11-22-2019, 08:24 PM | #1 |
171
Rep 313
BimmerCode for Flash to Pass
Has anyone used BimmerCode to change one-touch flash to pass from 3 flashes to 5 flashes?
I looked through the ECUs for the setting, but cannot find it. Thanks. |
11-23-2019, 06:34 AM | #3 | |
49
Rep 69
5_FACH_TIPPBLINKEN → aktiv(Default:nicht_aktiv)
BMW 320d xDrive Touring M Sport(G21) Production Plant: Munich, Production Date: 2021-02-25 |
wcs2229170.50 |
11-24-2019, 06:08 AM | #6 |
147
Rep 304
You’re still one level too high - each of those headings contains a number of individual parameters. My recollection is that the one you want is under 3000 HMI, but if not, does the Android version offer a search function like the iOS version? I’ve used that several times to search for a specific entry when I wasn’t sure what section of a particular ECU it was in.
11-24-2019, 10:38 AM | #7 |
49
Rep 69
There is also information at the following URL.
https://f48.bimmerpost.com/forums/sh...84&page=25#548
wcs2229170.50 |
11-24-2019, 05:39 PM | #8 |
171
Rep 313
I have some good news and some bad news ...
The good: I found 5_FACH_TIPPBLINKEN under 3000 HMI in Headunit Expert Mode. I changed it to "aktiv", HU rebooted, then I exited BimmerCode, restarted car and went back into BimmerCode to confirm the setting. Thanks to maaii11, Takabo and kavatski. The bad: It still only blinks 3 times! |
11-24-2019, 06:52 PM | #9 | |
49
Rep 69
https://f48.bimmerpost.com/forums/sh...st24551219#592
BMW 320d xDrive Touring M Sport(G21) Production Plant: Munich, Production Date: 2021-02-25 Last edited by Takabo; 11-24-2019 at 10:22 PM.. |
wcs2229170.50 |
11-25-2019, 06:17 PM | #11 |
147
Rep 304
I like 3 blinks so I hadn't done this change but figured I'd try it on our 2019 just to check. No problem - now I have 5 blinks as an option. I'd say Bimmercode's info is out of date.
10-17-2021, 08:16 PM | #14 |
171
Rep 313
After coding with BimmerCode, you still have to go into iDrive to set the number of blinks. The coding only enables more blinks you can select.
10-17-2021, 09:28 PM | #15 | |
21
Rep 140
Wondering if that is possible. I found this on another site HU_NBT, Section 3000 HMI, Value 5_FACH_TIPPBLINKEN aktiv and BDC Body PIA_Default_TippBlinken 5 mal However when I got into PIA_Default_TippBlinken the value don't seem to be in mal. |
10-18-2021, 08:25 PM | #16 | |
171
Rep 313
10-18-2021, 10:49 PM | #17 |
21
Rep 140
