BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Burger Tuning JB4 install on B48 X2 m35i
      06-02-2021, 01:22 PM   #463
billnchristy
1604
Drives: 2022 M440xi GC
The b48/58 has a built in one that returns to sump anyway
      06-06-2021, 11:17 AM   #464
CPWillys
Drives: 2020 Clubman JCW
Hello JB4 B48E users, 21M235XGC directed me to this post after disappointing support on the N54 Forum. I have read through many of the posts here, I was running the V19 firmware and I noticed that timing was added sparingly.
I've since switched to V17 and the timing has come to life, I have run map 1,2, and 3 with good results.
I only have a FMIC on my car, I installed it in anticipation of the additional heat from the tune and to prepare for an open road course day that I am attending next week.
I look forward to contributing to the discussions here.
      06-06-2021, 12:34 PM   #465
rice_rocket88
Drives: E60 F48 F39
Great to have you here!
      06-06-2021, 02:58 PM   #466
xcelir8bmw
xcelir8bmw's Avatar
402
Drives: 2022 BMW M240ix
Heavy testing today on maps 1 and 2 with v17 software.
87F and pipercross filter.
Map 1 is 3 additional psi over stock and super safe. Spikes to 30.
Map 2 additional 4 psi over stock and seems safe and spikes to 32.
Sticking to map 3 in this heat so I don't go above 30.
No failsafe in either.
One thing I noticed and don't honestly remember but am I the only one missing Temp IAT readout?
      06-08-2021, 07:00 AM   #467
xcelir8bmw
xcelir8bmw's Avatar
402
Bueller? 😀
      06-08-2021, 07:13 AM   #468
CPWillys
Mine has a different gauge layout but the Intake air temp has always been present.
      06-08-2021, 12:41 PM   #469
rice_rocket88
Drives: E60 F48 F39
Hmm I don't seem to be getting updates to this thread much by email, not sure why.
Anyways, I do get my IAT as well, and I'm still using the "stock" gauges like CPwilly. I didn't bother changing the style. I'm just setting it at map2 and forgetting it.. haven't hit failsafe myself in a while, usually I feel the little stutter when it does/did. I'm running the pipercross as well still.
      06-09-2021, 07:18 AM   #470
xcelir8bmw
xcelir8bmw's Avatar
402
What firmware version are you guys on?
      06-09-2021, 05:02 PM   #471
samzor
Drives: BMW X2m35i
question, do you still think it is worth to buy JB+ for a X2m35i ?
      06-09-2021, 05:12 PM   #472
rice_rocket88
Drives: E60 F48 F39
I'm not sure what version I'm running now.. probably 17.
My iat was 129 today on a 90F day. I do believe if I remember correctly even with my open cover intake it was 137 ish last year.
Boost was still 24.5 and timing was at 7.5.
As to the other question, I'd much rather have the jb4 vs the jb+ that I can't log or have safety failsafe. Is it worth the extra power? I think so.. I would certainly like to see anyone's dyno .. but others with dragy noticed a good improvement.
      06-09-2021, 08:20 PM   #473
xcelir8bmw
xcelir8bmw's Avatar
402
no
      06-09-2021, 08:40 PM   #474
xcelir8bmw
xcelir8bmw's Avatar
402
Figured it out. Accidentally. I didn't know if you hold down on a gauge you can change what is displayed. So I rechose IAT. Bam all good. Then I changed my gauge setup to be more inline with my AEM. May fiddle with colors still.
Stooooopid. 😀
      06-10-2021, 01:33 AM   #475
samzor
Drives: BMW X2m35i
Sorry I wanted to ask for JB4 not JB+. Is it worth it ? is it safe for a newbie in car ? and without any other addition ?
      06-10-2021, 07:11 AM   #476
xcelir8bmw
xcelir8bmw's Avatar
402
Originally Posted by 21M235IXGC View Post
Stooooopid. 😀
Stooooopid. 😀
Also if u didn't know if u double tap the boost gauge only it will show the last peak psi reading 👍🏻
saw that too!
