BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Coolant level 2015 X1
      10-08-2020, 11:29 PM   #1
Shineon2020
Shineon2020's Avatar
Drives: BMW X1 sdrive28i
I've been getting the coolant light come on my dash now once every 2-3 weeks in the past month & a half in my 2015 X1. I fill it up, then it goes low again. I haven't seen any fluids on the driveway. Does anyone know what it could be & how much?
      10-10-2020, 01:00 PM   #2
Jack Watts
20
Drives: BMW X1
I think most likely cause is a leak at the water pump. If it's leaking slowly it's likely evaporating, with some residue on the block. This shows the location: https://bmwtechnician.com/2019/01/03...al-water-pump/
This is a pretty common VW thing--not sure how common it is on this engine.
      10-11-2020, 02:08 AM   #3
oakey46
159
Drives: BMW 2 A/T 220i Lux Auto 1.5
Is your X1 an F48 model or, because you say it’s a 2015 model, an E84? The engines on both versions are quite different, so if yours is the E84 it is best that you submit an enquiry via the E84 forum.
      10-11-2020, 08:31 AM   #4
StefanJ
StefanJ's Avatar
68
Drives: BMW X3 G01 xDrive 20d
I agree with oakey46, because F48 doesn't have any coolant level sensor, nor coolant light on the dash.
