09-28-2021, 10:12 AM | #1 |
Rep 1
Remove inner wing / fender liner
Hi,
Does any one have a video or instructions as to how to remove the plastic liner inside the front wing/fender on an X1 F48. I need to do this to remove my washer bottle to clean the windscreen washer pump and filter. Thanks Last edited by Tigerspill; 09-28-2021 at 10:22 AM.. |
09-28-2021, 12:15 PM | #2 |
266
Rep 649
Hi Tigerspill,
According to ISTA, you need to remove the front right wheel arch cover to access the washer pump. I attached the instructions.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
02-27-2024, 08:26 AM | #3 |
Rep 1
Windscreen Washer Pump Replacement
Hi,
I'm new to this forum in fact this is my first post! so here goes!! I have a X1 F48 2017 with an issue with the windscreen washers? the pump runs but there is no water coming up to the nozzles, I have disconnected the pipe at nearest nozzle to the tank and tried blowing air down the pipe, I'm getting air in the tank so there isn't a blockage?? is this a common thing on these X1's and is it easy to change the pump? Dave |
