06-03-2018, 06:21 PM | #1 |
Rep 24
Certain "lights" stay on after locking?
I was locking with the key fob and noticed that some lights were left on in the car after locking and activating security.
The lights that were left on were the emergency blinkers on the center console, the adaptive driving assistant button (right below the emergency blinkers), and the driver's left side headlight switch. Is that a normal thing? I did go back to check the car after 10 mins and its still on. I double check to see that I turned all of the lights off. |
06-04-2018, 07:10 AM | #2 |
49
Rep 181
I noticed the same thing and thought it was weird. The lights eventually go off, but this seems like a goof. Hopefully it’s not wearing on the battery.
09-27-2020, 09:39 PM | #4 |
50
Rep 753
Reviving this old thread.
Noticed my headlight switch backlighting, gear shift indicator was lit in green "P", Hazard light button, and my cigarette to USB adapter was lit up in blue on my x1. This is AFTER the car has been sitting over an hour. I went inside to get the keys, came back out and the interior lights were off. Then around 15 minutes later (never touched the car or unlocked it), those interior lights were back on. Now I've read these turn on because the electronics are on, and should usually go to sleep after 10-20 minutes after the car is off. This is why if you stop to fill up on gas and come back idrive doesn't need to start up again, because that computer never turned off. In my case though, why would those lights be on after so long, turn off, and later turn on again? Only thing I could think of is the SIM card was downloading some type of data to the car? Anyone else notice this behavior? |
09-28-2020, 12:01 PM | #5 |
298
Rep 1,079
Maybe your key fob is too close or you keep on walking by the car.. it has a billion sensors and it will wake itself up. Even in my 2 car garage when I have the keys on one side of the car if I get close to a car I'm not working on you'll hear something "wake up".
The car is supposed to fall asleep after 20 mins max unless something else wakes up the brain. If your car is still going off then you might have some other problem of a module error. |
