09-14-2020, 04:13 PM | #1 |
402
Rep 1,104
OBDII Software for Apple Devices
Hi.
Long time Android fan, finally switched to Apple (don't ask). Running an 11 Pro with IOS 14 Beta 8 Developer (yes, spent the $99). Today I went to use the BimmerLink app I bought (from same team as BimmerCode) to casually look at boost. I can definitely tell you that it was not accurate at all compared to the TORQUE app on my Android. Not going to get into it, without causing a super long thread. With that being said, are the issues I have with BimmerLink or IOS 14 Beta 8 and or ? What are all of you using for standard OBD II management using Apple devices? Just curious. Thanks, P.S. My OBD USB dongle has not changed and BimmerCode is still functional. |
09-14-2020, 05:50 PM | #2 |
402
Rep 1,104
Figured it out.
It was the BimmerLink crap software. Read 14.29PSI at idle. Pffft. Bought OBD Fusion. Works like a charm. And there is logging and export to .csv. $10 bux, well worth it. I'll be using this with the Dinan for sure and will share PSI results accordingly! |
09-14-2020, 08:40 PM | #3 |
129
Rep 421
09-15-2020, 05:17 AM | #4 |
1604
Rep 1,480
Drives: 2022 M440xi GC
That sounds about right because I read around-.5 at idle.
09-15-2020, 12:50 PM | #6 |
129
Rep 421
