11-30-2020, 10:35 AM | #199 | |
34172
Rep 11,637
Drives: 2015 BMW i8, E63 M6, 328d
The initial plume/fireball seemed about 10 meter tall? Gasoline vapour density is about 3.9 kg/m3. Combining these two with the experimental approximate scaling law, we get: Z = 12.73 m * (V / 1 m3)^ (1/3) => V = 1 m * (Z / 12.73 m)^3 ~ 0.5 m3 ~ 1.95 kg fuel ~ 2 kg The math seems to add about up. With 110 kg, the plume due to the initial fireball would have been about four times larger in height. We will never know until the investigation is done, my friend. I'm just glad that Romain "The Phoenix" Grojean is safe. Cheers-mk
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion. |
11-30-2020, 10:36 AM | #200 | |
62749
Rep 24,514
It's for sure , they stood too far away from the fire ! By this , the air in the mixture was feeding the flames ...
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
M5Rick58913.50 |
11-30-2020, 10:39 AM | #201 | |
62749
Rep 24,514
M5Rick58913.50 |
11-30-2020, 10:39 AM | #202 | |
3633
Rep 1,397
///M Power-Belgium62748.50 MKSixer34171.50 |
11-30-2020, 11:19 AM | #203 | |
62749
Rep 24,514
The fuel tank is completely gone..It's melted or blown away by the explosion !
M5Rick58913.50 fiveohwblow3633.00 |
11-30-2020, 11:31 AM | #204 |
3633
Rep 1,397
Yes I saw that and was watching it quite a bit yesterday. I too believe the theory is the bag was ruptured and added to the fire and find that easy to believe given the components of the fuel cell make up and the force of collision. I was merely trying to learn more about the collector
///M Power-Belgium62748.50 M5Rick58913.50 |
11-30-2020, 11:33 AM | #205 |
58914
Rep 19,254
Same here, collector is news to me, just thought pipes from tank go to injection pressure pump (metered) then on to fuel distributor and injectors.
fiveohwblow3633.00 ///M Power-Belgium62748.50 |
11-30-2020, 11:35 AM | #206 | |
564
Rep 465
I doubt it. The spray from a handheld extinguisher is fairly puny. The fire will entrain much more air on its own. They were definitely too far away at first, but those guys with the extinguishers didn't appear to be wearing proper face masks/SCBA, and it must have been crazy hot getting towards that fire. So I can't blame them for starting further back and working their way closer. Major props to the medical car guys for getting right in there and helping Grosjean over the fence. |
11-30-2020, 11:50 AM | #207 |
518
Rep 941
I was attempting to fight a fire that took hold in my neighbours wooden shed this summer and the heat drove me back much further than the Marshall was. I'm convinced the heat from that fuel would be far greater as well. Well done to the medical guy getting in so close.
11-30-2020, 11:53 AM | #208 | |
491
Rep 197
11-30-2020, 12:01 PM | #209 | |
3633
Rep 1,397
11-30-2020, 12:25 PM | #210 |
491
Rep 197
Gotcha. The technical regs don't lay out a size for the collector, but a quick scan of other sites show anywhere between 2.5-3.5l for Formula 1.
11-30-2020, 12:39 PM | #211 | |
62749
Rep 24,514
Well mate . In fact I already had 2 fire prevention courses from a team of professional fire brigade/officers . The reason why is : Because the company falls under the chemical industry . We are working with chemical granulates in injection molding machines . So , in the last 10 years I got 2 fire prevention courses as for fire prevention .Course was 2 X 4 hours . Special equipped truck arrived at the parking of the company and I got theoretical training and practical training . We were going through the different kind of fires . Normal wood fires, Fuel fires , chemical fires, and finally through a frying French fries pan fire . I had to put out all the fires in the specially equipped fire truck . So I smelled and felt the unbearable heat of the fire on my body . In the last hour , the officer showed me a French fries pan fire .. The oil in pan has +/- 180° C , means actually nothing , because we are melting our granulates at 400° C in our injection cylinders at the company. But what happens when we pour or spray water on that fries pan on fire ..? Well I felt the shockwave through the truck from the explosion of the fries pan , the special room was secured by steel walls while we watched the video of the explosion . Or...Just open a door to feed the backdraft fire..! In other words a burning fries pan can blow your house away . The people in the kitchen wouldn't survive it .. The simple way is : Just throw a wet blanket over the flames of 1.8 meter height while you protect your arms and hands . I've done that too , and it's really amazing how fast the fire was extinguished due to lack of oxygen...
