06-08-2020, 06:19 AM | #23 | |
147
Rep 304
06-08-2020, 06:54 AM | #24 | ||
80
Rep 241
06-08-2020, 09:01 AM | #25 |
On the Go!
79
Rep 235
We did a 60 mile trip to the beach and here is the cumulative feedback:
1. No significant difference between Sport & Sport+ with DTC activated. Event the RPMs stayed the same when I toggled from one mode to the other. 2. Without DTC, Sport+ has a sharper throttle response, though only slightly, over Sport. 3. Lesser (or no) difference between Comfort & Comfort+. Absolutely nada. Mine is a MY2016, with standard M-Sport suspension and ~20K miles. I had 3 adults in the car and gas was half empty. I'm running on GY RFTS (OEMs) tires and OEM wheels. Road condition was average not Autobahn-like but it was also not a war-zone. Like a previous poster commented, the only material difference you can feel in the seat & steering wheel are Comfort (softer) vs. Sport (stiffer). HTH!
It doesn't matter if you win by a mile or inch, Winning is WINNING!
06-08-2020, 09:05 AM | #26 |
Air Vice Marshall
256
Rep 1,639
Yes!
It is standard fit on all UK 2020 X1's. Code 6CP.
2012 BMW 320d Sport (F31). 2013 BMW X3 xDrive 30d M Sport (F25). 2020 BMW X1 xDrive 2.0i MSport (F48). 2022 MB EQB 300 4MATIC AMG Line Premium |
06-08-2020, 09:34 AM | #27 | |
Air Vice Marshall
256
Rep 1,639
06-08-2020, 10:01 AM | #28 | |
On the Go!
79
Rep 235
You may be technically correct on the suspension, however, all I am stating is how the car feels in these two modes, not challenging your point.
06-08-2020, 10:12 AM | #29 | |
Air Vice Marshall
256
Rep 1,639
2012 BMW 320d Sport (F31). 2013 BMW X3 xDrive 30d M Sport (F25). 2020 BMW X1 xDrive 2.0i MSport (F48). 2022 MB EQB 300 4MATIC AMG Line Premium Last edited by Peter_R; 06-08-2020 at 10:39 AM.. |
08-15-2020, 09:50 PM | #30 |
137
Rep 310
ventjock,
Thanks much for your walkthrough to code Sport+. Successfully coded with BimmerCode. Car does seem to stay in a lower gear longer and revs a bit higher. Not a drastic jump up from Sport and I tend to drive in mostly Comfort with the wifey. But, good to know I now have an option to kick it up a notch whenever I'm out solo. |
08-24-2020, 12:57 AM | #32 |
47
Rep 231
You can add a CAI - Cold Air Intake and hire a programmer that has a laptop, software and an ECU ODBII connector; you can program the engine to produce at least 50HP if not more and considerably more torque. The engine is quite capable of producing much more HP. In fact the same engine is found in most of the new BMW vehicles from the 2,3,4,5, X1, X2 and X3...Just slightly different HP ratings. So the engine in the X1 has in fact been dumbed down. Your software programmer can also program all sorts of features to your X1 such as delayed mirror folding when you press the key FOB or the door handle. Pressing on the door handle with your finger for a slightly longer period of time will close all the windows, the sunroof, the sunroof cover and in some cases the hatch. Holding down the unlock button on the key FOB also opens all the windows and sunroof to cool down the vehicle before you enter.
09-03-2020, 06:51 AM | #33 |
Rep 10
09-03-2020, 06:58 AM | #35 | |
Rep 10
Still not capable to find the differences between this and COMFORT mode |
Takabo49.00 |
03-26-2021, 08:38 AM | #36 |
Rep 2
Sport+ (Expert Mode)
Did this via expert mode in BimmerCode 1 - BDC--> 3221 PfFesMaster --> FesHasMode 5 --> set to "Aktiv" 2 - Instrument Cluster KOMBI --> 300C ECO_FDS --> FDS_MENUE_TEXT_1=> menue_3 FDS_MENUE_SIGNAL_1=> menue_3 FDS_MENUE_TEXT_2=> menue_3 FDS_MENUE_SIGNAL_2=> menue_3 FDS_MENUE_TEXT_3=> menue_3 FDS_MENUE_SIGNAL_3=> menue_3 FDS_MENUE_TEXT_4=> menue_3 FDS_MENUE_SIGNAL_4=> menue_3 |
03-26-2021, 12:13 PM | #38 | |
22
Rep 81
https://f48.bimmerpost.com/forums/sh...ght=bimmercode |
03-26-2021, 07:29 PM | #39 | ||
Rep 19
09-16-2021, 01:13 PM | #40 | |
The BMW Life
21
Rep 69
Hi, Can you confirm what the FDS_MENUE_TEXT and _SIGNAL changed? Mine are set at : menue_4 ....for _1 to _5 I changed them to menue_3, but did not see anything change, so i out them back to menue_4 Much appreciated if you could verify what that changes. Cheers, |
10-19-2021, 12:05 AM | #41 | |
Rep 1
After coding comfort plus and sport plus. Does your sport plus mode appear in speedo for selection? I can only see comfort plus in the speedo. |
10-24-2021, 09:37 AM | #42 | |
22
Rep 143
What does the code for the instrumental cluster do? Thanks in advance. |
10-26-2021, 01:59 PM | #43 |
4448
Rep 7,488
The KOMBI (instrument cluster) coding shows you the driving mode you've selected. If your BMW didn't come with the additional driving mode selections like SPORT+ or COMFORT+...when you code the BDC (or what ever module that controls these functions)...you also code the KOMBI (cluster) so that you can see the new menu selections displayed.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
10-27-2021, 06:04 AM | #44 | |
22
Rep 143
I have coded the bdc, fortunately the cluster is able to display the sport + in the cluster |
