BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) F48 Dash and Door Trims
      09-15-2020, 02:19 PM   #1
mtc5131
Drives: 2020 BMW X1
Does anyone know a solid place to find Dash and Door Trim for a 2020 F48... I've looked at my local dealerships parts inventory and it seems nothing comes up for the 2020 just the 2020 F39, is the something I just need to reach out to them directly? ... I really hate the gloss black on the dash and the door panels... I know you can always wrap the pieces, I don't trust myself to even attempt to wrap the pieces... I love the brushed aluminum trim with pearl chrome accent look you can find in the F39... don't know who thought that much all gloss black was a good idea the up keep to not get scratched alone
      09-16-2020, 01:29 PM   #2
Viltronian
10
Drives: BMW X1 25i
Look around for these terms on amazon or Aliexpress, so many terms tho. Although I have no idea if the dimensions are the same on the 2020 versions.
https://www.aliexpress.com/item/3294...6c9f7822U53l5a
      09-16-2020, 11:56 PM   #3
ventjock
65
Drives: 2020 M340i
I had a shop wrap all those pieces for me. Makes such a huge difference. They also wrapped the piano black center console.
You can easily do the first two pieces you took images off. The pieces on the doors and the center console are trickier.
      09-17-2020, 07:11 AM   #4
kavatski
147
Drives: 2023 X3 30iX
Wrapping or covering up with stick-on pieces is going to be the cheapest option, but you could dig deeper at your dealer if you really want to swap the pieces out. There are several different factory options for those trim pieces for the F48 depending on how the vehicle was ordered, including the aluminium trim. Ours has the dark open-pore wood and it's great: no scratches, no fingerprints.
      09-26-2020, 08:49 PM   #5
00max00
19
Drives: BMW X1 - option loaded
Don't they provide better options for 2020? I specifically ordered mine with the "fine-wood fine-line", looks gorgeous.
      09-28-2020, 09:50 PM   #6
mrexcuse
34
Drives: Tiguan, M2 Comp, 330 Touring
This could be a start for you to try and find the correct part numbers. Once you have the colour codes and part numbers found you can try to go to the dealer and source it. That being said, the lowest cost way forward would be to wrap it.
https://www.realoem.com/bmw/enUS/sho...diagId=51_2907