M5Rick58913.50 |
11-30-2020, 12:50 PM | #212 | |
564
Rep 465
I'm a fire protection engineer so all this is right up my alley. |
11-30-2020, 12:55 PM | #213 |
58914
Rep 19,254
I started a scrap wood fire stuffed inside with some crushed newspapers,I poured a 1/2 litre of gas over the pile then flicked a match onto it at the same time moving back fast, there was a boom and I felt the explosive shock with loud bang even as I was moving away.
11-30-2020, 12:55 PM | #214 |
564
Rep 465
Grosjean's crash reminded me of when I was competing with Formula SAE back in '14 and watched a university's car catch fire while driving on course. Potential fuel rail failure. The bolt in their harness quick release supposedly had worked its way a little loose, and the driver couldn't release the harness. So the driver was engulfed in flames waving his arms until a course worker got to him with an extinguisher, and someone else cut him free. I heard the driver made it out relatively okay but with some second degree burns. They were wearing nomex suit, gloves, shoes, but man it was really scary to watch.
///M Power-Belgium62748.50 minn1913970.00 |
11-30-2020, 01:02 PM | #215 | |
62749
Rep 24,514
All I can say is : The heat was scary to approach , but I learned at lot of how dangerous a fire can be . Backdraft fire is the hell's fire ! Meanwhile I know what fire can do , but also what mistakes can do...
M5Rick58913.50 |
11-30-2020, 01:47 PM | #216 |
3855
Rep 2,064
Doc Roberts and driver van der Merwe were approaching the inferno with open face helmets (and fortunately balaclavas). Very heroic because the heat must have been insane.
In the aftermath of this crash the protocol will surely be adjusted - full helmets for the guys in the medical car.
2004 e87 118d (ret.), 2007 e92 330d (ret.), 2007 e87 130i M-sport (ret.), 2009 e92 M3 (ret.), 2010 f10 535d M-sport (ret.), 2015 f10 M5 CP (ret.), 2017 f82 M4 CP (ret.)
2022 g26 i4 M50 & 2009 e70 X5 35d |
11-30-2020, 02:40 PM | #217 |
3849
Rep 3,004
The FIA needs to mandate the installation of the same deceleration materials installed at the other corners of the track at T3, the location of the GRO shunt.
The Armco rails run at a 30 degree decreasing radius and make the impact much worse. Another words, the Armco barrier is not parallel with the race track, which creates a significant hazard. http://www.impactsafetybarriers.com/...Comparison.pdf
Racerbruce
11-30-2020, 02:58 PM | #218 | |
34172
Rep 11,637
We are all worse than Armchair Quarterbacks. We're Armchair Accident Investigators. Has there ever been a more ridiculous thing to be? Let's wait for the investigation before announcing a conclusion.
11-30-2020, 02:59 PM | #219 |
2510
Rep 4,381
You would have thought that the FIA could have found a better barrier than armco by now.
It shouldn't be possible for a nose of an F1 car to be able to get between two layers and separate them. |
11-30-2020, 03:08 PM | #220 |
2510
Rep 4,381
Verstappens comments on Albon:
“I don’t think that if you are 30 or 40 seconds behind your team-mate, that’s very good,” Just because something is true doesn't mean you have to be an arrogant douche and say it. |
