BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Almost stalled backing out of my garage
      08-14-2016, 12:03 PM   #1
ifletch
22
Drives: 2016 BMW X1 xDrive28i xLine
Today I went to back my 2016 X1 out of the garage and it felt like it was going to stall. I put it back into Park and pressed the fuel pedal down to give it a little fuel and the engine calmed down. I have had the X1 since April and has about 5000km on it. Always fill it up with Shell or Esso 91.
Can't remember ever having that occur with my 2010 Tiguan that I had for five years.
I suppose these things happen or should I be concerned.
      08-14-2016, 12:14 PM   #2
Pristineship
48
Drives: F48 X1 X line sDrive 20i
did you use a gas pedal or just let it creep on its own
      08-14-2016, 02:28 PM   #3
ifletch
22
I put it in reverse and let it creep out. Backing out of my townhouse I have to be careful of other cars driving down the alley. It is the first time it has done this since picking the car up at the dealer April 11.
      12-28-2019, 07:49 AM   #4
joed789
Drives: BMW X1 xdrive28i
Did you ever get this issue resolved? I am experiencing a very similar issue with my 2017 x1 xdrive28i and the car has actually stalled once at this point. When I restart the car it runs completely fine. I have seen a few other posts regarding "rough starts" but no other reports of near stalls or stalls.
      12-28-2019, 01:46 PM   #5
rice_rocket88
No_Country
298
Drives: E60 F48 F39
I'm curious to watch too.. Backed the wife's car out and it was really rough.. First time I've experienced it..
      12-28-2019, 05:59 PM   #6
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
Ours does this a bit, too. Just let it idle for a little longer before engaging gear. I suspect new plugs on ours, due at the next service, will likely solve the issue
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      12-28-2019, 06:06 PM   #7
Bimmer North
69
Drives: 2018 430I grand coupe
Also experienced same issue a couple of times with wife's 2016 X1. Think a little longer idle time is needed ; if memory serves me correctly when you start and don't wait at least 30 seconds....issue crept up a couple of times.
      02-11-2020, 09:20 PM   #8
Derelique
Drives: BMW X1
Did the spark plugs fix this issue? I'm having the same problem. I guess I need to wait patiently to let it warm up. Although it would be nice to figure out what causes it.
      02-12-2020, 03:01 AM   #9
ttimbo
ttimbo's Avatar
282
Not serviced yet, so I can't confirm. But even just letting the car idle for 30s seems to overcome the problem
      02-13-2020, 06:31 PM   #10
Derelique
Drives: BMW X1
True that! I read another post saying it was related to the tune and emissions requirements to heat up the cat quickly(too much gas early messes up the mixture). Not sure if it's accurate but that's what some people suspect. And several dealership technicians saying it was normal. Less concerned about it now. Thanks for the input!
      02-13-2020, 08:23 PM   #11
jmhumr
49
Drives: 2017 BMW X1
Wow, funny to see this thread. I’ve been experiencing these near-stalls all along and this morning it was so bad that I convinced myself to make an appointment to take it in. I’ll try the warm up thing first.
      06-20-2020, 06:43 PM   #12
PurePulse64
52
Drives: 2017 BMW X1
I had issues like this with my 2017 X1. When I took it in for service I mentioned it, they updated the software in the car and I haven’t had it happen since.
      06-20-2020, 08:00 PM   #13
jmhumr
49
Drives: 2017 BMW X1
There's a whole thread on this. Faulty EGR valve, get fixed under warranty.
      06-21-2020, 12:15 AM   #14
ttimbo
ttimbo's Avatar
282
My understanding is the EGR issue referred to in that thread relates to diesel engines, not the gasoline engines. It may not be the same in all markets, however, due to different emissions standards
      06-22-2020, 11:56 AM   #15
E39M5Dan
Drives: 2017 BMW X1 28SDrive
1996 BMW 328is  [0.00]
2017 BMW X1  [0.00]
2000 BMW M5  [0.00]
Been having this same issue off and on with my wife's 2017. Most days starts and idles fine... but every other week or so, start, rough idle, will stall if you try to put it in gear and move. Will try and sit and wait but this stinks of a bad sensor.
      06-22-2020, 03:24 PM   #16
jmhumr
49
Drives: 2017 BMW X1
FWIW mine completely stalled TWICE while backing out today. This is the first time; previously the car would stutter each time but I was able to play with the throttle to keep it running. I'm making an appointment right now.
      06-22-2020, 04:26 PM   #17
Shagohod
18
Drives: F48 X1
I'm curious as to what they diagnose the problem as, or whether they'll just try to shrug it off. Is your car completely stock?
The closest I've noticed to this behavior is in the morning when I start my car for the first time. It'll sit for a moment at the higher revs, sensibly, and then it comes VERY close to stalling before returning to a warm idle rpm. I could easily picture the car stalling if I tried to reverse up my steep driveway while it was in that warm up phase. Does this still happen to you even when the car is warm?
      06-22-2020, 07:41 PM   #18
Movnmik
15
Drives: BMW X1
I picked up my 2017 X1 in late May so this is a common occurrence with mine. It seems after about 30 sec to a min it's fine. But would really like to know if I should have it looked at whiles its under warranty.
      06-22-2020, 07:48 PM   #19
jmhumr
49
Drives: 2017 BMW X1
Completely stock, seems worse when the car has been sitting overnight. Yes, I think warming up helps, but I'm calling this a defect unless BMW can show me owner's documentation that says we're advised to let the engine warm.
      06-24-2020, 01:27 AM   #20
ttimbo
ttimbo's Avatar
282
I guess it depends on how long you are needing go warm up the motor before the stuttering stops. With all my cars, I've started them and had them idle for about a minute when cold — it's just a mechanical sympathy thing, to get all the fluids (especially oil) flowing before placing load on the engine. That said, if the car is 'stuttering' even after this, time for a service visit.
Oh, and new spark plugs certainly fixed ours.
      07-08-2020, 11:47 AM   #21
jmhumr
49
Drives: 2017 BMW X1
Just got my car back from the dealer. They prescribed a coding fix. I asked them to explain the issue in more detail and all they knew is that they ran a diagnostic check and that was the shop book answer. I didn't have the time or patience to ask to speak to the actual technician vs. the service advisor. I'll post an update once I try a cold start.
On a related note, the dealer discovered that my water pump was bad (replaced under warranty). I found that quite premature.
      10-23-2020, 05:54 AM   #22
Jaybyrd
Drives: 2016 BMW X1
I am curious if the coding fix resolved the issue?
