BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Sport+ Driving Mode
      06-04-2020, 08:52 PM   #1
ventjock
65
Drives: 2020 M340i
Sport+ Driving Mode
Did this via expert mode in BimmerCode
BDC--> 3221 PfFesMaster --> FesHasMode 5 --> set to "Aktiv"
Gears will shift at higher RPMs and DTC is turned on.
2016 F48 X1 -> 2020 G20 M340i
Appreciate 6
      06-05-2020, 12:11 AM   #2
Takabo
Takabo's Avatar
Japan
49
Drives: G21 320d xDrive Touring MSport
Hi ventjock,
Is "Sport+" displayed on the speedometer (cluster)?
Thank you.
BMW 320d xDrive Touring M Sport(G21)
Production Plant: Munich, Production Date: 2021-02-25
      06-05-2020, 12:42 AM   #3
ventjock
65
Drives: 2020 M340i
Originally Posted by Takabo View Post
Hi ventjock,
Thank you.
Yes https://imgur.com/a/4Kzx7tn
Sorry that’s the image is sideways. I’m on my phone
Takabo49.00
      06-05-2020, 01:11 AM   #4
maaii11
21
Drives: Mini F54
Hi sir
Could you help to provide .NCD file of your KOMBI ecu ?
Because In Mini system F54 can't show "Sport+" in speedometer (cluster).
Takabo49.00
      06-05-2020, 07:15 AM   #5
iceman7
iceman7's Avatar
Greece
117
Drives: X1 LCI sDrive 18i
This is in an XDrive 28i ?
My BMWs
02/2017 - 10/2019: X1 F48 18i sDrive X-Line Platinum Silver with Android 10,25 Aftermarket Screen
11/2019 - Present: X1 F48 LCI 18i sDrive Connected Advanced Mineral White
      06-05-2020, 08:00 AM   #6
Proper
Proper's Avatar
100
Drives: X1 M-Sport
Successfully coded! Thanks vent!
      06-05-2020, 08:13 AM   #7
Proper
Proper's Avatar
100
Drives: X1 M-Sport
Yes
      06-05-2020, 08:39 AM   #8
iceman7
iceman7's Avatar
Greece
117
How do you select it using the button? You press it towards sport twice?
Has anyone tried it in diesel X1s or smaller petrol engines?
My BMWs
      06-05-2020, 09:10 AM   #9
ventjock
65
Drives: 2020 M340i
Yes, toggle sport mode twice to select.
Yes it is an XDrive 28i
      06-05-2020, 10:18 AM   #10
Proper
Proper's Avatar
100
Drives: X1 M-Sport
Heres what it looks like on the tach...
      06-05-2020, 10:35 AM   #11
kreizyidiot
Drives: '18 X1 sDrive28i
What's the difference between sport and sport+?
      06-05-2020, 10:51 AM   #12
ventjock
65
Drives: 2020 M340i
Tons of discussions on the 3 series forums regarding the differences.
      06-05-2020, 11:53 AM   #13
Xorbitman
47
Drives: 2018 BMW X1
Does this allow the use of "Launch Control" on a regular X1 X2.8i ?
      06-05-2020, 05:36 PM   #14
ventjock
65
Drives: 2020 M340i
Have not tried it. You should be able to use launch control if you engage DTC. Again never tried launch control either method
      06-06-2020, 04:13 AM   #15
Takabo
Takabo's Avatar
Japan
49
Hi ventjock,
Hi maaii11,
SPORT+ has been set. Thank you for teaching me.
P.S.
COMFORT+ mode added
BDC_BODY > 3221 PfFesMaster, 11 > FesHasMode2 = aktiv (default: nicht_aktiv = 00)
KOMBI2 > 300C ECO_FDS(300C ,3C) > FDS_MENUE(300C_0_0_255) = menue_9 = 09 (default: menue_4 = 04)
OPTIONS
(kein_menue = 00, menue_1 = 01, menue_2 = 02, menue_3 = 03, menue_4 = 04, menue_9 = 09)
      06-06-2020, 10:16 AM   #16
NotSooFast
On the Go!
NotSooFast's Avatar
No_Country
79
Drives: Just a few!
Hi ventjock,
Hi maaii11,
P.S.
COMFORT+ mode added
KOMBI2 > 300C ECO_FDS(300C_0_0_255) > FDS_MENUE = menue_9 = 09 (default: menue_4 = 04)
OPTIONS
Thanks for sharing. Mind if ask your personal opinion on how different is Comfort+ vs. Comfort on your M sport suspension? Does it soften the suspension at all?
It doesn't matter if you win by a mile or inch, Winning is WINNING!
      06-06-2020, 07:22 PM   #17
Takabo
Takabo's Avatar
Japan
49
Hi pTron,
I can't feel the difference while driving. I need a little more time.
      06-08-2020, 12:13 AM   #18
808X1
80
Drives: F48 X1 M-Sport
Did the Sport+ setting as described by ventjock. To be honest, could not tell the difference between that and Sport with DTC manually activated. In fact, I am not even sure if DTC is really activated, as it usually displays the icon for DTC activation on the dash when manually activated. With Sport+, no DTC icon was shown on the dash, except it was mentioned only on the screen display showing Sport+ was activated. Perhaps I was expecting something more from Sport+?
      06-08-2020, 01:36 AM   #19
SDriver18i
SDriver18i's Avatar
No_Country
80
Drives: BMW X1 s18i 2019
Yeah, on F30 forums you see them mention a more aggressive and faster operation when switching to Sports+ but I see no difference at all either.
      06-08-2020, 03:19 AM   #20
808X1
80
Yeah, after reading about it on the F30 forum, I was expecting something more significant than Sport mode and manually activated DTC.
      06-08-2020, 04:09 AM   #21
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Not trying to pick you up on your wording, but suffice to say, you cannot have comfort or comfort + on an M Sport suspension on these cars.
BMW will not/cannot build it. When you go into the configurator and specify the M Sport model, and specify the adaptive suspension, the configurator deletes the M Suspension that would have lowered the car by 10mm.
So to summarise. If you are able to actually change the suspension settings (meaning you have the adaptive suspension), there are 2 suspension settings:
Comfort (standard setting).
Sport (firmed up and stiffer).
I know this because I have just ordered a new car and specified the adaptive.
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      06-08-2020, 04:31 AM   #22
SDriver18i
SDriver18i's Avatar
No_Country
80
You have carplay in the new X1?
