BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Got myself some pedals...
      01-13-2020, 10:45 AM   #1
rice_rocket88
No_Country
298
Drives: E60 F48 F39
So I was bored and browsing around. I got myself some Msport pedals to match the rest of the car.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Just to note, that this is the ONLY one that fits.. the round brake pedal. If you look for the trapezoid (rectangular-ish) one it will not fit. I'm a little unsure which orientation I like the pedal with. To me it looks like the pattern is best with the rubber on the right side of the brake pedal, but it puts a teeny bit of 'grip' when sliding the foot from brake to gas. I flipped it around and it's much smoother, but I can't get over the idea the pattern doesn't match up. Here's a picture of the "matched pattern" If you look at the amazon ad it has it both ways.
The gas pedal is pretty simple slip on, you can make sure all the rubber encases the pedal as it's pretty tight tolerance. The brake pedal is a real chore to get it on, since it's TIGHT! I have done it a few times now taking it on and off so I'm much better at it. The idea is you slide one side on, get your finger in it, and try very hard to pry the rubber so it'll flip over the metal pedal. You can grab the edges and persuade it over a little once you have enough flipped over the edge. For $25 it's a superb mod!