      06-10-2021, 07:13 AM   #477
xcelir8bmw
xcelir8bmw's Avatar
402
yes, absolutely!
      06-10-2021, 07:14 AM   #478
xcelir8bmw
xcelir8bmw's Avatar
402
Stooooopid. 😀
Map 3 is 6psi , I wouldn't go with map 3 .. map 1 when it's hot out and map 2 when it's colder out .
agree! no map 3! even though with TDI at one point I was in that territory.
      06-10-2021, 07:24 AM   #479
samzor
Drives: BMW X2m35i
yes, absolutely!
Ok great. And why you didnt just reprogram it using CMD flash ?I see you have a 2019 so it should be not protected.Only june 2020 are protected. Then You dont need additional box
      06-10-2021, 11:27 AM   #480
rice_rocket88
Drives: E60 F48 F39
Well mainly because there is no off the shelf flashes for us to do.. MHD does not have it. Although I have a local tuner that is able to flash over the ECU according to his website.. still only the 30hp gains, so unless there's massive benefits.
Also think of it this way.. if the car ever got to BMW and they did a courtesy update, then your ECU will be locked, and the tune is down the toilet. Piggyback will always work no matter what. Also the logging ability is really nice.
xcelier8bmw: I just checked this morning and I am running v18. I do believe way back in the day Terry@burger wanted me to update to v18 for the failsafe when he was working on things... but as you guys have shown, v17 seems ok. My timing itself didn't take a dump when I did a quick pull yesterday in the extreme heat so I think I'm perfectly fine with v18 still.
      06-10-2021, 03:07 PM   #481
xcelir8bmw
xcelir8bmw's Avatar
402
I actually now think v18 is just fine. However, I have seen and felt better results with v17. I was running v18 in cool weather with no issues. I never ran v18 because I saw your original post and I went with that. Though in the hot-hot-hot dayam it's hot heat right now, v17 or v18 in MAP 1 works fine. I'm sticking with whatever the 'stable' version is and right now it is v17, and well, we will see in the future.
And what is really funny as of today, my AEM LED gauge and the JB4 LED round gauge, matches pretty darn close in regards to boost performance and max. And the upgrade iPhone 12 Pro Max (yeah, that must of burped the IAT readout configuration in software) has a large enough display, though off center works really well.
Though I still love the AEM. I would really of wished or wish they can put a boost gauge up via the HUD. Now that would be perfect!
      06-11-2021, 08:41 AM   #482
samzor
Drives: BMW X2m35i
Ok I heard everywhere that additional box is notcthe way to go, it can arms the engine and make lot of problem.So it is definitely not correct ?
      06-11-2021, 11:44 AM   #483
rice_rocket88
Drives: E60 F48 F39
There's lots of things in the HUD that I have seen on various 5 series and other M series such as RPM, gear, heck even signalling with the arrows is nice! The ricer in me still wants a boost gauge.. I might get to it one day, but I'm anxiously waiting for my Maxton Design front lip that has been "pre-ordered" for months and months.. Maybe boost gauge next
      06-11-2021, 11:49 AM   #484
rice_rocket88
Drives: E60 F48 F39
I think you need to do some more reading and decide for yourself. In my opinion a true full ECU flash *IF* done correctly will always be better, HOWEVER if that flash has bad values it will definitely hurt the engine as it is rewriting the base programming of the car itself. The piggybacks are a little more standard, and some like the JB4 has a built in failsafe. The piggyback intercepts signals to sensors so the car's ECU will compensate for it. *IF* the piggyback has a way to failsafe .. or the signal is so far off that even with the piggyback's signal being off chart it will still hit the car's ECU limit and failsafe by default (ECU wise).
The JB4 does have this failsafe feature within it's own software and seems to be fine if you don't go setting that boost limit too high. That coupled with not a lot of ECU flashing available, AND the fact that BMW could potentially flash/lock the ECU which would render any of the ECU flash invalid is why I chose to keep with the JB4 for now.
