06-12-2013, 06:06 PM | #23 |
European Editor
10628
Rep 22,992
Headlight switch set to MANUAL ON position. Headlights point straight ahead.
AHL2 EU coding... switch in AUTO mode... note hoe the dirver's headlight swings out further to the LEFT and slightly down. Highbeam pattern - pretty much the same, except for more light output do to EU coding on my US spec 135i.
06-13-2013, 04:30 PM | #24 |
European Editor
10628
Rep 22,992
07-09-2013, 10:22 PM | #25 |
86
Rep 638
I know this is off topic but just wondering if anyone's been able to code activating pathway lighting via the trunk button on the key fob?
Current: 2022 M240i xDrive
Previous: 2018 440i xDrive, 2012 135i |
07-10-2013, 02:56 AM | #26 |
85
Rep 2,438
07-10-2013, 11:53 PM | #27 |
86
Rep 638
Yeah it's weird DimSum coded it but it doesn't work... He said he had coded it on 3-series and it did work so kinda odd... Got the AHL2 coded it's pretty sick. Just wondering if only the drivers side headlight is suppose to move outward?
07-11-2013, 11:12 AM | #28 |
European Editor
10628
Rep 22,992
No, BOTH lights will move outwards when in light switch is in "AUTO mode". But the drivers side headlight will move outwards and down a little bit. While the passenger's side light just moves outwards.
07-11-2013, 11:48 PM | #29 | |
86
Rep 638
07-12-2013, 07:10 AM | #30 | |
European Editor
10628
Rep 22,992
Yes, both lights move, like I said above. Its kind of hard to see in the video. Dackel
07-12-2013, 07:40 AM | #31 |
4338
Rep 6,196
I bought a Euro HL switch from a friend. It has the switch for the front fogs, which the 135i does not have. Will the REAR foglight switch still work? Will have to find out about coding for the EU beam functions. Pretty cool!
07-12-2013, 07:55 AM | #32 |
85
Rep 2,438
It will work and you can take out the button for front fogs and put in from your 135i blind button.
07-12-2013, 08:22 AM | #33 |
86
Rep 638
I just got a buddy of mine to turn the switch from manual to auto for me as I watched and the drivers side headlight does indeed rotate outwards and down however the passenger side headlight didn't move... I thought it might not be working properly but it moves when you turn the steering wheel... Does anyone know specifically what the line codes are?
07-12-2013, 09:31 AM | #34 |
4338
Rep 6,196
07-12-2013, 10:04 AM | #35 | |
86
Rep 638
07-12-2013, 10:45 AM | #37 | |
European Editor
10628
Rep 22,992
Dack
07-12-2013, 03:22 PM | #38 |
86
Rep 638
looking @ headlights would be great!
07-12-2013, 03:58 PM | #39 |
86
Rep 638
Driver side: http://tinypic.com/r/32zs8z7/5
Passenger side: http://tinypic.com/r/fn9zr9/5 Clearly the driver side is swiveling outwards when on auto however the passenger side doesn't seem to be. Am I missing something here?
07-12-2013, 04:10 PM | #40 | |
European Editor
10628
Rep 22,992
Yes, only the driver's side will pivot outwards while the car is parked. I believe the passenger side does swing outwards when under way. I know BOTH head lights will swing left and right following the steering wheel inputs. Plus they will more more than before with USA coding. But looking at the vidoes I shot tonight(they are uploading as I type this) only the driver's side head light swings outwards. IF you flick on the high beams you will see the drivers side head light move from outwards to straight ahead position. Dack
07-12-2013, 05:14 PM | #41 |
European Editor
10628
Rep 22,992
EU AHL coding headlight videos...
Here you go... NOTE: the car MUST be running in order to see the driver's side low beam move outwards. When you only have the key fob switch on... the headlight will only move up and down. As see here...
07-12-2013, 05:23 PM | #42 | ||
86
Rep 638
07-12-2013, 05:41 PM | #43 | |
European Editor
10628
Rep 22,992
IF it was... no, I do not think you have it coded right, bc the headlight was not angled out like my car is. When you switch on the car(and the headlight switch is in AUTO mode) you sill see the drivers side headlight move up and then down... and then after a few seconds... the driver's headlight will point out at about 30' angle. Look at my video with the headlights on the garage wall. Dack
07-13-2013, 08:55 PM | #44 | ||
86
Rep 638
