BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Tyre Damage
      09-09-2020, 02:35 AM   #1
adi555
21
Drives: F48
Tyre Damage
Can this tyre be used or get it replaced? There's no air leak, the cut does not look deep though. Please suggest
      09-09-2020, 02:44 AM   #2
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
1. Is it a RFT?
2. How did it happen? Ie, might there be carcass damage due to a high impact?
3. How old (yrs/distance) is the tyre?
Personally, I'm super-cautious about tyres; I'd probably replace it. However, if it is a RFT and wasn't damaged by a high speed impact, I *might* consider swapping to the rear of the car and keeping a close eye on it until I'm ready for a new set of tyres
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      09-09-2020, 03:51 AM   #3
adi555
21
Drives: F48
Yes this is Pirelli RFT. I don't know how it happened, the tyre has about 3-4mm thread life on it. This is already on the rear. Tyre is 2 yr old Looks more like surface cut?
      09-09-2020, 04:49 AM   #4
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
It is difficult to assess from a picture on a forum. For your own safety, get an assessment from two local tyre fitters and take it from there.
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      09-09-2020, 02:56 PM   #5
oakey46
159
Drives: BMW 2 A/T 220i Lux Auto 1.5
If you have any damage on the sidewall of a tyre, here's what it says on Continental Tyres UK website:
'Cuts are the result of external influences like bad road conditions, protruding bodywork parts or sharp, foreign objects such as stones or glass. If you discover damage in the form of a cut on the tyre surface, you should visit your local tyre retailer and have your tyres immediately checked by a professional.'
From what I can see and from personal experience, it would be unwise to drive with a tyre in that condition because it could cause a blow out at any time, with appropriate consequences.
In the UK it would result in an MOT (Ministry of Transport annual safety test) failure.
I recently had to replace a winter tyre where a sharp object had penetrated through the outer tread block (near the shoulder) and resulted in the steel re-inforcing wires becoming clearly visible, despite only being approx 2cm length. The tyre dealer I used for the replacement told me he would have had to fail the car if it was in for MOT (my X1 is only 2 ½ years old, although MOT is only required on cars at 3 years old and annually thereafter).
In any event, it is a wise precaution to regularly check your tyres for any signs of damage.
