12-28-2023, 10:08 PM | #1 |
91
Rep 76
Mid 4 pt brace installed ! for the X3 M40i
Finally got this installed and you could feel the difference immediately.
Car used to wobble if going through uneven surfaces, right now its just way more compliant and settles really quickly. Definitely recommend ! |
12-28-2023, 10:25 PM | #3 |
3386
Rep 1,834
Drives: 2022 X3 M40i
Ultra Racing 4 Points Middle Lower Bar for BMW G02-X4 M40 3.0T 2018 (4WD) fits X3 Rottweiler has pics of the oem one up close when he installed his.
https://www.ebay.com/itm/175389270584 or https://www.aleksracing.com/ultrarac...4-g02-2018-ur/ I have the rear lower bar installed and waiting for the mid brace to arrive. |
Rottweiler4065.50 3y3scream90.50 |
12-28-2023, 11:05 PM | #5 |
126
Rep 222
Burr001 Do you know what exactly fits on our X3 chassis? I am looking to get all of the UR bars that Aleksracing has.
So far it looks like: Mid Lower Rear lower What about: Strut Front Lower Rear lower large (looks like it fits) I may order them all and try my luck. I have used UR products before and they are well designed. |
12-28-2023, 11:43 PM | #6 |
Captain (Retired)
4066
Rep 1,796
I’ve got front, mid and rear installed from Aleks Racing
Would do it again in a heartbeat |
Burr0013386.00 earlgsxbusa126.00 |
12-29-2023, 12:18 AM | #7 | |
3386
Rep 1,834
you can always go X3M OEM brace...more money though. https://x3.xbimmers.com/forums/showp...1&postcount=54 PS when installing the rear small lower make sure you have another jack holding the subframe as it will drop once you take the 2 bolts off. Last edited by Burr001; 12-29-2023 at 12:25 AM.. |
12-29-2023, 12:43 AM | #8 | |
126
Rep 222
12-29-2023, 01:18 AM | #9 |
3386
Rep 1,834
Rottweiler4065.50 deviation01126.00 |
12-29-2023, 04:03 AM | #10 |
91
Rep 76
The shop i went to was selling the front lower for the X4 G01 as well, they told me that if i installed onto the X3 G01, i'll have to cut some of the undercarriage panels to make space....
Those who installed the front lower, is it true ? |
12-29-2023, 08:25 PM | #11 | |
252
Rep 513
What has to come off to put it on. Same with mid brace please, including a link to it if you have one. Thanks in advance.
E46 -> E90 -> F30 -> F23
12-31-2023, 12:03 AM | #12 |
91
Rep 76
https://www.aleksracing.com/middle-l...-urtw-ml4-4002
Here you go ! this will fit 2018 X3 to present models |
01-01-2024, 12:06 AM | #14 |
Captain (Retired)
4066
Rep 1,796
earlgsxbusa126.00 |
01-02-2024, 10:32 AM | #16 |
260
Rep 383
Drives: 2023 BMW X3M40 1984 911 TARGA
why?
2023 X3 M40I 2018 X3 30i M Sport
2011 550i 2005 325i 1985 535I 2017 F150 2016 GS 2004 545i 1994 525I 1984 911 TARGA 2014 HD ULTRA |
01-02-2024, 10:54 PM | #18 |
4371
Rep 2,115
ocdx30.00 gofastbmw5100.00 |
01-02-2024, 11:31 PM | #19 |
3386
Rep 1,834
To install the rear lower bar, you will need to remove both sides that hold up the rear subframe. There is no real room to install the bar one side at a time and to undo the bolt once the other side is attached.
Rottweiler4065.50 dinan5m34371.00 |
01-03-2024, 12:11 AM | #20 | |
4371
Rep 2,115
01-03-2024, 12:13 AM | #21 |
3386
Rep 1,834
Yeah also this brace is a different location than the f97 one. It is located just above the muffler and not the midbrace location.
01-03-2024, 09:44 AM | #22 |
260
Rep 383
Why are these braces needed?
