      01-30-2012, 11:38 AM   #1
momo style
32
Drives: 1m
12 MM spacers
Hi
Will 12 mm spacers rub on the car with the original suspension. I know it won't in the back but Im not sure for the front
Any comments?
      01-30-2012, 11:44 AM   #2
Sales@AUTOcouture
Sales@AUTOcouture's Avatar
25
Drives: VO 1M
Rears work to 15mm
Fronts 12mm
      02-09-2012, 12:02 AM   #3
HP Autosport
Supreme Allied Commander
3847
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Originally Posted by momo style View Post
Hi
Any comments?
Yes, the 12mm will cause the tire to rub on the oil and water cooler exhaust vents at or near full steering lock.
12mm is okay for the rear, but no more. Once lowered and at stock camber settings, anything more than 12mm will rub. If you plan to run more, you will need to add negative camber and anything more than -2 on a street car will start eating up the inside of your rear tires.
      02-09-2012, 06:45 AM   #4
bklounge
bklounge's Avatar
52
Drives: VO 1M
Harold do you think I could get away with 9.5" 24ET F, 10.5" 24ET R with 265/20/19 F 295/30/19 R PSS with KW V3 and the stock camber maxed out? Not really interested in a lot of rubbing, but I would like to lower a bit.
      02-09-2012, 09:22 AM   #5
momo style
32
Drives: 1m
Is anyone running with only 12 mm in the back? No spacers in the front?
      02-09-2012, 10:51 AM   #6
HP Autosport
3847
Drives: F80 M3
The wheels will fit, that is not a problem.
As long as the tires are right around the same diameter of the OE you will be okay. We are mostly concerned on diameter on the front with a 255 or 265. Rears at 295 will be a tight fit and you will have to try it.
12mm rear will work fine. 5mm works on the front, 10mm will work with some rubbing on the vents.
      02-09-2012, 09:06 PM   #7
BMW Gator
BMW Gator's Avatar
61
Drives: C8/R8/1M/X5/JK Rubicon/FJ40
Momo, I had been running around with 12mm rears and no spacers in the front -with that set up the front looked really "inset" . Today I added 10mm to the front and it looks "right". I am very happy with the 10mmF/12mmR. I personally think the 12mmF/15mmR that some are running looks too agressive or "gangsta" But to each his own!
      02-10-2012, 08:46 AM   #8
momo style
32
Drives: 1m
ok thanxs for the reply..
But I speak french, what does INSET means??
Thanxs
      02-10-2012, 09:52 PM   #9
BMW Gator
BMW Gator's Avatar
61
Thanxs
I should have said recessed or en retrait
      02-14-2012, 03:44 PM   #10
nicoz
Drives: 1M
Momo.. if you're from Montreal, I should have mine with 10F and 12R if you want to see how it looks.
1addicts
