BIMMERPOST Universal Forums General BMW News and Cars Discussion Homelink ?
      07-13-2021, 08:25 PM   #1
Xccelerate
Back in a BMW
Xccelerate's Avatar
285
Drives: 21 X5M Comp
Homelink ?
So just got a f44 in the family 228 xdrive, was shocked to see no homelink.
Anyone know if it can be added via mirror swap? I was already hunting down parts.
No real info as of yet. Hoping someone can help.
21' Donington on Black X5M | Comp | Exec
11' 1M Coupe Valencia 6MT OEM+ 289 of 740
      07-13-2021, 09:57 PM   #2
BzsBimmer
BzsBimmer's Avatar
3270
Drives: '23 G80 FO M3, M3 & MY Tezzy's
Wonder if result of chip/supplier shortage. I would think by now Homelink is standard, especially for a luxury vehicle where cheap econoboxes even has them standard.
Best of luck on finding the answer
      07-14-2021, 07:18 AM   #3
BMWCCA1
BMW Owner Since 1971
2257
Drives: 1964 700 Sport Cabriolet
2013 BMW 128i  [10.00]
I believe it requires Premium package. That being said, all it takes is power connection. We used to add it to E39s all the time by swapping the button section and using the power wire available in the headliner. I assume the Homelink hardware are also self-contained in the buttons or mirror. There's probably a simple Homelink add-on available not from BMW.
https://www.amazon.com/HomeLink-60-H.../dp/B00A79G9FY
      07-14-2021, 09:07 AM   #4
zx10guy
5150
Drives: 2013 135i
Agreed. You just need power. Might be able to get the factory mirror with Homelink and install it....provided the harness is there or you can splice in power.
I did this with my Toyota C-HR. The car came from the factory with an auto dimming mirror but no Homelink. There wasn't a factory option. So I bought a Gentex auto dimming mirror with Homelink. Since power was already there at the mirror assembly, I just spliced in the new mirror. Had to grind out a little of the plastic housing where the mirror mounts in for clearance along with getting an adaptor to provide the clearance necessary due to the short arm of the Gentex mirror. Works great.
      07-15-2021, 08:36 PM   #5
Xccelerate
Back in a BMW
Xccelerate's Avatar
285
Drives: 21 X5M Comp
Indeed just can't find that mirror. It does appear to be the same as my x5 but easier said than done haha.
      07-22-2021, 06:08 AM   #6
spielnicht
Petrolhead
spielnicht's Avatar
440
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
I had a fully loaded F44 loaner just a month ago and was surprised it didn't have it either. Doesn't look like it's even an option for F40/F44 according to this dealer or RealOEM.
https://www.bmwofmountainview.com/research/homelink.htm
https://www.realoem.com/bmw/enUS/sho...diagId=51_A708
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
      07-29-2021, 11:13 AM   #7
WeryPert1
105
Drives: 128i
Might not be missing much: I haven’t been able to get it working on my BMWs anyway. And when I researched it seems like a lot of other folks struggle, as well.
      07-30-2021, 06:49 PM   #8
zx10guy
5150
Drives: 2013 135i
Haven't had any issues getting mine working on two different garage door openers. Although it seems the signal strength coming out of the factory unit is weaker than the Gentex unit I installed in my Toyota.
      07-30-2021, 08:17 PM   #9
Almuliman
484
Drives: 2013 LMB 6MT 128i
I cannot for the life of me get the Homelink unit to learn the signal from the remote. No matter the distance or angle. FWIW, it's a ~5 years old Chamberlain (the opener – car is a 2013 128i ).
      07-30-2021, 08:25 PM   #10
Xccelerate
Back in a BMW
Xccelerate's Avatar
285
Drives: 21 X5M Comp
Reset it from the car. Pressing 1&3
Then take remote to the homelink then learn button and homelink button in car done
      07-30-2021, 09:11 PM   #11
NBTBRV8
Drives: LCi E60 530i
I retrofitted Homelink in my old E90, it was hard as I had to split the mirror apart and remove the US spec module and insert a Euro one for where I live.
https://www.e90post.com/forums/showthread.php?t=1159452
      07-30-2021, 11:52 PM   #12
Almuliman
484
I've done the 1&3 reset numerous times. The Homelink doesn't ever start blinking rapidly (which is supposedly what indicates it has learned), it just keeps blinking slowly as long as the remote sends a signal. The Homelink hasn't learned the signal, so as best I can tell, it doesn't send anything to the opener itself, meaning the Learn button won't do anything. At least I haven't gotten it to do anything.
      07-31-2021, 06:32 AM   #13
The Libertine
The Libertine's Avatar
1236
Drives: 2021 Porsche Macan
If you have two remotes, try programming with each. For my system, one garage remote worked to program in my X5 and the other did not.
      07-31-2021, 08:41 AM   #14
Almuliman
484
May just try that. We only have one, but need to buy a second anyway.
      07-31-2021, 09:32 AM   #15
The Libertine
1236
Give it a shot. With mine, it’s as if one of the controllers is the “master” of the two which is designed to program other devices.
      07-31-2021, 10:24 AM   #16
Almuliman
484
Sadly, no luck. Picked up a new Chamberlain one-button remote just now and tried again. Homelink is still not picking up .
      07-31-2021, 10:48 AM   #17
BzsBimmer
BzsBimmer's Avatar
3270
^ might need this
https://bridge.chamberlain.com/?&_ga...7746442#/intro
      08-03-2021, 06:17 PM   #18
zx10guy
5150
Drives: 2013 135i
Try calling Chamberlain. Something is definitely not right. I have a Liftmaster circa 2012/13 ish. My car is a 2013 135i and I was able to program one of the Homelink buttons to the Liftmaster without issue.
I had to call Chamberlain for support on their MyQ Smart garage controller and the support rep I got was excellent.
      08-03-2021, 07:43 PM   #19
Almuliman
484
Originally Posted by BzsBimmer View Post
Called Chamberlain (thanks, zxq10guy) and yes, I do need a bridge. Apparently, the combination of Homelink and that particular opener doesn't work without it. Our '01 Odyssey (older, so OK, I guess) can't be programmed to it either, but our '12 Volvo can. Go figure.
