault checking I use carly - but got it before it was a subscription service and don't use it enough to warrant the subscription cost. It just saves getting out the laptop and I keep my dongle in the glove box if there is ever a fault when driving. |
06-24-2022, 07:36 AM | #53 | |
Rep 9
I wanted to ask you if your car is still well up and running with those N54 Injectors? Im about to do the same, just with used ones (from a N63 actually) because you literally can't get them new. |
06-24-2022, 04:20 PM | #54 |
623
Rep 3,199
Yes my N54 (index 12) injectors are performing just fine. However mine were new not used.
06-28-2022, 05:54 AM | #55 |
Rep 9
06-28-2022, 10:12 AM | #56 |
623
Rep 3,199
I've now driven 7,000kms on the N54 injectors. I presume you mean the valve cover gasket is leaking, not the head gasket? Head gaskets are not known to leak on this engine...
06-30-2022, 03:05 AM | #57 | |
Rep 9
My Engine has about 280.000km now, and it started smoking white, funny sweet smelling since a few days. Today it started smoking non stop.. not sure what to do now. Most likely the head gasket |
06-30-2022, 03:18 AM | #58 |
623
Rep 3,199
That's bad news and very rare. Hope you manage to get it sorted...
330i.germany1.50 |
06-30-2022, 04:03 PM | #59 |
102
Rep 681
I'd be looking for a proper test before condemning the HG. Also they tend to get damaged rather than fail so has it overheated recently? If it really is burning coolant it'll not do your cats and o2s much good.
330i.germany1.50 |
07-02-2022, 11:21 AM | #60 | |
Rep 9
The Engine didn't overheat to my knowledge, i did a test drive today and it was holding the heat perfectly fine! (Range is 90-110°C, both oil and coolant). Also no smoke today, its really weird! |
07-02-2022, 06:58 PM | #61 |
102
Rep 681
Any gasses in coolant? Compression test done?
What does not holding pressure mean - sounds like vacuum test on coolant system - as Phil says, HGF unheard of on these engines |
07-03-2022, 07:19 AM | #62 | |
Rep 9
By not holding pressure i mean, that a device was connected to the Coolant expansion tank cap to build pressure (1.5 bar) and you could watch it get lower by the minute There were no signs of coolant in oil or vice versa so far HGF might be unlikely, but i heard of lots of cases of cracked cylinder walls Last edited by 330i.germany; 07-03-2022 at 07:36 AM.. |
08-18-2022, 05:20 AM | #63 |
Rep 21
08-18-2022, 10:55 AM | #64 |
623
Rep 3,199
Without diagnostics (which I don't have) I'm not sure how I would know for certain. However the engine runs absolutely normally and economy is a good as ever. Today I've just completed a 300 mile trip (mixed cross country and highway) and it's returning 45mpg or 5l/100km. So I'm confident it's working in all modes.
03-11-2024, 04:59 AM | #66 |
Rep 7
Hi everyone,
I was bold enough to get a 2008 e90 325i with the N53B30A engine and 135k kms. Sure enough, it's having a bit of a rough idle on a cold start and the EML came on for a cylinder 1 misfire. After reading a bit, I'm assuming it's probably a bad injector... I'm gonna smell the spark plugs tomorrow. Question - are the N54 index 12's any better than the N53 index 11's? Any idea about reliability/longevity compared? If the N54 index 12's are noticeably better, I guess I would get 3 of these for a bank. Otherwise, maybe I just replace the ones that are bad with index 11's. Joy of joys... the car is in excellent condition otherwise and I'd be sad to throw it away. Cheers, Bruno Last edited by Series3; 03-11-2024 at 05:09 AM.. |
