10-30-2016, 05:19 PM | #1 |
1190
Rep 1,544
Drives: '22 Tesla MY + '23 Tesla MY
Euro foglight switch?
Anyone get their rear fog lights working? We do a lot of driving in rual areas that aren't lit and I really want to get the rear foglights working. On my X5 it was a new switch and one wire to the FRM module, but has anyone figured it out for the F48 yet?
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
10-30-2016, 06:52 PM | #2 |
170
Rep 549
Headlights or front fog lights have to be switched on for the rear fog lights to work. I've used mine a couple of times so far without any issues. Used it just last night in fact.
10-30-2016, 08:44 PM | #3 |
1190
Rep 1,544
Yes, but in North America, our light switch only has the button for the front fogs. On some models, like the E90, it was just buying the right switch to get the rear fogs to work. On other models like my E70, you had to run an additional wire from the light switch to the module which controls the lighting.
I don't know where to find the F48 wiring diagram (my copy of WDS is too old), so I can't see if there are any differences between the Euro/Aussie versions of the car in the wiring
10-31-2016, 07:06 AM | #4 |
170
Rep 549
That sounds above my pay grade, I'm afraid. I've attached he only PDF I have that mentions exterior lighting. No idea if it's outdated or now (credit to ynguldyn; more HERE).
blue dragon1190.00 |
10-31-2016, 06:28 PM | #5 |
1190
Rep 1,544
Thanks, not quite what I was looking for, but interesting information
04-04-2018, 03:09 PM | #6 |
113
Rep 342
Drives: G20 330ix M Sport
blue dragon did you ever figure this out?
04-06-2018, 02:41 PM | #7 |
1190
Rep 1,544
Haven't tried. I would imagine it's similar to the f30. I'd did the rear fogs on my F30 and while you could enable it by filing down some tabs to enable the switch, I opted for the euro switch plus coding
04-06-2018, 07:33 PM | #8 |
113
Rep 342
I want to get the euro switch. But I cant seen to figure which switch I need for my X1. And all the ones on eBay all state they will not ship to the US.
05-12-2018, 10:48 AM | #9 |
1786
Rep 3,055
Did you figure out coding?
I've change the switch but can't code it to work. NSL_Verbaut = Verbaut Mapping_Nebelschlussl_L_output = nsw_l Mapping_Nebelschlussl_L_Function = nebelscheinwerfer Mapping_Nebelschlussl_R_output = nsw_l Mapping_Nebelschlussl_R_Function = nebelscheinwerfer I've made this changes and fog light still doesn't work. |
mikeyb74113.00 |
07-05-2018, 10:17 AM | #10 | |
113
Rep 342
07-05-2018, 10:24 AM | #11 |
1786
Rep 3,055
08-20-2018, 12:36 PM | #12 |
113
Rep 342
What did you to get it to work? I finally got my X1 back swapped the switch. Thought I coded it. But now the front fogs do not come on and the rear fogs still don't work.
"It is funny...people who drive anything expensive often get labeled by folks who drive less expensive cars. I have found, without exception, that douchebags cover all demographics and incomes."
12-03-2019, 11:00 AM | #14 | |
110
Rep 394
Here you go https://f48.bimmerpost.com/forums/sh....php?t=1666194 |
12-03-2019, 11:59 AM | #15 |
159
Rep 458
Although not residing in the USA, I read this topic with some alarm.
Here in the UK, my X1 and most other recently manufactured cars have rear fog lights. I find following cars with them switched on to be one of the least pleasurable experiences of driving. The reason why? Well, we only have to see a bit of mist when out on the road and substantial numbers of 'numpties' think ' wow, I'll switch on my fog lights (front and rear).' They then dazzle the driver of any any following (or approaching) vehicle, which in itself can lead to accidents. Worse still is that many of these 'drivers' forget to switch them off when the mist clears, making matters even worse. We had a misty/foggy day in the English Midlands a few days ago and there were numerous vehicles showing their foglight through the day (although most of the mist was cleared by late morning). Again, I don't know what regulations cover use of foglight in the USA, but here in the UK it is an offence to switch them on except under specific conditions and here's what the law states: 'You MUST use headlights when visibility is seriously reduced, generally when you cannot see for more than 100 metres (328 feet). You may also use front or rear fog lights but you MUST switch them off when visibility improves (see Rule 236).' Here's what Rule 236 says: 'You MUST NOT use front or rear fog lights unless visibility is seriously reduced (see Rule 226) as they dazzle other road users and can obscure your brake lights. You MUST switch them off when visibility improves.' I apologise to our friends in the USA for having this rant, but I think fog lights are, in reality, more of a nuisance than an aid except in the very worst of conditions. Incidentally, the LED rear lights on my X1 are bright enough for driving under most conditions without having to resort to using the fog lights. |
12-03-2019, 12:25 PM | #16 | |
110
Rep 394
oakey46158.50 |
12-03-2019, 01:46 PM | #17 | ||
52
Rep 105
12-03-2019, 03:00 PM | #18 |
129
Rep 421
All US Volvos have them, and have since the 1990's. It's a constant source of amusement on Volvo forums when people discuss whether they're useful, legal, or burned-out-on-one-side.
12-03-2019, 03:03 PM | #19 | |
159
Rep 458
12-04-2019, 11:00 AM | #20 | ||
52
Rep 105
I bet that mini was fun to drive, could even pick it up and move it if needed For anybody else curious of the outcome. I pulled off the plastic switch (pry tool) shaved down the 3 tabs, coded using BimmerCode and had success. It was extremely easy. |
12-05-2019, 10:26 AM | #21 | |
159
Rep 458
My son claims my X1 isn't a proper BMW as it's front wheel drive, but is just a 'big Mini', unlike his 2017 BMW 1 Series. Well, I enjoy my X1 and have covered just 20K miles in 20 months, so I tell him to get real! |
